Author Topic: Need double O-Rings on Razer Orbweaver Stealth, kailh, orange switches  (Read 4051 times)
Offline Blue_Moon
I just got a 2014 Razer Orbweaver Stealth with the kailh orange switches. The first thing I tried to do was to put o rings on it, but the o-rings did nothing. The stem on the orbweaver keycaps is really long and the o-ring sits far down on it. The o-ring never touches when the keycap bottoms out.
Just fyi
« Last Edit: Fri, 24 October 2014, 10:34:17 by Blue_Moon »
Offline Rebral
Re: O-Rings are useless on Razer Orbweaver Stealth, kailh, orange switches
« Reply #1 on: Thu, 23 October 2014, 20:48:43 »
Have you tried using multiple o-rings on one cap?
I ask only because you didn't mention it on your post. :X
Offline Blue_Moon
« Reply #2 on: Fri, 24 October 2014, 10:29:09 »
No, I didn't. :p But I did just now. Two o-rings works. I'm gonna have to buy more o-rings!
