Author Topic: DIY Holder for WASD Sampler?  (Read 1307 times)
Offline Kreation
« on: Mon, 13 October 2014, 11:25:12 »
Since Max Keyboards is out of stock on their sampler, I went ahead and bought WASD's, however since it doesn't come with a holder/stand of any sort, I'm wondering if anyone would be kind enough to measure their Max Keyboard holder and post the dimensions here. It'd make a neat project.
« Last Edit: Mon, 13 October 2014, 11:31:19 by Kreation »
Offline BlueBär
Re: DIY Holder for WASD Sampler?
« Reply #1 on: Wed, 15 October 2014, 05:43:11 »
What material do you want to make it out of?
The cutouts for the switches should be 0.551" square.
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #2 on: Wed, 15 October 2014, 19:10:09 »
Just measured the holes in mine. My digital calipers say 16mm square hole with a 1mm x 1mm overhang around the top side of the hole for the little clips to grab onto.
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
