Author Topic: Model F feet - AT and XT are not interchangeable  (Read 1555 times)
Offline geniekid
« on: Wed, 22 October 2014, 20:22:59 »
With the help of fohat.digs, I have discovered that Model F AT feet are not interchangeable with XT feet.  Probably some people already know this, but I couldn't find any information on the subject when I was looking for it so if that information is already out there it's hard to find :)  Anyway, here are some pictures to illustrate the foot difference.  Not pictured are the spring mechanisms for each foot, which are also different between the AT and the XT.
AT
80487-0
XT
80489-1
Potato pics yes but you get the idea.  Hopefully this helps someone else!  And also, someone sell/trade me a Model F AT foot :)
Re: Model F feet - AT and XT are not interchangeable
« Reply #1 on: Wed, 22 October 2014, 21:25:59 »
That's good to know. If you like I can check intercompatability of 3178 feet (Doubt it but I'll check anyway).
Offline geniekid
« Reply #2 on: Wed, 22 October 2014, 21:58:55 »
Sure.  Worst case scenario we have more info for future reference.  Either way, I appreciate the offer.
« Reply #3 on: Wed, 22 October 2014, 22:18:57 »
ok so the bad news is that they have no feet at all. sorry.
Offline FrostyToast
  • Litshoard
« Reply #4 on: Wed, 22 October 2014, 22:21:38 »
Well now we know those feet aren't compatible :p
Quote from: elton5354
Offline geniekid
« Reply #5 on: Wed, 22 October 2014, 22:22:22 »
Haha, thanks :)
