Author Topic: POKER 2  (Read 2460 times)
Offline Mesort
POKER 2
« on: Tue, 28 October 2014, 22:45:58 »
I want to buy a new poker 2 . Do u guys know where can i find one?
Offline FrostyToast
  • Litshoard
Re: POKER 2
« Reply #1 on: Tue, 28 October 2014, 22:48:44 »
Mechanical Keyboards
Massdrop for clear switches currently
Quote from: elton5354
Offline DoubleUB
Re: POKER 2
« Reply #2 on: Wed, 29 October 2014, 15:19:22 »
Qtan sells them, going to order from him aswell.
good luck
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: POKER 2
« Reply #3 on: Wed, 29 October 2014, 18:02:29 »
Just remember that with Massdrop you'll be waiting a while
Offline Mesort
Re: POKER 2
« Reply #4 on: Wed, 29 October 2014, 18:44:15 »
I forgot to mention. I want a white one :) and do you guys know all poker 2 's are PBT?
« Last Edit: Wed, 29 October 2014, 18:52:12 by Mesort »
Offline Booper
    • omniclectic.com
Re: POKER 2
« Reply #5 on: Wed, 29 October 2014, 18:53:12 »
White ones with clear switches are up on massdrop right now. They seem to have rounds with the option of Blue, Brown, Red and Black switches pretty frequently though if you don't want clears.
IDK if you like LEDs but I'll mention I *think* massdrop is the only place that gives you an option for white LEDs pre-installed. You can find pokers with various LED colors from other vendors though.
That's about all the Poker info I know! good luck
« Last Edit: Wed, 29 October 2014, 18:54:47 by Booper »
boop!
Offline Mesort
Re: POKER 2
« Reply #6 on: Wed, 29 October 2014, 19:15:14 »
Is there an option to close backlits when u buy a backlit one?
« Last Edit: Wed, 29 October 2014, 19:19:25 by Mesort »
Offline user 18
Re: POKER 2
« Reply #7 on: Wed, 29 October 2014, 19:38:13 »
This is inaccurate, some Poker IIs have ABS caps. Not that there's anything wrong with ABS, but that's how it is.
Generally, ABS caps are on backlit boards, and PBT caps are on non-backlit boards.
Yes, backlighting can be turned on and off on the board itself after the LEDs are installed.
Avatar by ashdenej
Offline Booper
    • omniclectic.com
Re: POKER 2
« Reply #8 on: Wed, 29 October 2014, 19:46:03 »
There are 7 different brightnesses you can use and you can turn it off.
I just got one in the mail a few days ago. Some of the LEDs are inconsistent, but for the low price and luxury of not having to install them myself, it's not bad.
This is what it looks like - but it comes with a white cable
boop!
