Author Topic: buckling spring with cherry on top  (Read 21806 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: buckling spring with cherry on top
« Reply #50 on: Sat, 25 October 2014, 22:10:41 »
If this project comes to fruition I would put Toxic on the bigfoot.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #51 on: Sun, 26 October 2014, 01:55:37 »
I doubt we can have all keys adapted (right shift is pretty problematic for example), but 1u should work.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #52 on: Sun, 26 October 2014, 14:28:34 »
Ah, then maybe only for novelties.
Offline 0100010
  • Not Sure
« Reply #53 on: Sun, 26 October 2014, 15:34:25 »
I wanted to thank madhias who volunteered his Model M to the cause. I received the keyboard few days ago and I'm ready to 3d print the beta 1 of the slider :) Crossing fingers, let me know if you spot any issue.
Do you think that 'nub' on the bottom is sufficient to capture the top of the spring, from rest and through the buckle?
« Reply #54 on: Sun, 26 October 2014, 16:28:20 »
I think so.
If you look at a normal IBM cap it's not much bigger, and the spring is always in compression, so there's really nowhere else for it to go. We'll see once the prototypes arrive.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #55 on: Sun, 26 October 2014, 17:51:53 »
my spring nub/holder is actually bigger than the original one... so should work.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #56 on: Wed, 05 November 2014, 09:50:40 »
They arrived!
Offline geniekid
« Reply #57 on: Wed, 05 November 2014, 12:07:43 »
WELL?!!?!?!?!?!?!  :p
Offline 0100010
  • Not Sure
« Reply #58 on: Wed, 05 November 2014, 14:22:58 »
It's......... beautiful!!!!
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #59 on: Wed, 05 November 2014, 16:57:36 »
I need to make more changes... gosh this prototyping phase is expensive :P
Offline 0100010
  • Not Sure
« Reply #60 on: Wed, 05 November 2014, 17:07:53 »
Curious as to what is 'wrong' with them currently.
« Reply #61 on: Wed, 05 November 2014, 17:31:00 »
These look great, I need some.
« Reply #62 on: Wed, 05 November 2014, 20:53:18 »
is there enough of a stem for the cherry cap to grip?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #63 on: Thu, 06 November 2014, 02:06:22 »
yeah the stem works. the problem is that for some reasons the spring doesn't "click". There's very little room for error. Also 3d material is pretty rough while the slider needs to be smooth.
more testing needed.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #64 on: Thu, 06 November 2014, 08:46:38 »
Not certain what aspects of your design you're keying on, but I believe the angle of the spring mount point on the underside of the key has to a very specific angle for the buckling action to work properly.
Offline 0100010
  • Not Sure
« Reply #65 on: Thu, 06 November 2014, 09:06:30 »
↑ this x 100
Also the bottom 'lips' of the BS stem need to be very thin to provide clearance around the base of the spring.  As a slightly related example, sometimes with new stems from Unicomp there is some flash there which you can feel binding on the spring towards the bottom of the stroke which can be removed with a razor/exacto.
Sometimes when inserting the stem in the barrel, you have to orient the whole assembly "up" or "down" - depending on what direction the spring is 'pointing' in the barrel when it is in a vertical position.  I find for springs that rest towards the 'bottom' of the barrel, you need the orient the assembly so the spring falls towards the top of the barrel so that the stem and spring interface properly.
« Reply #66 on: Thu, 06 November 2014, 11:09:49 »
I think it's not the angle, but the position. The two ends of the spring are held at different locations, eccentrically loading it. For a slightly different feel, you could move it forward (toward the front of the KB) a bit and that would cause it to buckle for sure.
I agree with 0100010 about the inserting into barrels part. I actually tip the whole keyboard forward to make sure all the springs are rocked forward so I can insert the keycaps the proper way.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #67 on: Thu, 06 November 2014, 12:23:19 »
I believe the problem is in the spot where the springs lays. It is probably too deep (or not deep enough). That is the only measurement that I couldn't take.
« Reply #68 on: Thu, 06 November 2014, 13:30:50 »
you mean how big the bump is? I will measure one now.
FWIW I do not think that to be an issue. To test this I sued a pin and something hard (a screwdriver) which poked out much further than normal. The spring still buckled.
But if the "bump" is too deep you will run into an issue if it's not for forward enough. I believe the eccentric loading of the spring causes it to buckle reliably.
« Last Edit: Thu, 06 November 2014, 13:46:41 by dorkvader »
Offline kalrand
« Reply #69 on: Sun, 07 December 2014, 16:46:08 »
I'm kind of curious how this is progressing...
My 122 key Model M was born on July 25th, 1988.
« Reply #70 on: Sun, 07 December 2014, 16:50:25 »
Me too. It gets a lot more conversation on Deskthority.
"We�re making money like we�ve never made before. They�ll say: President Trump is bragging about all the money they're making while people are suffering at the pump.
I don�t give a damn. We�re making a freaking fortune.
- D Trump 2026-10-24
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #71 on: Sun, 07 December 2014, 17:06:20 »
I'm waiting for the second prototype.
Offline dark_samus
« Reply #72 on: Fri, 27 February 2015, 11:23:05 »
Looks like just what I want.... how long do you think until these are available for 3d printing or somewhere I could buy a set?
Offline mattlach
« Reply #73 on: Thu, 31 January 2019, 11:32:56 »
Apologies for resurrecting a very old thread, but did this effort die off, or did it just continue in a different thread somewhere?
I had considered trying to model and 3d print something like this myself, but some googling suggested it had already been done, which lead me here.
Very curious.
IBM Beamspring > IBM Model F > IBM Model M > All Cherry MX, Alps and Topre > Rubber Dome & Scissor Switches.
