Author Topic: Keyboard Suggestion  (Read 1932 times)
Offline SoullessWhale
Keyboard Suggestion
« on: Tue, 14 October 2014, 19:52:41 »
So Ive been using this old LiteOn board with complicated white alps and Ive found that the typing experience has yet to be beat by anything else I have tried. I am looking to get something new and more customize-able and want to know if anyone has any suggestions as to what switch might be comparable.
Ill probably want something cherry I assume too since the caps are so readily available compared to the others.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Keyboard Suggestion
« Reply #1 on: Tue, 14 October 2014, 19:59:12 »
Mx green would probably be the closest, both heavy and clicky
Offline eth0s
  • Peace & Love
« Reply #2 on: Tue, 14 October 2014, 20:04:50 »
Customize-able how?  You want to change the function of the keys?  Or you just want to change color of the the keycaps?  Also do you want a Cherry brand keyboard?  Or are you looking for any keyboard with Cherry switches?  I ask these questions, to raise your consciousness.  But if you want heavy and clicky, the only real choices are Cherry MX Green switches, and/or maybe a vintage IBM buckling-spring keyboard.  I can't remember the actuation force on a BS switch, but it's a lot.  Also they make an audible report that cannot be missed.  You can feel it in your fingers in fact, IIRC.
« Reply #3 on: Tue, 14 October 2014, 20:39:57 »
You will have trouble improving on complicated white Alps unless you are desperate for something lighter.
If the tactile click is not satisfying enough, then buckling springs can't be beat.
- D Trump 2026-10-24
Offline Tony
« Reply #4 on: Tue, 14 October 2014, 22:42:26 »
Blue switch provides very good typing feel if you can stand the sound.
Offline ComradeSniper
  • HHKB Pro
« Reply #5 on: Tue, 14 October 2014, 22:47:44 »
No MX switch will match the tactility of clicky alps. Like fohat said, buckling spring might be a good choice.
Topre could be interesting because it's a completely different feel, but customization is lacking.
Offline BlueBär
« Reply #6 on: Wed, 15 October 2014, 05:31:01 »
It was really disappointing for me to type on MX Blues after typing on some nice and clicky Alps (even if it's just white Alps).
I would say get a buckling spring board, possibly a Model F, but those are not really customizable. If you want to go Cherry, at least go MX Greens.
