Author Topic: Recommended Bluetooth Mouse for android?  (Read 4779 times)
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« on: Wed, 22 October 2014, 10:28:22 »
Hi Geekhackers!
I am going to get the Nexus 9 and use my JD40 keyboard with it, i also want to have a mouse, a Bluetooth mouse.
Does anyone have a recommendation?
Thanks!  :thumb:
Offline esoomenona
  • Gnillort?
« Reply #1 on: Wed, 22 October 2014, 10:29:19 »
« Last Edit: Fri, 04 September 2015, 09:20:38 by esoomenona »
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
Re: Recommended Bluetooth Mouse for android?
« Reply #2 on: Wed, 22 October 2014, 10:32:28 »
Go on eBay and pick up a Logitech MX Revolution.
that mouse using a Radio(RF) Instead of Bluetooth, i don't know if that would work for android   :(
Offline esoomenona
  • Gnillort?
« Reply #3 on: Wed, 22 October 2014, 10:33:50 »
« Last Edit: Fri, 04 September 2015, 09:20:28 by esoomenona »
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #4 on: Wed, 22 October 2014, 10:35:41 »
You must not be looking at the correct mouse. The MX Revolution is a BT mouse. Sure it has a receiver, but it is not necessary. I've connected it to my laptop without it.
aah okey! :D
have you seen the Microsoft ARC Touch Mouse? i dont need so much flashy mouse, just a mouse that i can take with me in my bag :)
Offline esoomenona
  • Gnillort?
« Reply #5 on: Wed, 22 October 2014, 10:36:54 »
« Last Edit: Wed, 02 September 2015, 13:50:23 by esoomenona »
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #6 on: Wed, 22 October 2014, 10:44:27 »
Yeah. Bro, that mouse is gross. But if that's why you like, then go for it.
i also thinks is gross, i just want a BT mouse that is easy to carry! :)
Offline edwardpark8
« Reply #7 on: Sun, 26 October 2014, 03:17:38 »
any logitech bluetooth mouse is solid!
