Author Topic: Does anyone want to bug test a program?  (Read 7011 times)
Offline Inertially
« on: Fri, 03 July 2009, 02:39:05 »
Seeing as how this wonderful community is mainly about keyboards and stuff, I thought that it would be a good idea to ask here.
I made some keyboard input program which displays key inputs amongst other things.
http://sites.google.com/site/inertially/keyscan
Download link: http://sites.google.com/site/inertially/files
If you are getting the COMCTL32.OCX error, download that also.
Suggestions are welcome.
Offline bsvP585hUO2Y6
Re: Does anyone want to bug test a program?
« Reply #1 on: Fri, 03 July 2009, 04:02:35 »
Inertially writes:
I don't see a license anywhere... Is the source code available?
Offline Mr.6502
« Reply #2 on: Fri, 03 July 2009, 13:44:30 »
It might be handy to include instructions on the page that tell people how to register comctl32.ocx since just putting it in system32 or in the same folder as the exe won't make it work on all systems.
"Engineers are really good at labeling and branding things ...  If we had named Kentucky Fried Chicken, it would have been Hot Dead Birds."
-Vint Cerf
Offline FunkTrooper
    • http://funktrooper.t35.com/
« Reply #3 on: Fri, 03 July 2009, 17:51:12 »
It appears to detect what key you're pressing based on your keyboard layout and not the scancodes of that key.  And it does not recognise keyboard layouts other than US QWERTY.
I use Colemak, and the keys it recognises are all wrong. For example, If I press *my* T key (which is labelled F), it will be recognised as a keypress of the key that is labelled T on the keyboard.  I know Colemak users may seem like a tiny minority to bother catering for, but presumably this bug would also affect users of AZERTY, QWERTY and even UK QWERTY users, to mention but a few.  It would probably be a better idea to read the scancodes, if that's even possible with a .NET app, which I assume is what this is (I really don't know much about Windows programming, even though I use little other than Windows myself).
EDIT: also, pressing Alt Gr is recognised as being a press of a combination of Left Ctrl and Right Alt. That's really interesting — I wonder if that's how Windows actually interprets a press of the Alt Gr key.
« Last Edit: Fri, 03 July 2009, 17:53:35 by FunkTrooper »
Offline FunkTrooper
« Reply #4 on: Fri, 03 July 2009, 18:14:07 »
I've attached a screenshot to show what it's detected of my PC.  Although I have the same processor as you (a Q6600), it doesn't show up that model name like your screenshot does, even though it does detect other details about the CPU correctly.
It manages to get my RAM very wrong indeed — I do not have 0.125 GB RAM; infact, I have 4 GB.
The “Unknown Keyboard” in question is a Unicomp Customizer 104.
Seemingly, when taking a screenshot, the “log” part of the windows doesn't quite get screenshot correctly… I'm not quite sure how that happened.
Also, is there any chance of this being open-sourced. It would be very interesting to see how this is all done, if nothing else.
« Last Edit: Fri, 03 July 2009, 18:14:44 by FunkTrooper »
Offline ch_123
« Reply #5 on: Fri, 03 July 2009, 19:50:12 »
Quote from: FunkTrooper;101024
CTRL+ALT does the same thing as ALT-GR, so it would make sense.
Offline vils
« Reply #6 on: Fri, 03 July 2009, 20:40:59 »
I just pressed AltGr + Del, it worked! Why have I been pressing 3 keys to guide windows through life for all these years.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline vils
« Reply #7 on: Fri, 03 July 2009, 20:44:44 »
This thread is around a similar program, although this seems to be more promising.
Offline Mr.6502
« Reply #8 on: Fri, 03 July 2009, 20:58:22 »
Quote from: FunkTrooper;101027
That screenshot is interesting.  Looks like it took the screenshot in the middle of the window redrawing.  On my computer when I do a screenshot of the program, the PrtScr button is lit up but the "log" part hasn't been updated to include the PrtScr button press yet.
-Vint Cerf
Offline sixty
    • http://deskthority.net
« Reply #9 on: Sat, 04 July 2009, 11:14:26 »
Quote from: ripster;101055
I always thought ASCII Shower was an unfortunate name.  Sounds like it came from a Porn site.
Before I even look at this program is the author going to be charging for it?
It says its freeware in the about box.
Btw, Gave this a try yesterday, I really like it so far, especially since its portable and does not need any install. But yes.. it would make more sense if the keys pressed are being recognized by their bios keycode.
Offline Rajagra
« Reply #10 on: Sun, 05 July 2009, 10:47:25 »
Sooo... are we satisfied this isn't a keylogger?
It checked out OK with Kapersky and Ad-Aware, but I held back from running it. Sorry to be so mistrusting but linking a download in someone's first post on a forum tends to arouse suspicion.
Offline Inertially
« Reply #11 on: Tue, 07 July 2009, 02:13:11 »
Thanks for the feedback.
I haven't been replying because I've been worrying about other things such as entering first year college, in which I think I'm screwed, and working on this can take up a lot of time, maybe because I'm mentally challenged (in a way)...
As for how the program works, anything you need to know or would want to know is available here:
http://msdn.microsoft.com/en-us/library/ms645530%28VS.85,loband%29.aspx
There are some major bugs in the beta.
I chose to do a look up from the virtual key code instead of  scan code because virtual key is device-independent whereas scan code can be specific/vary from keyboard  to keyboard.
Whether virtual-key is used or scan code is used, a new virtual keyboard layout (UI) would have to be created in order to support unique key layouts.
In your case, I don't think VKey vs Scan code is causing the error.  The scan code for each key does not change when you enable the Colemak layout, assuming that you are using the application that remaps each key from QWERTY to COLEMAK and not a native COLEMAK keyboard.
The Colemak remapping app uses a low-level keyboard hook to block key input from the keyboard and then injects the COLEMAK equivalent of that key (F to T) with probably the SendInput() or keybd_event() API.
Because both applications use keyboard hooks, the results can be funky, or vary, depending on which application is ran first.
And KeyScan sometimes detects both the normal and injected key inputs.
Also there's mistake in interpreting key up/down.
The program does log keys (should be apparent), but it doesn't send them to anyone or anything.  This isn't a keylogger.
« Last Edit: Tue, 07 July 2009, 02:17:09 by Inertially »
Offline FunkTrooper
« Reply #12 on: Tue, 07 July 2009, 06:22:05 »
Quote from: Inertially;101491
That's not right at all.  There is no “Colemak app”, it's just a keyboard layout created using MS Keyboard Layout Creator.  The same problem is seen with this program when using Dvorak or Azerty keyboards.
Offline lowpoly
« Reply #13 on: Tue, 07 July 2009, 06:39:16 »
I remember getting problems when I used Autohotkey to redefine
CapsLock::LCtrl
LCtrl::LWin
Then AltGr would act up. Why couldn't they use RCtrl which I never use.
Offline Inertially
« Reply #14 on: Tue, 07 July 2009, 15:33:51 »
Quote from: FunkTrooper;101502
I was looking at  http://sourceforge.net/projects/pkl/files/
There is a portable Colemak remapping app.
