Author Topic: Looking for a 60% or tenkeyless with a programmable key layer  (Read 2565 times)
Offline ashcraft
« on: Fri, 03 October 2014, 16:01:46 »
I looked at the ducky mini and liked it for everything it offered, I'm still interested in it but I would hopefully like to find something with programmable keys. Can anyone give me some good options? My spending limit is 140$
I live in the US
« Last Edit: Fri, 03 October 2014, 16:04:44 by ashcraft »
Offline kitsun8
  • In need of some cash
Re: Looking for a 60% or tenkeyless with a programmable key layer
« Reply #1 on: Fri, 03 October 2014, 17:22:58 »
For programmable go the poker 2 since it has really good programmable layer
« Reply #2 on: Fri, 03 October 2014, 18:01:11 »
poker 2 = ducky mini
they're exactly the same except for the look and the branding.
Offline kitsun8
« Reply #3 on: Fri, 03 October 2014, 20:47:19 »
Oh really? TIL ;D i always thought they had different programmable layers. In that case its whichever looks nice haha
Offline Britney Spears
« Reply #4 on: Sat, 04 October 2014, 01:41:35 »
Afaik only the Ducky Mini V1 is identical to the Poker II. The Ducky Mini V2 is a different beast altogether.
Ducky Mini V1
Ducky Mini V2
Offline Oobly
« Reply #5 on: Sat, 04 October 2014, 06:40:32 »
Poker 2, QFR and a Frosty Flake, Phantom, any of GON's customs (but these won't fit your budget unless you only buy a PCB and get the rest of the parts from some other board.), hand wired board made with a plate from an existing board and a Teensy. Least work is a Poker 2 or a completed Phantom.
A bit more way out is an IBM SSK with a programmable converter or replacement controller.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline ashcraft
« Reply #6 on: Sat, 04 October 2014, 07:21:01 »
Thanks for the reply!
I know it isn't programmable, but it looks promissing for everything else I'm looking for. Is the KUL es87 a good keyboard? If not is there any other tenkeyless you could recommend?
I also found the quickfire tk, can any owners recommend it over the kul?
« Last Edit: Sat, 04 October 2014, 07:36:08 by ashcraft »
