Author Topic: IBM 122-Key Model M (PT NO 1387001 - DATE 26JULY85 - ID NO 00219)  (Read 6620 times)
Offline joc
Hello, I found this unique IBM 122-key Model M. This is the first 122-key Model M I've seen with the old style barcode label. Also, this 122-key Model M has one of the lowest serial numbers I've seen on a Model M. I'm assuming that it's rare. I'll probably put together a Soarer's converter to check if it still works. Are there any keyboards similar to this one documented online? I couldn't find much information about it online.
Re: IBM 122-Key Model M (PT NO 1387001 - DATE 26JULY85 - ID NO 00219)
« Reply #1 on: Sun, 26 October 2014, 21:25:25 »
holy **** an '85 M
that might be the earliest M I've seen
I know DV has a really early one too, but this is up there
Offline mougrim
« Reply #2 on: Mon, 27 October 2014, 02:10:54 »
Is it real? Can't believe my eyes!
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Jotokun
« Reply #3 on: Mon, 27 October 2014, 15:29:59 »
Woah... that's older than my 122-key Model F! I would have expected a hard transition from the F to the M on 122s, but clearly that wasn't the case.
« Last Edit: Mon, 27 October 2014, 15:31:34 by Jotokun »
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline joc
« Reply #4 on: Mon, 27 October 2014, 17:51:52 »
I opened up the keyboard to take some pictures of its backplate and electronics. This keyboard has one of the thicker backplates found on early Model M's.
« Reply #5 on: Tue, 25 November 2014, 21:09:28 »
holy **** an '85 M
nah mine's a 1390120 march 1986. The IBM I have that's really early is my F122 which is january 1984. It's ID number is 00363
of note is the serial number (ID number) of this one is even lower: there are only a few IBM keyboards I know of with serial numbers that low.
I'll have to look up the previous contender for oldest model M. i think killerbee had it. part number is 1386303 or 1386304
hal9000 has this from this topic
killerbee's was from june 10 1985 serial number 01137
https://geekhack.org/index.php?topic=11311.msg217468#msg217468
Note that buckling spring over membrane was introduced in december of 1984 on the wheelwriter typewriters.
« Last Edit: Tue, 25 November 2014, 21:24:07 by dorkvader »
Offline joc
« Reply #6 on: Tue, 25 November 2014, 22:29:38 »
This is the only Model M I was able to find with a lower ID number.
