Author Topic: Looking to downsize old gaming PC - case ideas?  (Read 4589 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
« on: Mon, 01 September 2014, 21:56:31 »
I'm looking to downsize my old gaming PC. Currently it's in an NZXT Phantom case which is ****ing massive and impractical.
The build is about 3 years old, and the main size constraints would be that I have a Rampage III Extreme MOBO and a massive 6950 GPU. I also need space for 1 SSD and 4 HDDs as it is going to be used for storage and watching of films/TV shows. I would like the case to be as small (and as cheap?) as possible, and am willing to swap out the GPU if I need to (thinking of you dorkvader). It doesn't need to look good/cool/#SWAG but that would be a bonus too.
« Last Edit: Mon, 01 September 2014, 21:58:31 by katushkin »
Offline Badwrench
  • ummmm.....I forgot
Re: Looking to downsize old gaming PC - case ideas?
« Reply #1 on: Mon, 01 September 2014, 22:12:54 »
Nuff said.  Lian Li PC A05   :thumb:
As long as your PSU isn't longer than 165mm, you should be good to go.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112331
Offline CSCoder4ever
  • If it clicks I dig it
    • my github
« Reply #2 on: Mon, 01 September 2014, 22:13:24 »
I'm guessing this is a full tower phantom vs the Phantom 410 mid tower?
Corsair Carbide 200R and the Fractal Design Core 3000 look like good options. Sure they're not totally #SWAG, but nothing a couple LED Fans can't fix! :p
Rosewill RK-9100; Poker II; Magicforce 68; Planck; WASDv2 TKL; Corsair k65; minivan; tada68;
*buntu - Debian - OpenBSD
Offline engicoder
« Reply #3 on: Mon, 01 September 2014, 22:18:42 »
For something a little different, take a look at the Corsair Carbide Air 540
Its a ATX compatible cube style case so its short but wide.
« Reply #4 on: Mon, 01 September 2014, 22:19:37 »
So much wasted space in that case though.
Offline The Mad Professor
  • Ex Scientia, Rabies
« Reply #5 on: Mon, 01 September 2014, 22:25:24 »
Given that it's designed for maximum airflow, I believe that's a feature.
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #6 on: Mon, 01 September 2014, 22:26:43 »
Lian li ;)
Offline katushkin
  • Just the guy
« Reply #7 on: Mon, 01 September 2014, 22:26:58 »
I can't find any Lian Li cases in the UK that aren't either Micro ATX or stupidly expensive :( But thanks though.
Yeah, It's the full tower Phantom. An absolute beast.
Those two do look pretty much exactly what I'm looking for. Both about £50 and should be just enough for what I need. I don't think the missus will be happy me ordering another PC case, but I need to do some maint on the inside of my old rig anyway and this would be the perfect excuse.
I was thinking of something a different shape. I like the look of short, stocky cases, but like nubb said, there would be a lot of empty space in there, and I'm looking to downsize rather than just change the look, and I'm not too worried about airflow
Offline Novus
  • Mondai nothing~
« Reply #8 on: Mon, 01 September 2014, 22:31:01 »
When you say downsize - Is the weight of the case itself an issue for you?
Offline Badwrench
« Reply #9 on: Mon, 01 September 2014, 22:31:26 »
Oops, didn't notice the UK location.  I have used both the 200R and the Fractal 3000 and much prefer the Corsair of the 2.  The Fractal is decent, but it feels flimsy compared to the 200R.
Offline katushkin
  • Just the guy
« Reply #10 on: Mon, 01 September 2014, 22:40:19 »
I might have to measure my 6950... If it's too big for these cases then I may have to either suck it up with the huge case or go for a full upgrade (smaller mobo, GPU, new CPU) as I'm not sure how well new GPUs will work with my old mobo.
Sigh, I can see my money just floating away...
Offline FrostyToast
  • Litshoard
« Reply #11 on: Mon, 01 September 2014, 22:52:35 »
Node 804 gives you sufficient space to work in, lots of fan mounts and storage bays. It also has noise dampening material and isn't a bad looker either
Quote from: elton5354
Offline katushkin
  • Just the guy
« Reply #12 on: Mon, 01 September 2014, 22:56:18 »
Oooo that's pretty....
That is REALLY nice. It fits GPUs up to 320mm long.
ITS ONLY MICRO OR MINI ATX D: GRRRRRRR
Edit 2: I'm frustrated at not being able to downsize this enough. I'm going to lock this until I can justify spending more money. Thanks for all your help guys.
« Last Edit: Mon, 01 September 2014, 23:05:11 by katushkin »
