Author Topic: What kind of switch is this?  (Read 1616 times)
Offline supamesican
« on: Sat, 18 October 2014, 13:52:27 »
Found an old compaq keyboard at the local retirement home thrift shop, for $1.50, felt heavier than a rubber dome and they keys were noticeably different. Took a key off and found this, hopefully it uploads right..
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: What kind of switch is this?
« Reply #1 on: Sat, 18 October 2014, 16:04:53 »
http://deskthority.net/wiki/NMB_dome_with_slider
Rubber dome with a slider over the top.
Bore Awards
Offline JackMills
« Reply #2 on: Sat, 18 October 2014, 16:07:26 »
I have the same on a Compaq. If you disassemble you'll see the rubber dome beneath.
Edit: Daniel beat me to it, his link shows what's beneath. Looks exactly like what I saw when I disassembled mine.
« Last Edit: Sat, 18 October 2014, 16:09:42 by JackMills »
Offline supamesican
« Reply #3 on: Sat, 18 October 2014, 16:15:52 »
Oh well, at least its feels better than a normal rubber dome.
Offline JackMills
« Reply #4 on: Sat, 18 October 2014, 16:32:36 »
It does feel better, that's why I opened it up. Had to know what it was, bit disappointed about the dome. It's still being used.
  • RIP
    • Boring twaddle
« Reply #5 on: Sat, 18 October 2014, 16:35:05 »
Domes are not inherently bad — it depends how much the manufacturer was willing to invest in the design and production.
Mechanical switches can also be terrible if made cheaply. It's just that dome tends to go hand-in-hand with maximum cost-cutting measures.
Bore Awards
Offline JackMills
« Reply #6 on: Sat, 18 October 2014, 16:43:06 »
I know, the disappointment was more because I didn't expect it as it differed from the rubber domes that I knew. I hoped for something special, I guess supamesican had the same hope. But it is indeed a better rubber dome then the others that I have or use.
Offline supamesican
« Reply #7 on: Sat, 18 October 2014, 16:53:03 »
Yeah it was kinda disappointing, but they feel a lot nicer than normal rubber domes(even ripster said so on imgur http://imgur.com/a/ko54H), they sound nicer, and just better switches to standard domes. Until I get my unicomp(or find a different mechanical switch at a swap meet or thrift store) I'll be happy enough with this. Especially for $1.50, its hands down the best non mechanical board I've used.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Sat, 18 October 2014, 16:57:43 »
isn't that basically the same as the Dell Quiet Key?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
  • RIP
    • Boring twaddle
« Reply #9 on: Sat, 18 October 2014, 17:00:21 »
Well, yes, the NMB version of the QuietKey used those switches; whether they have the same spec or feel, I don't know.
I had the Silitek QuietKey and that was really nice, but it wore out and I finally ended up breaking the membrane cleaning it — IIRC it had conductive domes that needed frequent cleaning.
Bore Awards
