Author Topic: Honeywell 101RX, more info please...  (Read 5081 times)
Offline Cherry1990
« on: Sat, 04 October 2014, 18:03:42 »
Today I found an old keyboard in my garage (I stored it 15 years ago or more, I don't remember...). It was a gift from a co-worker...
I never used it until now. It is a rubber dome keyboard. It "sounds" strange to me, it is very different from my Cherry G80-3000 MX Black.
I would like to know more about this type of keyboard, its typing quality etc. It is very silent and seems less noisy than Cherry MX Black. Probably also the key force is a bit less, I cannot measure it.
It is branded Honeywell-Bull because it was sold in Europe but I think it is like the others Honeywell keyboards. THe connector is the normal PS/2 and the cable is detachable.
Does anyone have more information on these keyboards?
Thank you! ;)
P.S.: A couple of photos taken with my mobile phone...
PBT forever!
Offline Cherry1990
Re: Honeywell 101RX, more info please...
« Reply #1 on: Sat, 04 October 2014, 19:20:49 »
P.P.S.: I forgot some things: keycaps are not doubleshot, they are also thin. "Alt" labels have different colour. I don't know it they are ABS or PBT or if they are dye-sub or laser etched or something other...
PBT forever!
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Sat, 04 October 2014, 21:16:30 »
keyboard is definitely a rubber dome (see attached)
caps have not yellowed like the rest of the board, but look lasered ABS to me?
alt caps are green legend.........and it is ANSI :thumb:
can't tell if it has a metal plate or not, but still pretty decent keyboard
i would retrobrite the case and give the caps a decent denture tab soak and it would look like a new one
« Last Edit: Sat, 04 October 2014, 21:18:26 by terrpn »
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Sat, 04 October 2014, 21:29:04 »
i am not sure, but maybe someone who knows better than me can clarify............because only the board has yellowed and none of the caps i'm thinking they might be PBT?
Offline Cherry1990
« Reply #4 on: Sun, 05 October 2014, 06:12:45 »
Thank you terrpn!
I think it is without metal plate, because I can warp it easily. I took my old Cherry G81-3000 HAU and it is far better than this Honeywell...
Me too cannont undestand why body is so yellow and keycaps still white (a bit grey for dust but certainly not soo yellow like the chassis).
Keycaps are like the one you showed.
I think this is a low quality keyboard, not mechanical, less satisfactory than my old Cherry G81-3000 HAU, with harder keys. Strange thing is that is less fatiguing than my last Cherry (G80-3000LPM) that is a real mechanical board... :eek:
Is this the difference between Topre keyboards and real mechanical keyboards?!? :eek: :eek: :eek:
PBT forever!
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #5 on: Sun, 05 October 2014, 08:34:50 »
Yellowing: it probably is as terrpn suggests — ABS case, and non-ABS keycaps (e.g. PBT), so only the ABS case has yellowed. What you do see is keyboards where only the space bar has yellowed, because it's the one ABS keycap (as PBT tends to warp after being moulded and with such a large key this is far more apparent — Topre for example use ABS just for the space bar).
Topre: is what the difference between Topre and "real" mechanical keyboards?
Bore Awards
Offline Cherry1990
« Reply #6 on: Sun, 05 October 2014, 10:31:31 »
The space bar is not more yellow than other keycaps... Also on my old 1990's Cherry the chassis is more yellow than keycaps (double shot), probably they are made with a low quality ABS...
After one day of typing I must admit that I put back my MX Black Cherry G80-3000 keyboard... It is better! The Honeywell will come back to my garage... :(
If it is a question for me, I don't know the answer... I am trying to understand if I can enjoy or not a Topre keyboard, before buy it... I know, I will search again on the web... :-[
PBT forever!
  • RIP
    • Boring twaddle
« Reply #7 on: Sun, 05 October 2014, 11:47:18 »
You said: "Is this the difference between Topre keyboards and real mechanical keyboards?!?".
My question is: is what the difference?
Topre keyboards use rubber domes, so they're not comparable to metal-contact microswitch designs such as Alps SKCL/SKCM or Cherry MX. Topre's Realforce line does use a metal plate to mount the slider guides, so they're heavy and solid (though my 105UB has a bit of flex and creak to it).
Whether there's another rubber dome keyboard that feels approximately like Topre, I don't know; the closest I've found is the Dell KB1421, but the Realforce is far better made. Topre domes are an interesting design, and the tactile event is stretched, giving an unusual feel.
Bore Awards
Offline Cherry1990
« Reply #8 on: Sun, 05 October 2014, 15:51:52 »
Never tried a Topre. I was only asking (especially to myself) if this old keyboard can be, more or less, like a Topre... But, if nothing is like a Topre, the matter is closed. If Topre sells keyboards at 300 EUR or more yes, probably, they are really different from all other keyboards... ;)
PBT forever!
