Author Topic: IBM Model M - Stuck "++++++++++++++++++++++++++++++++++++++++++  (Read 2705 times)
Offline guidodogg
« on: Tue, 28 October 2014, 20:10:40 »
I recently got a Model M and i couldn't be happier with it. Thing is, that the numpad key "+" get stuck every time i press it, getting "+++++++++" until i raise it manually. I removed the key and didn't see anything broken. The only thing i notice was the spring being a little bit "going down".
So i tried:
a) Exchange "Intro" long cap with "+" cap. Result: "+" button with "Intro" cap still stuck. "Intro" button with "+" cap works well.
b) Try "-" (Single box cap) on the "+" place (To check the spring). Result: "+" input works well and the key don't stuck.
c) Remove the blue guide for the second hole of the long "+" cap and it no longer stucks, but pressing feels kind of loose.
Is this a common issue? Could you guys give me your opinion?
Thanks in advance!
PD: Sorry about the duplicated post. I send it the first time and i got timeout and when i hit back there was already two posts.
« Last Edit: Tue, 28 October 2014, 20:28:54 by guidodogg »
Re: IBM Model M - Stuck "++++++++++++++++++++++++++++++++++++++++++
« Reply #1 on: Tue, 28 October 2014, 20:19:18 »
Some of those inserts are not symmetrical - i.e. it does matter which way they go in.
This was mentioned in a thread here recently, but I am so far behind that it passed me in a blur :))
Offline guidodogg
« Reply #2 on: Tue, 28 October 2014, 20:30:27 »
What do you mean by insert?
Offline 0100010
  • Not Sure
« Reply #3 on: Tue, 28 October 2014, 20:42:13 »
The blue guide you are referring to, is what is being called an insert.  Will find a pic in a minute.
Offline guidodogg
« Reply #4 on: Tue, 28 October 2014, 20:54:14 »
Thanks. It's either that or the spring. The plus key's insert it's placed the same way the intro key's insert is. If you try to flip it 180 degrees (the only other position to fit in the keyboard) the cap's guide will not fit on it.
Offline 0100010
  • Not Sure
« Reply #5 on: Tue, 28 October 2014, 21:18:59 »
Found it - take a look here :  http://geekhack.org/index.php?topic=63267.msg1482842#msg1482842
It shows the difference between the horizontal key stabilizer inserts and the vertical key inserts.
But - it sounds like you have the correct stab already, when you mention flipping it over the key won't fit at all.
How does the spring look?
Offline guidodogg
« Reply #6 on: Tue, 28 October 2014, 21:23:48 »
Like the one on the second picture, flaccid. I tried with a regular cap and worked, though. Could be the long cap not compressing the spring correctly?
Offline FreeCopy
« Reply #7 on: Tue, 28 October 2014, 21:34:46 »
Is it possible the blue stab guide is in backwards? I just took mine apart and rotated it and the key stuck.
I should have read more carefully.
« Last Edit: Tue, 28 October 2014, 21:37:09 by FreeCopy »
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline 0100010
  • Not Sure
« Reply #8 on: Tue, 28 October 2014, 21:49:58 »
Turn the board upside down, so the spring is positioned near the top of the barrel, then put on the cap // see if it buckles and springs back that way.
Offline guidodogg
« Reply #9 on: Tue, 28 October 2014, 22:16:20 »
Now i'm feeling stupid, i didn't thought of that. It didn't work, though. It keeps getting stuck.
« Last Edit: Tue, 28 October 2014, 22:18:26 by guidodogg »
Offline 0100010
  • Not Sure
« Reply #10 on: Wed, 29 October 2014, 08:27:01 »
Can you post any images of what the inside of the two barrels look like, or the bottom of the key?
Offline berserkfan
« Reply #11 on: Wed, 29 October 2014, 13:44:42 »
One possibility, is that the hammer is actually broken. I think someone wrote about that online but I don't know where. It's a rare occurrence, so lets hope your problem really comes from poor spring placement. In any case a broken hammer can be replaced just that its troublesome.
« Reply #12 on: Wed, 29 October 2014, 15:35:28 »
Whoa!
I did not know that was possible. I suppose I figured that it was never more than the spring flailing around.
Will need to be more careful, I sometimes give the spacebar or Enter a good whack, especially when it is the last stroke of the session.
- D Trump 2026-10-24
