Author Topic: Poker II Backlight Issue  (Read 1225 times)
Offline Ripudio
« on: Thu, 02 October 2014, 12:50:29 »
Not sure if this is the right place, but I just got a new Poker II yesterday and noticed that when I shut down my computer, the backlight turns on, even if it was set to off when the computer was on. Is it just me or is this a normal thing/is there a way to fix it? Thanks!
Offline RED-404
Re: Poker II Backlight Issue
« Reply #1 on: Thu, 02 October 2014, 13:05:50 »
Yeah, you either have to disable keyboard power-on or, more likely, need to disable the USB charging on your mobo "GIGABYTE ON/OFF Charge, ASUS Ai Charger, ect" or possibly just use a different USB port. It may also be a powered USB hub causing the problem.
Offline Ripudio
« Reply #2 on: Thu, 02 October 2014, 14:48:23 »
Thanks Red, I'll try that when I get home. Somehow my old keyboard (G710+) never did it, who knows.
