Author Topic: Vortex KBTalking One uses ABS keycaps?  (Read 8014 times)
Offline dante
« on: Sat, 18 October 2014, 09:15:05 »
The KBTalking One boards that you just got in say they have ABS keycaps in the description.  However the keyset itself looks identical to the Vortex PBT/POM translucent sets you also stock.
Are you sure these boards have ABS?
Offline JoshMK
  • * Commercial Vendor
  • MechanicalKeyboards.com
Re: Vortex KBTalking One uses ABS keycaps?
« Reply #1 on: Mon, 20 October 2014, 12:13:13 »
Definitely ABS.
Josh McConnell
Josh@mechanicalkeyboards.com
615.266.1420 ext303
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #2 on: Wed, 22 October 2014, 12:53:35 »
Definitely ABS.
Same quality as Ducky's thick ABS shine keycaps.
 :thumb:
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
