Author Topic: Filco Majestouch II Tenkeyless Cherry MX Brown - W Keycap  (Read 1780 times)
Offline causmos
« on: Wed, 03 September 2014, 18:16:53 »
Hello, I remember that this was an excellent site for anything keyboard related. I have an odd issue.
I play a lot of competitive counterstrike, and I have recently just had this problem. Holding W is essential to run forward in most games (as most of you know). When I lift my finger of the w key after holding it for a certain period of time it comes off. I tried another keycap in place of the w but it still keeps happening. What are my options since it seems to be the switch and not the key itself? Are there any recommended solutions? Perhaps someone on here has experienced this.
Any help would be appreciated. Thanks.
Offline Grendel
Re: Filco Majestouch II Tenkeyless Cherry MX Brown - W Keycap
« Reply #1 on: Wed, 03 September 2014, 18:27:52 »
Try sticking a small patch of scotch tape (5x5mm) on top of the stem before putting the keycap on again. Should tighten things up.
- I'm game !
