Author Topic: 60% Cases are back and in stock @ PEXON!  (Read 141129 times)
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
Re: 60% Cases are back and in stock @ PEXON!
« Reply #50 on: Fri, 26 December 2014, 10:58:03 »
Yup, its just a protective sleeve to stop the interior getting scuffed up :)
Offline ideus
  • Björkö.
« Reply #51 on: Fri, 26 December 2014, 21:30:29 »
Does that mean the case is painted?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #52 on: Sat, 27 December 2014, 08:58:29 »
No, its cast aluminium, so its black all the way through
Offline FreeChemicals
« Reply #53 on: Sun, 28 December 2014, 09:10:52 »
I've ordered one for my SPRiT build ;D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #54 on: Sun, 28 December 2014, 09:14:14 »
Just got it through man, we are hopefully getting back to work tomorrow, so it should go out on Tuesday
« Reply #55 on: Sun, 28 December 2014, 09:17:38 »
Thanks! I'm looking forward to it, still have to wait for the PCB kit to arrive aswell. All in good time.
« Reply #56 on: Mon, 05 January 2015, 06:06:57 »
It was delivered at the office last saturday, so I picked it up today. It's a great case, thanks pexon!
« Last Edit: Mon, 05 January 2015, 06:12:30 by FreeChemicals »
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #57 on: Mon, 05 January 2015, 11:00:27 »
Fantastic! Glad you like it dude. They are awesome little cases aren't they :D
« Reply #58 on: Fri, 16 January 2015, 04:02:05 »
Indeed, thanks again. A question though: would you recommend adding some foam & washers between the PCB and the case?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #59 on: Fri, 16 January 2015, 14:05:58 »
I have not, but I don't see a reason not too. Not had any issues without
Offline Alastoris
« Reply #60 on: Fri, 06 March 2015, 21:17:02 »
Just bought a 60% case! I can't wait for it to arrive!
Offline yobinad
« Reply #61 on: Thu, 09 April 2015, 16:54:02 »
Hi
Is this case compatible with GON's NerD 60 PCB ?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #62 on: Fri, 10 April 2015, 06:44:39 »
Hi
I cant say I have any experience with the case and that PCB dude
Offline ideus
  • Björkö.
« Reply #63 on: Fri, 10 April 2015, 07:34:59 »
Hi
It is an standard Poker case; that, should fit the Nerd60 that fits the ABS version of the stock Poker case.
Offline azhdar
  • Praise the AZERTY god
« Reply #64 on: Fri, 10 April 2015, 07:40:58 »
Hi
It will fit.
Azerty Propagandiste
Offline yobinad
« Reply #65 on: Fri, 10 April 2015, 13:31:34 »
Thank you for your replies  :)
Offline Lastpilot
  • Power stance
« Reply #66 on: Fri, 10 April 2015, 13:40:55 »
Any chance of the silver case coming back?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #67 on: Fri, 10 April 2015, 13:46:18 »
Thanks for the clarification dudes! :D
The silver cases should be back, no idea of a date though. We may also have access to gold and pink versions too. Once we know more, I will make a post and we can do preorders again
« Reply #68 on: Fri, 24 April 2015, 15:04:14 »
Are these designed to screw to the plate or PCB?  I have a plate and was going to handwire it, but not if I can't get a case...
Offline azhdar
« Reply #69 on: Fri, 24 April 2015, 15:06:09 »
They have the regular stand-off of a poker, so I guess you could use it on your plate + handwire.
« Reply #70 on: Fri, 24 April 2015, 15:15:08 »
I've never seen a poker to know how it mounts but if you say it's good I'll take your word for it - thanks :)
Offline azhdar
« Reply #71 on: Fri, 24 April 2015, 15:17:51 »
Verify that your plate has the correct hole to mount it onto a 60% case, as long as your holes are correctly positionned there should be no problems, there is plenty of room underneath the standoffs.
Offline Photoelectric
« Reply #72 on: Tue, 28 April 2015, 02:46:24 »
Pink sounds great! Any preliminary photos available?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #73 on: Tue, 28 April 2015, 12:47:06 »
Still no news unfortunately
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #74 on: Fri, 15 May 2015, 06:13:01 »
Will be up for a cnc when they come back in
« Reply #75 on: Sun, 17 May 2015, 05:38:53 »
I finally put this together (all the parts got confiscated as birthday presents, then the plate needed modding) and it seems the case is designed to screw to the PCB as even with a thick acrylic plate there is a definite gap between the spacers and the bottom of the plate.  That or my plate is too big and it's supposed to sit lower in the case?  Don't think there would be room for the bottom row switches if it did...
