Author Topic: (ebay) NIB IBM 6112884 and 6113442 $25 each  (Read 8834 times)
Offline Daspartic
  • IBM is love IBM is life
« Last Edit: Wed, 08 October 2014, 23:12:42 by Daspartic »
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Re: (ebay) NIB IBM 6112884 and 6113442 $25 each
« Reply #1 on: Thu, 09 October 2014, 09:52:41 »
These are very high quality and completely worth the price. They ping loudly though!
You have two options to use on PC. The first (what I did) is to replace the microcontroller with a teensy. The second (more recently developed) is to convert the protocol (these are apparently the same as the 4704 keyboard protocol and use the same cable). Thanks to soarer and Hasu for this.
Offline Daspartic
« Reply #2 on: Thu, 09 October 2014, 21:32:46 »
I recently picked up a wang 725-5971 with salmon alps and I really dig the feel and sound of alps switches.  I can't wait to try these vintage tee mount alps.
Thanks for the info  Dorkvader,  I'll probably use the same method you did and go with the teensy.  Also, thanks to Soarer and Hasu for enabling us to use these keyboards.
Offline Arcoril
« Reply #3 on: Thu, 09 October 2014, 21:42:19 »
Thank you for the heads up on these boards! Picked one up to see what all the fuss is about. And I think that it's a beautiful looking board too.
Offline Daspartic
« Reply #4 on: Fri, 10 October 2014, 00:01:25 »
You're welcome Arcoril, hope you enjoy it!
Offline thecolorblind1
« Reply #5 on: Mon, 30 May 2016, 17:12:33 »
I know this thread is a bit old, but you wouldn't by chance have a guide showing how to replace the microcontroller with a teensy? I recently picked one up and would like to give it a go, though I have zero experience with it.
Offline ThoughtArtist
« Reply #6 on: Tue, 31 May 2016, 12:54:51 »
When I first tried mine I thought "Holy PING Batman!"
« Reply #7 on: Tue, 31 May 2016, 13:02:44 »
I think this is it.
https://geekhack.org/index.php?topic=50437.msg1193047.msg#1193047
Offline yomammary
« Reply #8 on: Tue, 31 May 2016, 16:11:06 »
Only 50$ shipping to Canada, no biggie. :p
RF 87u 55g | Leeku 1800
« Reply #9 on: Tue, 31 May 2016, 16:14:03 »
Are these just standard Alps stems?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Tue, 31 May 2016, 16:24:28 »
Nope, tee mount.
« Reply #11 on: Tue, 31 May 2016, 17:08:43 »
I think this is it.
You rock, man.  :thumb:
