Author Topic: Is there IBM Model M in Dvorak ?  (Read 3392 times)
Offline acidtrip69
« on: Fri, 26 September 2014, 01:17:18 »
Like the title in this thread. Is there IBM Model M keyboards in Dvorak ? sorry if this has been answered before but i really don't have any info or knowledge in this subject. How much is it for a normal IBM model m for say mid 80's to early 90's ? What would i need to get one to work with todays pc's and were would i find one that would be guaranteed to work ? say something was broken with it and i could tell them and i could just send back get my cash back or they can just replace it ?
Offline False_Dmitry_II
Re: Is there IBM Model M in Dvorak ?
« Reply #1 on: Fri, 26 September 2014, 01:51:14 »
You just move the keys. Works perfectly on Buckling Spring keyboards, generally not any others.
Offline acidtrip69
« Reply #2 on: Fri, 26 September 2014, 02:10:40 »
But if you only move the keycaps when you press the keycap down doesn't it still think its in its default mode ? Just because i move a keycap to another spot on the keyboard doesn't mean the keyboards knows were you move the keycaps to. It needs software or some hardware actuated by the user for it know i think. Thats whats makes sense to me any way.
Offline yasuo
  • spanengan puyeng newbie
« Reply #3 on: Fri, 26 September 2014, 02:12:32 »
yup Control panel>change keyboard or other input :)
« Last Edit: Fri, 26 September 2014, 02:20:26 by yasuo »
Logitech MK220 Colemak DH
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Fri, 26 September 2014, 07:57:12 »
Unicomp takes custom orders and they list Dvorak among available layouts, but I have no idea, if it's just keycaps, or a truly DSK keyboard (like they have Mac/Unix models).
Otherwise, Teensy is your best bet.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5 on: Fri, 26 September 2014, 08:04:40 »
No need for teensy with M's or F's unless you need it in the hardware because you switch computers often.  M and F caps are all the same profile and work in any row, so you can change the keys around with no issue.  Also Dvorak is supported by all major OS's.  Just need to find the options.  Just google it for your OS.  I did it on my Das and kept the keys in the qwerty placement just to try it for a few minutes.  I even had hot keys setup to switch.  I think I used Ctrl+Shift+1 for qwerty and Ctrl+Shift+2 for dvorak.  Though I don't remember how I setup the hot keys or if I even did this with win 7 or 8.
Offline davkol
« Reply #6 on: Fri, 26 September 2014, 08:31:12 »
It's always better to have such layout in hardware for entering passwords (bootloader, encrypted system partition), dealing with remote/virtualized systems or just in case rights for changing the software layout aren't available.
The F&J nibs are annoying, when in incorrect positions.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Fri, 26 September 2014, 08:56:36 »
Sand them off?
Offline davkol
« Reply #8 on: Fri, 26 September 2014, 09:41:27 »
…and glue new nibs on U & H? #ghetto
« Reply #9 on: Fri, 26 September 2014, 10:48:59 »
paging dorkvader
he uses a model M, and it's Dvorak
« Reply #10 on: Fri, 26 September 2014, 11:55:28 »
terminal boards like the 122key model F do not have those nibs. I never found them to be annoying in the wrong positions though. (before I had a model F)
paging dorkvader
Bro, please. I use the model F. That M is for when I feel bad that it's sitting in the corner all alone. Or for work.
Anyway, I use the dvorak language layout in linux and either hardware dvorak (for typing) or qwerty (for gaming) in windows.
