Author Topic: [GB] Octagon 75% Kustom Keyboard  (Read 350667 times)
Offline Data
Re: [GB] Octagon 75% Kustom Keyboard
« Reply #700 on: Tue, 29 September 2015, 18:44:27 »
Nope.  Never figured it out.  The keys I defined for LED control do wildly different things, seemingly at random.  Even the backlighting zones give me trouble sometimes.   :confused:
Offline rainb1ood
  • so pretty so plastic
« Reply #701 on: Tue, 29 September 2015, 18:59:51 »
for RGB:
※ RGB Effects
  1. Off
  2. ON - R, G, B both on (white color)
  3. Change the circulation of the specified color (7 types)
    Applying a fixed delay
  4. Change up to 16 user-defined colors in circulation
    Applying the delay time of the preset
  5. Custom Color 1 ON> keys pressed Off
    Push Lock off when the key is pressed when the color conversion
  6. Off> key when the user clicks on color 2
  7. User Color 1. On> key when the user clicks on color 2
  8. Custom Color 2 On> key when the user clicks on one color
  9. breathing - circulation changes in the Custom preset colors
http://kbdlab.co.kr/?document_srl=309373&mid=board_sw&listStyle=viewer (Used google translate)
Offline Data
« Reply #702 on: Tue, 29 September 2015, 19:08:30 »
for RGB:
※ RGB Effects
  1. Off
OK, but that doesn't explain which key(s) to press or in which order to press them to achieve the listed result.
Also Google translate seems to indicate that document might only apply to the Orion.  It's hard to tell.
Offline rainb1ood
« Reply #703 on: Tue, 29 September 2015, 20:01:41 »
You'll have to map the key or use the default on the octagon. I believe its layer 3 then its Fn + 1 in the number row if I'm not wrong. (Also need to map the Fn key and the right layer to point it at)
The #4 item on my previous post is based on the colors you picked in the 02D mapper.
« Last Edit: Tue, 29 September 2015, 20:06:55 by rainb1ood »
Offline MrRooks
  • Always be knolling
« Reply #704 on: Sat, 03 October 2015, 13:58:46 »
See this is not the case for me. I picked all orange on the colors in the 02D mapper under Tools > RGB Color Preset yet when I put it in cycling mode with the 'R Mode' key it just cycles a bunch of RGB colors, none of the modes show my orange.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Offline E3E
« Reply #706 on: Sat, 03 October 2015, 18:23:34 »
:eek:
http://kbdlab.co.kr/index.php?document_srl=3104247&mid=board_Lsno50
Bye bye money. Hello Octagon v2. Please don't show up too soon. I'm spending too much right now! If it has Alps compatibility I'm done. Now the question is, do I keep or sell my Octagon when get this one. Hmmm. The only thing stopping me from selling mine is the heavy theme it will have and the fact Alps can't crossover caps wise unless I get those adapter things.
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #707 on: Sat, 03 October 2015, 18:26:51 »
I think have both but make sure you pick up the v2 in alps config.
Offline E3E
« Reply #708 on: Sat, 03 October 2015, 19:02:17 »
Sounds good to me. One MX, one Alps, so I don't have to feel like one is redundant!  :thumb:
Offline asgeirtj
« Reply #709 on: Sun, 04 October 2015, 17:50:38 »
So my keyboard feet seem to have lost their grip on the keyboard, what's best to do, buy new ones?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline E3E
« Reply #710 on: Sun, 04 October 2015, 19:16:27 »
I suppose so! I'd use some foam silicone rubber or neoprene to make the feet and cut it to shape
Offline tjweir
« Reply #711 on: Mon, 05 October 2015, 05:45:05 »
Or grab and cut a non-slip mat from a kitchen supply store.
Offline E3E
« Reply #712 on: Mon, 30 November 2015, 06:28:53 »
Did you guys see the updated pics of the new Octagon yet?
Get hyped!
http://duck0113.tistory.com/127
This is getting me antsy as hell. I really want to buy all the different versions, even though I've told myself I've settled on one to go with the SNES GMK set.
Offline gadzkun
« Reply #713 on: Mon, 30 November 2015, 06:37:04 »
Get hyped!
WOW! this is really HYPE! :p
Offline raymogi
« Reply #714 on: Mon, 30 November 2015, 07:07:09 »
Get hyped!
Hmmm tempting. Buy ALL new Duck boards!
Please feed my addiction.
Offline Data
« Reply #715 on: Mon, 30 November 2015, 07:36:15 »
New one looks nice.  Maybe we'll get some new firmware out of it.
Offline E3E
« Reply #716 on: Mon, 30 November 2015, 07:40:14 »
I bet we will! At least new RGB controls, lol. I'm still happy that the original Octagon had RGB though. :D
Offline Dreamre
    • kbdlife
« Reply #717 on: Mon, 30 November 2015, 09:09:21 »
This is totally going to be my next board!
Offline elton5354
« Reply #718 on: Mon, 30 November 2015, 09:20:51 »
This picture makes it worth having  :p
I wonder if they will have an option to add those duck feet with the acrylic flat bottoms...
Offline Steezus
  • Keeper of Facts
« Reply #719 on: Mon, 30 November 2015, 09:23:46 »
If there is such an option then I may be interested in my first 75%. :p :p
Offline stillzman
« Reply #720 on: Mon, 30 November 2015, 09:42:06 »
any idea when the new ones will be available?
Offline gadzkun
« Reply #721 on: Mon, 30 November 2015, 10:03:46 »
hope the price is wallet friend :p
« Last Edit: Mon, 30 November 2015, 10:27:01 by gadzkun »
Offline Steezus
  • Keeper of Facts
« Reply #722 on: Mon, 30 November 2015, 11:02:40 »
You'll be looking ~$350 is my guess after shipping and pp fees maybe a little more depending on where you live.
Edit: It'll probably end up closer to $400 than anything if it is similar to Duck's GBs.
« Last Edit: Mon, 30 November 2015, 11:07:07 by Steezus »
Offline E3E
« Reply #723 on: Mon, 30 November 2015, 11:51:49 »
The last one was around $360 (shipped to the US) when all was said and done, and that was for a single milled slab of aluminum.
Since the final price for an all aluminum combo for the Orion v2 was $360 + shipping, and since there's considerably less material that goes into a 75%, I can imagine the price being like the original Octagon or even lower.
If you all remember, the original Orion was even more expensive than this one by quite a bit.
If you live in  the US, I see the Octagon v2 being around $350-360. Not a bad price. :thumb: I'd get two if I was rich, but I'm probably going to settle on the silver + blue/ti grey aluminum bottom combo.
Once again, design concept prevails or else I'd have gotten a red case, since it's my favorite aluminum case color by far. Though not many key sets go well with red. :P
Offline JonasDK
  • Let me poo on you
« Reply #724 on: Mon, 30 November 2015, 16:11:14 »
And this still doesn't support iso  :'(
Offline QuickDelat
« Reply #725 on: Tue, 01 December 2015, 02:15:21 »
Here I was getting hyped, and then my dream gets crushed :(
Offline tjweir
« Reply #726 on: Tue, 01 December 2015, 06:12:42 »
Get hyped!
Damn, I'm going to have to sell my V1s for a pair of these, they look great.
I'm interested in the firmware improvements mainly.
Offline E3E
« Reply #727 on: Tue, 01 December 2015, 06:50:57 »
Get hyped!
Haha, I know, I know. I agree on both counts! I'm tempted to sell my V1 as well, but I think I'd rather hang onto it as there are some things about it I find pretty charming that are gone in this revision. Yes, that dumb little name plate that actually makes the board octagonal, haha.
I'm fine owning a V1 and a V2, I think that'd be pretty cool actually. :)
Offline beltet
« Reply #728 on: Tue, 01 December 2015, 07:38:33 »
Oooh! Really want this! Any indication when this going to happen?
So that I can save/sell things to afford this one.
Offline E3E
« Reply #729 on: Tue, 01 December 2015, 07:48:20 »
I'd say whenever everything from the Orion v2 group buy is fulfilled, so probably in a month or two. I'd say two months. Three if things take a little longer than planned.
I'm definitely fine with waiting!
Offline 64rky
« Reply #730 on: Tue, 01 December 2015, 15:09:30 »
Wait,  does this mean I can still get in on this,  or have I totally missed the boat?
Offline Steezus
  • Keeper of Facts
« Reply #731 on: Tue, 01 December 2015, 15:11:09 »
Missed it by over half a year, they just aren't finished shipping the rest of the keyboards. Once it's all said and done then Duck moves onto the next group buy.
Offline 64rky
« Reply #732 on: Tue, 01 December 2015, 15:14:15 »
Thanks,  will wait for the next buy.
Offline popkorn62
  • No keyboards for old men
    • Mekibo
« Reply #733 on: Tue, 01 December 2015, 16:08:27 »
i can't wait for v2 just because of those feet!
https://mekibo.com/
Offline E3E
« Reply #734 on: Tue, 01 December 2015, 16:09:57 »
Do you mean the flat acrylic bottom + aluminum feet?
Offline popkorn62
    • Mekibo
« Reply #735 on: Tue, 01 December 2015, 20:25:54 »
Yes! Sorry newbie here  ;D
https://mekibo.com/
Offline E3E
« Reply #736 on: Wed, 02 December 2015, 21:39:32 »
No problem. :) I think if I do get any other option for the bottom aside from aluminum, it'd be the flat acrylic bottom.
Offline R4WBIT
« Reply #737 on: Fri, 04 December 2015, 15:08:07 »
Please let the pictures be wrong. This keyboard must support ISO, just like the Orion :(
Offline yicaoyimu
« Reply #738 on: Fri, 04 December 2015, 15:15:12 »
Looks like it does.
Offline popkorn62
    • Mekibo
« Reply #739 on: Fri, 04 December 2015, 15:31:44 »
the bottom is exactly the kind I've always been looking for just didn't know where to begin to look for one  :))
https://mekibo.com/
Offline QuickDelat
« Reply #740 on: Fri, 04 December 2015, 16:20:19 »
Looks like it does.
Ah I can get hyped again, thanks! ;)
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #741 on: Fri, 04 December 2015, 17:22:51 »
Looks like it does.
no acrylic/plastic plate? :(
Offline gadzkun
« Reply #742 on: Fri, 04 December 2015, 17:27:44 »
Looks like it does.
wow can you tell us link of that korea GB?
i want to know the price. :p
i found it :thumb:
« Last Edit: Fri, 04 December 2015, 17:39:50 by gadzkun »
Offline E3E
« Reply #743 on: Fri, 04 December 2015, 17:39:51 »
Looks like it does.
Nice to see additional support! I'm definitely going to use holtite sockets in this one. :D
I can't wait until the GB opens up!
Offline yicaoyimu
« Reply #744 on: Fri, 04 December 2015, 17:43:56 »
Looks like it does.
i found it :thumb:
Link please? This is just a pictures I came across in a group chat. I don't know where it comes from actually.
Offline gadzkun
« Reply #745 on: Fri, 04 December 2015, 17:46:19 »
Looks like it does.
i found it :thumb:
http://www.kbd4u.co.kr/product/detail.html?product_no=62&cate_no=43&display_group=1
 :thumb:
Offline E3E
« Reply #746 on: Fri, 04 December 2015, 18:08:16 »
Looks like it does.
i found it :thumb:
 :thumb:
385000 South Korean Won equals
331.68520 US Dollar
The price for the whole package with the aluminum bottom.  From the original's price of $295, it's about $36 more expensive. Shipping to the US for the last buy was $57. So... We can expect a price around $390.
I guess the two piece design is more expensive to mill? The original Orion was a lot more expensive than the Orion v2.
Offline gadzkun
« Reply #747 on: Fri, 04 December 2015, 21:04:23 »
Looks like it does.
i found it :thumb:
 :thumb:
331.68520 US Dollar
i was hoping it would be like octagon v1 $295 full alu case. or maybe a little bit more cheap.
rip dream :))
Offline Data
« Reply #748 on: Wed, 16 December 2015, 07:23:19 »
Original was a comparatively simple 1-part case.  The 2-part case is more complex and therefore more expensive.
Offline E3E
« Reply #749 on: Wed, 16 December 2015, 07:25:34 »
Very much true. There's a lot more machining to do for the separate halves and all the tapping for screws and what not on both ends, LED indicator lights, etc. (I'm definitely going to hang onto my V1 though, as there is something nice about a solid 1-piece design I like over 2-piece, though I'll most certainly pick up a v2 as well!)
But...
Why was the Orion v1 more expensive than the v2?
AFAIK, they were both two part designs, but the original was quite a bit more expensive.
« Last Edit: Wed, 16 December 2015, 07:27:23 by E3E »
