Author Topic: Wireless Keyboard with Encryption?  (Read 1449 times)
Offline PointyFox
« on: Mon, 08 September 2014, 20:55:09 »
Are there any good wireless keyboards with encryption out there?  Especially if they also work with a mouse like Logitech does with their Unifying Receiver.
Also is there anything I can get to make existing keyboards/mice wireless?  I could make something but I don't have the time.
Offline Flyersfan1
  • Hi!
Re: Wireless Keyboard with Encryption?
« Reply #1 on: Mon, 08 September 2014, 20:59:15 »
This might interest you.  Hope it helps!
http://matias.ca/securepro/pc/
Quote from: Photekq
Offline SonOfSonOfSpock
« Reply #3 on: Mon, 08 September 2014, 23:41:10 »
The Matias has mechanical switches, so, yes it's better. I have a wired version and like it a lot.
Offline PointyFox
« Reply #4 on: Mon, 08 September 2014, 23:52:54 »
They may be mechanical, but how do they feel?  I prefer (good) rubber dome switches over most mechanical ones. I've never tried one of those Matias switches.
« Reply #5 on: Wed, 10 September 2014, 00:57:20 »
They have a very noticeable tactile bump at the top of the key stroke. The bottom out is slightly cushioned. They're really quiet compared to other mechanical switches. It takes a medium amount of force to activate, so it's a little heavier than Cherry blue, brown, and red switches, but it's less than cherry blacks.
What is it you liike about good rubber domes over the mechanical boards you've tried?
Offline PointyFox
« Reply #6 on: Wed, 10 September 2014, 21:33:16 »
I like the actuation point close to the top and heavier keys with smooth travel, so it sounds like I may like those.  Are single switches available for me to test?  I think I saw some in a Massdrop a while ago.
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Thu, 11 September 2014, 03:07:32 »
7bit sells them.
« Reply #8 on: Thu, 11 September 2014, 23:59:12 »
Yes, it does sound like you might like them. mechanicalkeyboards.com sells them in 5 packs for both varieties.
Quiet http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=480
Clicky http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=483
I'm not sure if many places sell key caps to use with the switches. I know Signature Plastics has some blanks with Alps mounts. You could also try contacting Matias directly. Edgar Matias seems like a nice guy and even posts here on Geekhack.
There is also ebay for old Alps keyboards. I'm not well versed in those, so I don't know if the less than $30 Alps boards would be a good tester for the world of Alps or not.
