Author Topic: Good 60% with a built in USB hub?  (Read 3629 times)
Offline halfkiller
« on: Fri, 19 September 2014, 12:10:54 »
Does such a keyboard exist?  Just picked up a winbook tablet and it has a full size USB port and a 60% would be perfect for travel -  one with a built in USB port (not pass through)  would be ideal.
I know I could Google it,  but the fine people on geekhack.org tend to be the most knowledgeable when it comes to keyboards :).
Offline bazh
Re: Good 60% with a built in USB hub?
« Reply #1 on: Fri, 19 September 2014, 13:09:08 »
HHKB Pro2
HHKB Pro2 white
Newbie again
Offline AKmalamute
  • HHKB Scrub
« Reply #2 on: Fri, 19 September 2014, 13:14:39 »
HHKB Pro2
The HHKB-lite2 has a hub, too -- and dedicated arrow keys. Just no keyswitches (rubber dome, but very nice for it).
built in hubs are an oddity in nice keyboards; you might have to ad-lib in this wise:
  • get a 6" USB cord
  • get a 4-port hub
  • get an extension USB cord of the needful length
Then you'd plug the extension cord into the computer, the hub into that, and set it next to the keyboard because you've got a very short cord going from keyboard to hub.
Of course, that assumes you have something of a desk to set the hub on. Taping the hub to the keyboard would look just a bit tacky but would remove the dangling-weight problem.
HHKB-lite2, Dvorak user
Offline saturnotaku
« Reply #3 on: Fri, 19 September 2014, 13:39:45 »
HHKB Pro 2 would be the only "mechanical" keyboard that fits the bill. It's expensive, though, so you'll have to weigh the cost versus simply carrying around a USB hub and using a cheaper keyboard.
« Reply #4 on: Fri, 19 September 2014, 13:57:12 »
tex yoda
http://geekhack.org/index.php?topic=58458.0
« Last Edit: Fri, 19 September 2014, 13:59:35 by dorkvader »
Offline OverKill
« Reply #5 on: Fri, 19 September 2014, 14:05:12 »
Don't forget the Maitas Quiet Pro
http://matias.ca/miniquietpro/pc/
They have a few products with a USB hub.
http://matias.ca/products/
Offline saturnotaku
« Reply #6 on: Fri, 19 September 2014, 14:17:19 »
tex yoda
Though it fits the criteria, that keyboard is hard to find. Only place I've seen it is on Massdrop.
Hadn't thought about that one. Good catch.
Offline halfkiller
« Reply #7 on: Fri, 19 September 2014, 16:39:57 »
MMMM more choices than I thought. I just picked up a 4 port USB port, but one built into the keyboard would equal one less thing to carry around. Hm.... decisions decisions decisions .....  The HHK is a topre esc board right ?
