Author Topic: Is it possible to switch springs on QWERKEYS 8 Switch Tester V2 ?  (Read 2699 times)
Offline acidtrip69
« on: Mon, 15 September 2014, 21:09:06 »
Hello members. I'm going to buy a QWER Key 8 switch tester V2 very soon, and i wanted to know if i could switch the springs in the switches super simple ? I wanted to get 8 springs in different weights like for example
8 in 55g
8 in 58g
8 in 60g
8 in 62g
8 in 65g
8 in 68g
i want to know whats the right switch in the right weight for me. so when i do build my mech keyboard i want it right for me i don't just want to guess in thinking what might be right for me.
Offline GL1TCH3D
Re: Is it possible to switch springs on QWERKEYS 8 Switch Tester V2 ?
« Reply #1 on: Mon, 15 September 2014, 22:43:03 »
If you already have the springs try the max keyboard one. The switches aren't soldered onto anything and pop out easily for an easy disassembly of switches
Offline acidtrip69
« Reply #2 on: Mon, 15 September 2014, 22:58:50 »
I don't have the springs yet but i can get some and i don't have the max tester. i wanted a 8 switch tester.
Offline GL1TCH3D
« Reply #3 on: Mon, 15 September 2014, 23:25:18 »
The max keyboards one is 8 switch as well?
I have one sitting on my desk with clear, red, black, grey, blue, green, white and brown switches.
« Reply #4 on: Mon, 15 September 2014, 23:29:55 »
QWER tester V1 was just a metal plate with plastic legs - I believe V2 is the same, just bigger.
Offline acidtrip69
« Reply #5 on: Mon, 15 September 2014, 23:35:46 »
i only knew about the 4 and 6 switch testers. I will also like to tell the truth and say i like the looks of the qwer keys tester more ^_^
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6 on: Mon, 15 September 2014, 23:41:02 »
You can. I have a QWER8 right here next to me that I got for free a little while back. You can pop the switches out of the QWER8 'case' and you can easily swap springs if you have the right tools for it.
