Author Topic: Which Filco tenkeyless?  (Read 2398 times)
Offline phototristan
    • https://www.youtube.com/phototristan
« on: Sun, 21 June 2009, 08:34:05 »
Anyone know which Filco tenkeyless keyboard has the best clicky feel and sound similar to a Model M?
http://www.elitekeyboards.com/products.php?lang=en
Offline kyamei
« Reply #1 on: Sun, 21 June 2009, 08:38:13 »
FKBN87MC -- The model with blue Cherry switches.
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
« Reply #2 on: Sun, 21 June 2009, 08:43:42 »
Thanks. How come they don't make a 104 key one with blue Cherry switches? Or do they?
« Last Edit: Sun, 21 June 2009, 08:46:50 by phototristan »
« Reply #3 on: Sun, 21 June 2009, 08:44:38 »
Whoops, I guess they do, it's a 'special edition'- http://www.elitekeyboards.com/products.php?pid=fkbn87mceb
Offline lam47
« Reply #4 on: Sun, 21 June 2009, 08:54:56 »
I think you would find the Zero most like an IBM. It uses white Alps which are louder than the Blues.
Blue switches do not feel or sound at all like a model M. They are far too soft and the sound is too small and high pitched.
The Alps will be closest for sure.
http://www.elitekeyboards.com/products.php?sub=filco_keyboards,majestouch_87key&pid=fkbn87zeb
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
« Reply #5 on: Sun, 21 June 2009, 08:59:56 »
Thanks for the info.
Quote from: lam47;98054
Offline kyamei
« Reply #6 on: Sun, 21 June 2009, 09:19:30 »
Oh yea, forgot there is a white alps version.  Was having too much fun typing that on my new toy.
+1 lam's suggestion.
Offline ch_123
« Reply #7 on: Sun, 21 June 2009, 09:56:15 »
There are at least two. Bigpook ended up swapping out the white XMs for real blacks from a Dell. Another guy swapped them out with blues as far as I remember.
Offline bigpook
« Reply #8 on: Sun, 21 June 2009, 10:17:00 »
I think that was billm that swapped them out for the blue alps. I am still using the filco with black alps. I feel like some kind of heretic for saying this, but the black alps are fricking sweet.
« Reply #9 on: Sun, 21 June 2009, 10:24:43 »
I can't because Metadot ended up replacing it under warranty for me and I sold the new one.
Quote from: ripster;98057
Phototristan, check here for 104 key info.
Also, can you take a photo sometime of your Das with the faded lettering and post it in that thread?  It's a common complaint but I've never seen a picture and since you're a photographer....
Offline patrickgeekhack
« Reply #10 on: Sun, 21 June 2009, 10:27:54 »
I, too, believe that Cherry MX Blue are completely different from the Model M. They offer a good tactile feeling and sound, but they are much much lighter than the Buckling spring, and way quieter (in my opinion).
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
« Reply #11 on: Sun, 21 June 2009, 10:34:45 »
I guess nothing really beats buckling springs! The Unicomps or Model Ms are durable too. Those keyscaps don't wear down nor start looking shiny like both the Das and Filcos.
Quote from: webwit;98073
I also think leavy sound and feeling is very different from BS. Closest would be the simplified Alps.
« Last Edit: Sun, 21 June 2009, 10:42:05 by phototristan »
Offline MsKeyboard
« Reply #12 on: Sun, 21 June 2009, 10:50:56 »
Aren't you feeling spunky today!
Happy Fathers Day everyone!
Offline ch_123
« Reply #13 on: Sun, 21 June 2009, 10:57:07 »
Quote from: phototristan;98075
You should really try out a PC/AT Model F, not a Filco tenkeyless, but it has a nicer feel and sound than a Model M (IMHO)
Come to the dark side, we have capacitive switches!
Pic
« Last Edit: Sun, 21 June 2009, 11:20:09 by ch_123 »
