Somehow they managed to do a white on black GMK set that flew totally under GH's radar. Really disappointed I missed out on that one, it had some awesome keys included. I'll try and find a photo, someone asked for a price check a while back.
That one was actually a Korean GB together with Korean Dolch GB, and Irisviel proxied them on EC. That set is overpriced at ~$180 considering how easily you can find NIB WoB set on eBay.
EDIT: That picture doesn't look like the set from that GB since the LED capslock and scrolllock are missing.
Correct. GMK WoB set includes 104 ANSI keys, extra 11 keys, and 3 LED windowed keys.
Its original price is about $130 USD at current exchange rate. Somewhat pricey? Correct.
After GB, some people cast a doubt on its price, and then finally it came out into the open that GB starter took no small unveiled profit personally.
Since that, his reputation got to be worse and he seems not to continue making another GMK GB because of falling his credit.
$180? Well... not a little profit(or premium)
Ryan, that is pretty interesting info. Do you know if the GB on EC also came with LED windowed caps/scroll/numlocks? I thought that was only from the Korean GB.
Correct. I explained what caps were included in GMK Dolch set from the former Korean GB.
As far as I know, Dolch-style LED windowed caps/scroll/numlocks were included in GMK Dolch set from this Korean GB and Originative only as below.
Korean GB mockup
![[IC] GMK Olivetti - R.I.P(canceled) 92327-0](https://geekhack.org/index.php?PHPSESSID=r1n554i46383tiidbb776556vp8pdukm&action=dlattach;topic=64075.0;attach=92328;image)
Originative mockup
![[IC] GMK Olivetti - R.I.P(canceled) 92329-1](https://geekhack.org/index.php?PHPSESSID=r1n554i46383tiidbb776556vp8pdukm&action=dlattach;topic=64075.0;attach=92330;image)
BTW, Unfortunately I've no idea about any GB on EC such caps are included currently.
Even later, if I may find any GB, I'll let you know it.
PS) You mean you are looking for 3 windowed caps in just Dolch color? Or any other color scheme?
If the latter, you know, now you can find several GBs here include such caps. For example, Feng's GMK Cyan set.
