Author Topic: Mechanical Switches on Membrane Keyboard  (Read 5259 times)
Offline TheAngelicWolf
  • Location: I live in the isolated, deserted, bare land of Mars...I'm the only one here. I need help immediately.
    • My Tumblr
« on: Tue, 04 November 2014, 16:23:30 »
Hey guys. I was busy thinking and I thought, is it possible to have a membrane keyboard with mechanical WASD keys? Maybe specifically for a gamer? What do you guys think?
I thought signatures belonged on paper?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Mechanical Switches on Membrane Keyboard
« Reply #1 on: Tue, 04 November 2014, 16:26:31 »
That's what buckling springs are
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #2 on: Tue, 04 November 2014, 16:27:59 »
Gah, why would you want that???
Who would buy that???
 :eek:
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
    • My Tumblr
« Reply #3 on: Tue, 04 November 2014, 16:28:25 »
 :eek:
It was just an idea  :confused:
Offline 00zeRO
« Reply #4 on: Tue, 04 November 2014, 16:35:24 »
Well then, in that case. That sounds like something Razer or Logitech should look into.
 :p
Offline 00zeRO
« Reply #5 on: Tue, 04 November 2014, 16:36:48 »
To those who what the best of both worlds, or have trouble letting go, they can buy a Type Heaven. It is the Hanna Montana of Mechanical Keyboards.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #6 on: Tue, 04 November 2014, 16:57:19 »
Why on earth would you ever want to do that?
There are of course switches that use various degrees of "mechanical" over membrane, such as (as mentioned) the IBM Model M, the Acer switch, Oriental Tech spring over membrane, and Cherry MY. I assume though that you specifically want discrete keyswitch modules.
The weirdest thing I ever saw was the Commodore 64 shift lock:
It's a latching action switch, with a little PCB used for the stationary switch contact, that projects from the switch downwards, and then they've soldered that onto the PCB. (One day I should clean up the switch and post detailed photos of it; I guess it predated the proper Mitsumi keyboard switch modules.)
Here's how Fujitsu had in-key LEDs on a pure membrane keyboard (FKB4700):
The LEDs legs are fitted with conductive pads that make contact with the membrane.
There are no end of weird ideas in production keyboards, some good, some bad.
The big gotcha with having "mechanical" WASD keys is that normal typing would feel odd, as you'd have certain keys that don't respond the same as all the others. I think I've seen mechanical keyboards with different switches under WASD, which just seems silly to me.
If you wanted to secure keyswitch modules into an otherwise membrane keyboard, you certainly could (just cut a hole in the membrane backing plate and put a PCB there) but it would be a very strange thing to do.
Bore Awards
  • RIP
    • Boring twaddle
« Reply #7 on: Tue, 04 November 2014, 16:59:44 »
OK just pretend there are images there.
Image 1 = http://deskthority.net/wiki/File:Commodore_64_--_shift_lock,_below.jpg
Image 2 = http://deskthority.net/wiki/File:Fujitsu_FKB4700-152_--_LED_membrane_contacts.jpg
I can't attach them thanks to some meaningless internal server error.
Bore Awards
Offline FoxWolf1
  • 154
« Reply #8 on: Tue, 04 November 2014, 19:24:17 »
This exists, but so far, I haven't seen Western brands picking up on the idea. Keep your eyes on on TaoBao though and you'll see some keyboards with 8 mechanical switches (WASD and arrows) and others with 19 (a whole cluster around WASD). The first one that comes to mind for me is the Delux T20. There are a bunch of 'em, though.
Offline ComradeSniper
  • HHKB Pro
« Reply #9 on: Tue, 04 November 2014, 19:59:46 »
I think there was a corsair board that was part mechanical and part rubber dome.
Offline 00zeRO
« Reply #10 on: Tue, 04 November 2014, 20:13:32 »
I apologize for my rudeness. Please forgive me OP. I just hate 'domes and don't want them mixing it up with any mechanical switchy goodness. I didn't realize how new you were when I said such nasty things... :'(
« Reply #11 on: Tue, 04 November 2014, 21:43:04 »
Sounds like you might want a membrane keyboard coupled with something like an Orbweaver.
http://www.razerzone.com/au-en/gaming-keyboards-keypads/razer-orbweaver
    • My Tumblr
« Reply #12 on: Wed, 05 November 2014, 00:01:38 »
Will do!  :D
    • My Tumblr
« Reply #13 on: Wed, 05 November 2014, 00:03:11 »
It's alright, I didn't see it as rude. I just thought you didn't read the post all the way through.  :thumb:
Offline jorgenslee
« Reply #14 on: Wed, 05 November 2014, 00:17:07 »
The Corsair K90 and K60 has part mechanical and part rubber dome. Maybe you should propose your idea to Corsair. I think they would love to build that. :)
« Reply #15 on: Wed, 05 November 2014, 00:55:52 »
Only the macro and function keys on Corsair's first "mechanical" keyboards were rubber-dome keys, but Corsair got a lot of flack from the gaming and keyboard communities for "cheapening out".
These days, all their mechanical keyboards are full-mechanical.
« Last Edit: Wed, 05 November 2014, 00:57:42 by Findecanor »
Offline johndavis33
« Reply #16 on: Wed, 05 November 2014, 08:50:53 »
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline 00zeRO
« Reply #17 on: Wed, 05 November 2014, 09:47:12 »
But again, the question: Why???
Offline davkol
  •  Post Editing Timeout
« Reply #18 on: Wed, 05 November 2014, 14:36:46 »
Ask Kinesis about the Advantage.
Offline FoxWolf1
  • 154
« Reply #19 on: Wed, 05 November 2014, 19:39:04 »
I had a few moments, so I dug up some examples.
With 8 mechanical keys (WASD and arrows):
link
A different one with the same 8 keys...and this time, the mechanical keys are also backlit:
link
How about one with 12? You even get a plastic bit to keep nasty stuff out of the switches...
link
Here's one with 19 mechanical keys, and handy markings on the keycaps to let you know which ones are which:
link
This one with 8 mechanical has been around for a while:
link
Anyway, I guess I could see the point of something like this for a heavy gamer on a strict budget...I mean, it's probably cheaper to get a partially mechanical keyboard than either a mechanical keypad and a dome keyboard, or a fully mechanical keyboard. And for the company, well, it'd probably count as dishonest if they marketed it as a mechanical keyboard, but if it's just a "gaming keyboard with mechanical keys"...well, I suppose that it is that.
    • My Tumblr
« Reply #20 on: Wed, 05 November 2014, 19:55:21 »
link
link
link
link
link
Wow. I appreciate you taking the time out to look for these. It's exactly what I was thinking of  ;D
