Author Topic: Will this set fit my ANSI Poker 2  (Read 2202 times)
Offline tobie
« on: Mon, 08 September 2014, 16:31:30 »
http://www.overclockers.co.uk/showproduct.php?prodid=KB-124-DK&groupid=702&catid=23&subcat=2455
I'm aware this is an ISO layout but I'm wondering as the Poker is a 60% if there would be enough to fit?
If not can you suggest a blank set which will fit (and will get to the UK soon).
Thanks a lot, I'm new to this stuff so please have some patience!
Offline Vibex
  • Love y'all
Re: Will this set fit my ANSI Poker 2
« Reply #1 on: Mon, 08 September 2014, 16:33:06 »
It will not fit, you would be missing an enter,  \,  and left shift key.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #2 on: Mon, 08 September 2014, 16:57:40 »
Blank white pbt ansi ducky caps pop up on massdrop every now and then. You can make an account and receive the newsletters to be notified when it is available again.
Offline Oobly
Buying more keycaps,
it really hacks my wallet,
but I must have them.
