Author Topic: My keyboard listing/database project  (Read 1904 times)
Offline azhdar
  • Praise the AZERTY god
« on: Mon, 01 September 2014, 11:10:09 »
I have the project to build a listing/database of all mech keyboards .
I noticed that there's no easy way to look for a keyboard based on criterias unless you go to mechanicalkeyboards.com but their large catalog is still missing lot of keyboards .
This will probably lead to something really similar to this page with more filters .
I also plan to put a quiz kinda like this one.
This is mainly to list CURRENT keyboards , older keyboards aren't the focus of this .
So far i have come with those fields to specify a keyboard :
  • Brand
  • Model
  • Size (Fullsize,TKL,60% .... )
  • Switches avaible
  • Backlit (Yes/no)
  • Backlit color
  • Macro keys
  • USB HUB (0/1/2 ... )
  • Headphones pluggable (micro+heaphone)
  • Media Keys (VolUp,Play-Pause,... )
  • Others features (Programmable layer , .... )
  • Current Price
  • Interface   (USB,PS2 , .... )
  • Release date
  • Release price
  • Review links (either geekhack,videos like linustechtips,reddit ... )
  • customizability (How standard are the keys ? )
  • Layout Avaibility (ANSI, ISO , ISO DE , ISO UK .... )
  • Keycap plastic    (ABS,PBT ...)
  • Wrist rest    (Yes,No,Removable)
  • Places to buy it (link resellers)
  • Removable Cable (yes/no)
It will be handle like a database for exemples :
Poker 2 ANSI mx blue green backlit ,
Poker 2 ANSI mx red green backlit ,
Poker 2 ANSI mx red no backlit ,
POKER 2 DE ISO mx blue green backlit
will be 4 differents entries .
Do you think i missed fields to define a keyboard ?
I'll also think of a solution to allow other people to add keyboard while avoiding the fake entries .
Azerty Propagandiste
Offline FoxWolf1
  • 154
Re: My keyboard listing/database project
« Reply #1 on: Mon, 01 September 2014, 11:44:58 »
Just a few things...
You have a field for keycap plastic, but you should also have one for printing method (laser, pad printing, dyesub, doubleshot, painted and engraved, etc.).
PCB vs plate mount for switches.
Plate material-- you might have a hard time finding this information, but some people might find it useful to be able to exclude anything with a crappy (plastic) plate.
Case material.
Offline azhdar
« Reply #2 on: Mon, 01 September 2014, 12:07:41 »
Noted , thanks will add that
« Reply #3 on: Mon, 01 September 2014, 14:07:13 »
One thing I think might plague your effort is a philosophical issue.
What, exactly, counts as a "mechanical" keyboard, and how is that different from a "rubber dome" keyboard (or another type).
Once you have a very clear definition of that, then you can continue to catalogue everything that falls into the category.
Many keyboards enthusiasts enjoy (model M, topre) have aspects of keyboards we don't.
