Author Topic: [IC] Customized Pattern Spacebars  (Read 16800 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: [IC] Customized Pattern Spacebars
« Reply #50 on: Tue, 11 November 2014, 21:35:29 »
Some pattern mockups added to OP.
 ;D
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline Data
« Reply #51 on: Wed, 12 November 2014, 11:03:38 »
A hexagonal/honeycomb pattern might be cool.
Offline 00zeRO
Re: [IC] Custom Spacebars
« Reply #52 on: Wed, 12 November 2014, 11:07:23 »
I have no opinion one way or the other.
Anyway, wouldn't it almost be easier to make the key cap out of real carbon fiber?  You could still make the posts out of polymer I guess (helps them fit on switches better?).  It doesn't seem like taking an ABS or PBT spacebar and covering it with CF or some CF-like material would result in a quality product.  I dunno.
It is all a guessing game at this point. I suppose I should have waited to post the IC until I had prototypes on hand to attest to the quality...hindsight 20%/20%
Offline 00zeRO
« Reply #53 on: Fri, 28 November 2014, 12:59:02 »
...waiting for prototypes to come back from where they were sent...hopefully have something of value to post by the end of next week.
Offline 00zeRO
« Reply #54 on: Thu, 04 December 2014, 15:57:20 »
Still no word to speak of yet folks. Hang in there.
Offline tigersharkdude
« Reply #55 on: Thu, 04 December 2014, 16:46:33 »
Offline 00zeRO
« Reply #56 on: Thu, 18 December 2014, 21:07:40 »
Guess my source is busy from the season...hope to have more info soon... :-[
