Author Topic: What's this? Unknown board with L-shaped Enter  (Read 2934 times)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« on: Fri, 10 July 2009, 18:51:38 »
Don't ask me what this is.
Something mechanical by any chance? Should be some Taiwanese mfr.
The cable doesn't look too confidence-inspiring but still...
Offline huha
« Reply #1 on: Fri, 10 July 2009, 19:02:32 »
Extremely bad photo. The key lettering looks quite sharp and well defined, so they could be two-shot keycaps. Two-shot keycaps could mean Alps switches, but it's so hard to tell you'd better ask the seller to supply you with more info.
It does feature Windows keys, which usually isn't a good sign.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline rdjack21
« Reply #2 on: Fri, 10 July 2009, 21:18:49 »
If you do ask the seller for more pictures see if you can get one of the back.
One other observation if that is the original box then I bet it is a rubber dome board. Why? There is no way a manufacture put a mechanical board in that flimsy box. They are just to heavy. But a rubber dome would be fine they are extremely light
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #3 on: Fri, 10 July 2009, 22:06:04 »
Sellers have removed keys and took a photo for me in the past. It never hurts to ask. And if my opinion counts, I think it looks risky. Be cautious.
