Author Topic: Semi-pro needs a new mouse / Low sensitivity (IE 3.0 Fan)  (Read 24815 times)
Offline pharaoh
Re: Semi-pro needs a new mouse / Low sensitivity (IE 3.0 Fan)
« Reply #50 on: Sat, 18 October 2014, 18:34:56 »
If you're happy with the ec1, stick with an ec1, just get a new one.  Running your mouse at 1000hz instead of 500hz should eliminate that skipping.  As far as your other options, the sensei and the FK are the same shape essentially, so it'll probably feel a bit small.  You're not going to find a mouse with a lod similar to zowie's.  Switching from a ec1 to a deathadder will be a nightmare.  The DA and ec1 have the same shape, so if you do want one, and want to avoid that pesky synapse, 3.5g is probably your best bet.
I normally ignore this forum, but this thread was at the top so I thought I'd drop in.
I played ESEA Invite TF2 for 3 seasons as a medic
what team / seasons?
hhkb type-s| jd40 | jd45 | keycool87
Offline cookie
    • Deskthority
« Reply #51 on: Mon, 20 October 2014, 03:41:09 »
The Kana looks nice but Steelseries hasn't a good build quality for my taste. My Sensei was way to flimsy for my taste.
It looks bad ass tho! I don't know if one thumb button would be enough for me. I usually have reload on one and push to talk on the other (csgo)
Offline Oobly
« Reply #52 on: Wed, 22 October 2014, 06:36:32 »
Refurbished IE 3.0?
Give sprayable PlastiDip a try.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
