Author Topic: Fubata switch EAT-1010 keyboard question  (Read 6287 times)
Offline Touch_It
« on: Thu, 06 November 2014, 22:28:03 »
Found a local one on Facebook missing the enter and right shift keys.  Picking it up tomorrow for $5.00.  How hard is it to find replacement caps and any comments on the switch feel.  (I have read the wiki).
Fixed the title lol.
« Last Edit: Fri, 07 November 2014, 12:06:30 by Touch_It »
Offline Touch_It
Re: Fubta switch EAT-1010
« Reply #1 on: Thu, 06 November 2014, 22:38:32 »
Sorry for multiple threads.  And misspelling the title.  Tried doing this from my phone :(
Offline jevvix
« Reply #2 on: Fri, 07 November 2014, 05:00:48 »
The Futaba switch is interesting. Mine probably isn't the best representation of it, as half of the switches are worn out, but to me it feels close to an IBM Beam Spring but slightly stiffer. They switch really 'pops' for lack of a better term.
There are rubber dome variants of the Futaba switch in Sejin keyboards that use the same inverse-MX slider. They should have compatible caps but the stabilizers or keys larger than 1.5x might not line up. http://deskthority.net/wiki/Sejin_Futaba-mount_dome
Be sure to let us know how you like it when you get it :)
Offline Touch_It
Re: Fubata switch EAT-1010 keyboard question
« Reply #3 on: Fri, 07 November 2014, 21:07:28 »
Picked it up today.  Kinda rough condition with the missing keys, 3 missing stabilizers and missing stabs and a screw hole or stabilizer piece of plastic is broke.  Also one key cap was stuck and about pulled the whole switch out.  (I think it was f12.  Also it looks like someone spilled a bit of Pop on it.  Forgot to grab a at to ps2 converter from work so I can't test it till at least tomorrow.
As for the switch feel, I think it is pretty dissimilar to buckling spring.  Maybe more along the lines of mx brown.  If this makes sense or not idk but the sound to me is like buckling spring without the ping and "meat".  I think some of the switches are worn out a bit but overall I quite like the switch feel but wouldn't pay a lot for a board.
Key caps are double shot.  I'm assuming abs but no idea how to tell without acetone.  Thought they were cool though as this is my first keyboard with double shots.
Hoping I can find a cheap replacement enter,right shift, and numpad - key along with the stabs and stabilizers.  I very much want to try to use the board at work.  I've taken before pictures and tear down pictures I'll try to post in a bit.  Hopefully tomorrow I'll get it cleaned and post some after pictures.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #4 on: Sat, 08 November 2014, 07:12:45 »
Interesting. From this I can surmise that your one doesn't sound like this:
I only have the one switch, but it's very tactile and makes a loud click; it would not surprise me if a keyboard full of mine sounded like that video. (There's another question: why the distinct difference in twang pitch between keys in both Futaba and Model F?)
Bore Awards
Offline Touch_It
« Reply #5 on: Sat, 08 November 2014, 08:42:39 »
It sounds pretty similar to the video.  Noise isn't really an issue as I currently use clicky space invaders and have been contemplating using a model m or f once I finish a project and have a working one.  As far as pinging between the f and fubata the f has more of a high pitched tink and fubata is more of a plasticy thunk.  I will do some more comparing today and try to give a better description, and some audio if possible.  No pics yet.  Still in bed on my phone right now, only got 4 hours of sleep so I don't feel like being constructive yet.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Sat, 08 November 2014, 11:58:16 »
the board itself in the video resembles my leading edge dc2214..........
i have a couple of futaba's, but do not recall them being that loud?
does yours have the big honking enter on it?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Touch_It
« Reply #7 on: Sat, 08 November 2014, 13:52:09 »
 keycaps, stabs, stabilizers missing :(
closeup
all the cool kids mount the numpad enter upside down (without stabs stabilizer)?  also like the 0.
no time for XT up in herrr.
only cool people use AT.  Also this is the most heavy duty cord I've ever seen.  Love it.
first doubleshot keycaps!  Maybe I should win an award for photography. :thumb:
slightly better pic
forever unclean (no joke opening this literally made me sick to my stomach and that never happens)
spacebar for good measure
keycaps are currently soaking in warm water with ERA detergent.
about to go grab some rubbing alcohol to clean this bad boy up, and an at to ps/2 adapter to test if it even works.
  • RIP
    • Boring twaddle
« Reply #8 on: Sat, 08 November 2014, 15:58:13 »
Strange space bar stabiliser!
Bore Awards
Offline Touch_It
« Reply #9 on: Sun, 09 November 2014, 12:38:43 »
cleaned.  Has many small rust spots but decided it wasn't worth my time to fix them.
whole board cleaned.  Its hard to tell but some of the caps and case are starting to yellow but not enough for me to care really.
Here are sound clips of my IBM vs M2.  Hopefully the sound quality is satisfactory.
IBM M2
https://soundcloud.com/andrew-ellicott/ibm-m-2?in=andrew-ellicott/sets/switch-compare
Fubata
https://soundcloud.com/andrew-ellicott/fubata?in=andrew-ellicott/sets/switch-compare
Enjoy
Offline jacobolus
« Reply #10 on: Sun, 09 November 2014, 13:59:11 »
Do these have an actually snappy feel? The two futaba keyboards I have sound the same as the youtube video / soundcloud thingy above, but there’s really not much tactile feeling at all. I find both the sound and the feeling quite unpleasant.
I’ve seen it speculated that there are two types of futaba switches, one that’s linear-ish (the type I have) but that makes a metallic sound, and one that’s actually quite clicky, with a feel somewhat like a buckling spring. I haven’t found any evidence that sufficiently confirms that these two types are different, and not just different people’s subjective descriptions of the same switch.
Edit:
That is absolutely different than the futaba switches I’ve tried. I wonder whether there’s a good way to find a keyboard with that very clicky type.
« Last Edit: Sun, 09 November 2014, 14:06:44 by jacobolus »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #11 on: Sun, 09 November 2014, 14:03:42 »
nice board and ansi to...........
will see if i can find mine?
Offline Touch_It
« Reply #12 on: Sun, 09 November 2014, 14:05:43 »
Do these have an actually snappy feel? The futaba keyboard I have sounds the same as this, but there’re really not much tactile feeling at all. I find both the sound and the feeling quite unpleasant.
The keys are pretty snappy for the most part.  Some of the switches have seen better days as they are no longer clicky and not as snappy.  I can feel some tactility but not a whole lot.  All and all I will refrain from posting my final thoughts on the switch until I actually use it for a day or so but It doesn't come close to the love I have for buckling spring, clicky space invaders, or SMK alps mount.  Also the case feels pretty flimsy witch is a shame.  The keycaps look really nice to me sans the yellowing and a molding error and I absolutely love the cable.  I still want to track down some repalcement keycaps for it but I'll just say that I'm happy that I only payed 5 dollars for it.
Offline jacobolus
« Reply #13 on: Sun, 09 November 2014, 14:10:58 »
Interesting, I wonder if the keycaps from this SKR-2233 would work on Touch_It’s board:
http://www.ebay.com/itm/200988484329
(Probably not worth the money for this use case either way, and I suspect they might be some other type of keycap mount... but still, cute video editing keycaps.)
Oh, here’s a cheaper one: http://www.ebay.com/itm/261652720409
« Last Edit: Sun, 09 November 2014, 14:12:38 by jacobolus »
Offline Touch_It
« Reply #14 on: Sun, 09 November 2014, 14:20:10 »
:D the green enter would look cool on my board :D
  • RIP
    • Boring twaddle
« Reply #15 on: Sun, 09 November 2014, 17:54:31 »
It's a pity the M2 was so problematic, as it looks good and sounds good too.
The EAT-1010 sounds quite nice too. Of course, considering that people mistake some rubber domes for being linear I'm still none the wiser about whether linear Futaba "clicky" switches exist or not. Maybe one day Ascaii will get around to selling his one to me (it's been on sale for ages).
Bore Awards
Offline Touch_It
« Reply #16 on: Sun, 09 November 2014, 17:55:55 »
It is a shame about the m2 as I love mine but it is such a (insert bad word) to work on I dread it.
Offline jevvix
« Reply #17 on: Sun, 09 November 2014, 20:26:39 »
Yes, they sure do:
Of course for the stabilized keys ymmv.
  • RIP
    • Boring twaddle
« Reply #18 on: Mon, 10 November 2014, 02:22:51 »
Ah right, so the top one is the rubber dome version that takes the same keycaps.
Bore Awards
Offline Touch_It
« Reply #19 on: Mon, 10 November 2014, 10:46:28 »
Brought it to work today.  Plugged it in.  It works fine.  Interesting to type on, though missing the enter and shift keys makes it hard to type on.  Haven't typed long enough to form an opinion yet but It feels a bit spongy.  This might be due to the fact some switches are wore out.  It does sound pretty good though but seems to be to loud for work.  It also seems to be rather fatiguing to type on.
