Author Topic: Green or blue switches?  (Read 5698 times)
Offline Mrupton
« on: Sun, 12 October 2014, 19:07:23 »
I realize its completely personal reference but which do you prefer and why? i've only used browns, but im going to be switching to either blue or greens.
Sadly I have no store near me to test any out and I dont see the point in buying a sampler for 1/5th of the keyboard id buy.
Would love to hear some opinions!
Re: Green or blue switches?
« Reply #1 on: Sun, 12 October 2014, 19:14:56 »
Green.
Blues are too light :p
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #2 on: Sun, 12 October 2014, 19:19:40 »
Blues, for that sweet, clickity click sensation
Offline epzy
  • HHKB Fiend
  • ded
« Reply #3 on: Sun, 12 October 2014, 19:21:10 »
I prefer blues because greens are 3heavy5me.
Offline jacobolus
« Reply #4 on: Sun, 12 October 2014, 19:26:04 »
Clicky Matias switches! Or SMK “monterey” blue switches, or clicky white/blue/amber Alps, or amber Omrons, or clicky black Hi-Tek “space invaders”, or IBM buckling springs, or NEC switches, ...
Cherry clicky switches, both the blue and green varieties, are quite uninspiring.
« Reply #5 on: Sun, 12 October 2014, 19:37:02 »
If you find browns to be about stiff enough for you, probably blues would be best.
But if you find browns to be too light, then by all means try greens.
I could be wrong, but keyboards with MX green switches are not as common, and thus a bit more likely to retain their value if you decide you don't like them and want to sell the keyboard.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6 on: Sun, 12 October 2014, 19:40:52 »
lol
Offline Mrupton
« Reply #7 on: Sun, 12 October 2014, 19:45:41 »
I'm really not too sure how browns feel to me. I'm just trying to become better at typing at greater speeds. Would heavier keys make it harder to misclick letters?
« Reply #8 on: Sun, 12 October 2014, 19:57:51 »
That is also quite subjective.
I find that it does, but on the other hand you might experience fatigue in your hands and fingers due to the stiffer springs.  Many people do.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #9 on: Sun, 12 October 2014, 20:01:28 »
Greens.
I don't like clicky switches anymore though.
Offline Mrupton
« Reply #10 on: Sun, 12 October 2014, 20:09:49 »
Guess I can do what you suggested, buy it and if I dont like it can always sell it. I've typed on a blackwidow before and liked it so I imagine id like greens aswell.
I was planning on buying this (if I went with greens) http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=882 Is this a good choice?
Offline Fragil1ty
  • Abre los ojos.
« Reply #11 on: Sun, 12 October 2014, 20:46:59 »
Always baffles me when people switch to blues. But I don't know, I guess Blues over greens, not a personal fan of heavy switches.
你搞砸了
Offline Premonition
  • HHKB Elite
« Reply #12 on: Sun, 12 October 2014, 22:08:04 »
Blues are nice and comfy to type on, with a satisfying click. Greens are also 3heavy5me, it feels like I'm typing in concrete.
« Reply #13 on: Sun, 12 October 2014, 22:15:04 »
Awww they're not that bad!
Offline Rebral
« Reply #14 on: Mon, 13 October 2014, 01:00:10 »
Greens!
Though I started out with blues, I later learned that they were too light for me. I've had moments where I had trouble resetting the actuation point when I'm trying to double or even triple tap while gaming.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #15 on: Mon, 13 October 2014, 01:18:51 »
I don't know how much this means to you, but when I went to look for CM QuickFire Rapids in my local stores, one store ONLY had Green switches in stock, and 3-4 of them were all open box.
If this is your first keyboard, I highly recommend a lighter switch like blue over greens. It is not realistic to type on greens for most people. Personally I love IBM Bucking spring, and I find greens to be a lot heavier than them.
Offline Premonition
  • HHKB Elite
« Reply #16 on: Mon, 13 October 2014, 02:23:42 »
 ;D I'm exaggerating, but eh. Feels like I really have to push for every keypress, some like it and some don't, I guess!
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #17 on: Mon, 13 October 2014, 02:38:58 »
Definitely greens.
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
« Reply #18 on: Mon, 13 October 2014, 02:42:15 »
heavier the clicky switch the better
Offline Kouni
« Reply #19 on: Mon, 13 October 2014, 03:00:52 »
Greens over blues. I use browns every day, I find mx blacks too heavy for me, but when it comes to clicky switches I feel blues lack the necessary weight to give a satisying response after the click. Greens feel crisper in that sense.
Offline RickyJ
« Reply #20 on: Mon, 13 October 2014, 10:04:49 »
My ex has my blue board so I haven't typed on them in a long time, but I remember them feeling a bit rattly (especially the ones in my friend's original Black Widow).  My ghetto-greens (blue stems, clear springs) feel more positive and consistent, a huge improvement.  I'm a mechanic by day, so my fingers don't get tired from the extra spring strength.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #21 on: Mon, 13 October 2014, 10:09:47 »
I've got a blue switch board but whenever I rest my finger on the key, it registers. It might be too light for me but I guess greens might be too heavy as well.
But I'd go with the latter. Greens are awesome. Have one on my caplocks, :D
Offline Karura
  • SKidata life.
« Reply #22 on: Mon, 13 October 2014, 10:11:14 »
Honestly OP, judging from the responses in this thread, I feel we can all agree on the fact that this is very subjective. You must try for yourself to know for sure.
Offline Jokrik
« Reply #23 on: Mon, 13 October 2014, 10:24:22 »
I love greens
but when it comes to blues with 68g springs, its heaven on tuts
Offline Mrupton
« Reply #24 on: Mon, 13 October 2014, 12:06:58 »
Might go with greens first. Mechanicalkeyboards.com says they accept returns so worse case senario I return it and buy the blue verison.
Offline divito
« Reply #25 on: Mon, 13 October 2014, 13:07:26 »
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline Eszett
« Reply #26 on: Mon, 13 October 2014, 13:34:44 »
The problem is that preference depends on daytime: in the morning, when my fingers are shiftless, blues feel not too light, rather ok. In the evening, when my fingers are full of power, blues feel too light.
Offline Mrupton
« Reply #27 on: Mon, 13 October 2014, 13:43:56 »
Went to a local store and tried the black widow ultimate and the keys felt a bit light compared to my browns. Guess I should go with greens then? I'm no professional typist by any means I can only type at 60wpm. I'm just trying to improve.
Offline Hitcha
« Reply #28 on: Mon, 13 October 2014, 14:02:52 »
Greens are just better Blues. Plain and simple.
Full Metal Poker II - http://imgur.com/a/xK2Uv
Offline deci
« Reply #29 on: Mon, 13 October 2014, 14:51:45 »
Get blues in a pcb mounted board or anything that lets you open the switch without de-soldering (like a phantom) and then put korean 65g springs in them.
Those felt better than stock blue or green to me.
Offline paicrai
  • mindblank
« Reply #30 on: Mon, 13 October 2014, 17:08:36 »
Green. I don't have one though.
THE FEMINIST ILLUMINATI
Offline Gniourf
  • Good feeling of oneness with cup rubber
« Reply #31 on: Mon, 13 October 2014, 17:50:59 »
Typist here: I prefer blue. I get tired and sore fingers quicker with greens. I don't game so I can't tell anything about gaming usage.
Offline dante
« Reply #32 on: Mon, 13 October 2014, 18:58:41 »
Honestly ... Neither ... When it comes to clicky Cherry switches I like MX Whites the best but you'd have to sort through several bags of switches just to build a keyboard due to the inconsistency.  I think it's crazy MechanicalKeyboards.com continues to stock keyboards with them - I'd imagine it has to be one of the most RMA'ed switch types.
