Author Topic: Unpopular Keyboard Opinions  (Read 1729927 times)
Offline argentstonecutter
  • Greetings, programs!
Re: Unpopular Keyboard Opinions
« Reply #6200 on: Mon, 01 January 2024, 16:14:41 »
6. "They don't make them like they used to." The standard build quality on vintage keyboards is better than 95% of the crap being mass produced today.
I worked for Honeywell in 1978 and we had the BEST keyboards. I really miss discrete Microswitch keys.
« Reply #6201 on: Mon, 01 January 2024, 20:26:29 »
This may be absolute heresy on a board like this, but I kinda like rubber domes more than mechanical switches. Idk, but I find I type faster on them. Maybe because I'm used to MX reds which are too light for me and I tend to mis-hit keys.
Dell L100 is a nice keyboard. But my wrist is hurting a lot less since I got a mechanical with Silent Limes.
Offline iri
« Reply #6202 on: Tue, 02 January 2024, 05:19:37 »
wow, an old furry
-Ray Bradbury
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #6203 on: Tue, 02 January 2024, 06:39:41 »
65 and 75 are senseless
HHKB (keyboard) is overrated (quality of case, inconsistency)
salvation is bad keyboard due usb cutout and qc
meletrix is bad budget option
vintage blacks are overrated
why is 65 and 75 senseless?
hhkb underrated
idk what salvation or meletrix are ngl
vintage blacks are overrated indeed
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline mohawk1367
« Reply #6204 on: Tue, 02 January 2024, 06:42:33 »
awesome. i have 2 honeywell keyboards but both are hall effect
« Reply #6205 on: Wed, 03 January 2024, 10:53:24 »
Yeh, those were the ones. https://deskthority.net/wiki/Micro_Switch_SW_Series
Offline LavenderB
  • I believe in unix control supremacy
« Reply #6206 on: Fri, 05 January 2024, 03:48:50 »
1. 68 keys aren't enough. 84 keys are too many. I need all of DEL/HOME/PGUP/PGDN/END as separate keys, but the only key I use in the FK row is escape.
So an FRL TKL layout? Those have been growing in popularity lately.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
« Reply #6207 on: Fri, 05 January 2024, 06:37:43 »
FRL TKL doesn't give you a place for both ESC and "`~". An XT column on the left would do that (65XT). Or 71 key, with the "`~" on the right like this...
« Last Edit: Fri, 05 January 2024, 06:57:32 by argentstonecutter »
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #6208 on: Fri, 05 January 2024, 06:53:26 »
FRL TKL doesn't give you a place for both ESC and "`~". An XT column on the left would do that. Or 71 key, with the "`~" on the right like this...
I mean it kinda does, you can split the backspace and get both keys (but if you prefer regular backspace then you have to use layers then)
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
« Reply #6209 on: Fri, 05 January 2024, 08:13:04 »
65% with a split backspace and split left shift would work as well, there's lots of options once you start splitting keys, but then it's not 68 keys any more. And boards with split keys are even harder to find.
Offline VaporKeebs
« Reply #6210 on: Sun, 07 January 2024, 19:56:36 »
Unpopular for the general public... split backspace should be the norm.
We dont need the backslash to be that big. And it frees up space for the tilde and the backslash.
Offline Rhienfo
« Reply #6211 on: Sun, 07 January 2024, 23:48:18 »
I'd agree with that, actually why is regular backspace the norm, that would be interesting to know if there is a reason
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline bkrownd
« Reply #6212 on: Mon, 08 January 2024, 02:11:29 »
If there's a key that needs splitting it's the waste-of-space spacebar.  Backspace should be below the "v" key, space should be below the "n" key.  Both about 2u.
Offline Prince Valiant
« Reply #6213 on: Mon, 08 January 2024, 08:12:00 »
Seems to be the norm for non-standard splits like Kinesis Advantage and Ergodox where they have it 2U vertical plus additional keys in a cluster. I tend to favor my right more than my left for space duty but, on a leading space I will sometimes use the left. I might remap mine and see how frequently I end up backspacing characters :).
« Reply #6214 on: Mon, 08 January 2024, 08:59:40 »
Easier to identify and slap at it with a pinky is my guess.
Offline Rhienfo
« Reply #6215 on: Mon, 08 January 2024, 20:22:57 »
I mean you are probably right, but idk I like having a big spacebar unless I'm on an ergo board/anything below a 60%, just feels and sounds good
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline iri
« Reply #6216 on: Tue, 09 January 2024, 02:56:14 »
I'm so happy there is always a spacebar under my left thumb as the right one is non-operational
-Ray Bradbury
Offline mohawk1367
« Reply #6217 on: Tue, 09 January 2024, 06:40:13 »
using your thumb to hit space?!!??  :eek:
« Reply #6218 on: Tue, 09 January 2024, 07:30:00 »
Of course! Always.
Do you send a finger down there to make the hit?
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Offline mohawk1367
« Reply #6219 on: Tue, 09 January 2024, 07:44:39 »
Of course! Always.
yes...  :-X
« Reply #6220 on: Tue, 09 January 2024, 08:33:09 »
Of course! Always.
yes...  :-X
Maybe give the thumb a try sometime :cool:.
Offline mohawk1367
« Reply #6221 on: Tue, 09 January 2024, 09:09:08 »
Of course! Always.
yes...  :-X
nah too much pointless effort
Offline tricheboars
  • Keyboards are Important!
« Reply #6222 on: Tue, 09 January 2024, 11:06:57 »
completely stock HHKB hybrid (not silenced) is the best keyboard in the world. no lubing needed. no type-s.  bliss
Offline iri
« Reply #6223 on: Tue, 09 January 2024, 17:15:05 »
Both thumbs. That's how touch typing is supposed to work. For a person with 10 functional fingers that is.
-Ray Bradbury
Offline mohawk1367
« Reply #6224 on: Wed, 10 January 2024, 06:40:38 »
just too much for me to re-learn typing with minimal returns
« Reply #6225 on: Wed, 10 January 2024, 06:51:31 »
to re-learn typing
Honestly, it is hard for me to imagine a style of "typing" that does not utilize the the thumbs on the space bar.
What do they do? Or are they simply sidelined?
Offline mohawk1367
« Reply #6226 on: Wed, 10 January 2024, 08:06:50 »
to re-learn typing
nothing lol they just chill unless im playing a game then my left thumb is jump like everyone else
Offline bkrownd
« Reply #6227 on: Wed, 10 January 2024, 16:31:21 »
  I hope they're teaching typing in school at a younger age these days so kids don't stick to improvised bad habits.  It's painful to watch my dad do the hunt-and-peck thing his entire life because they didn't teach typing to boys in the era he was in school.
Offline TomahawkLabs
« Reply #6228 on: Wed, 10 January 2024, 16:35:18 »
to re-learn typing
This hurts my brain. I don't use any other digit on my spacebar than my thumbs.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline bkrownd
« Reply #6229 on: Wed, 10 January 2024, 16:46:36 »
I'm guessing it starts with people who have to look at the keys pulling their hands back to see them.
Offline mohawk1367
« Reply #6230 on: Thu, 11 January 2024, 08:09:30 »
they are. the first typing class i can remember was probably around 5th or 6th grade but i had been typing since the age of 2 so it was still late for me
Offline iri
« Reply #6231 on: Fri, 12 January 2024, 18:08:23 »
Ah, typing classes!
305536-0
-Ray Bradbury
Offline Souffle
    • Souffle
« Reply #6232 on: Sat, 13 January 2024, 05:10:28 »
I agree with this. We were never taught how to type correctly at school. I hit around 120 WPM average, which is fine, but I'm not typing correctly. However, complete computer illiteracy is a bigger problem that seems to be creeping up. Kids are turning 12 and still don't know how to create a folder on Windows. I don't work in the education sector, but some friends do. Most kids are alright with it, but the only exposure for some seems to be phones, tablets and consoles. So it's not their fault, but it's pretty alarming that they are not being exposed to such vital equipment. I wonder what's going on at the elementary/primary level for that to happen.
Offline bkrownd
« Reply #6233 on: Sat, 13 January 2024, 15:22:47 »
Keyboarding class was my worst grades in high school.  I got a C- or maybe even a D+.  I was only good at subjects where "winging it" could succeed, and keyboarding took practice LOL.  But like most of school keyboarding class created an ergonomic foundation I was able to build on later when I started working on the computer in undergrad.  (It's far more about ergonomics and efficiency than "WPM")
Offline Souffle
    • Souffle
« Reply #6234 on: Sat, 13 January 2024, 16:10:56 »
We were never taught proper keyboard skills. Most of our lessons were on how to use Windows shortcuts rather than proper typing. Ergonomics were never mentioned for us.
Offline bkrownd
« Reply #6235 on: Sat, 13 January 2024, 17:11:33 »
It was an elective class for us, so maybe 20% of our school took Keyboarding class.  Which was entirely on typewriters BTW - hammers hitting ink ribbon onto manually fed sheets of paper - whack whack zhhht DING!  :D  Even fewer students took the Programming elective, but the glorious modern Apple ][e computers were so expensive not everyone could get into Programming class.
Offline marksen
« Reply #6236 on: Sun, 14 January 2024, 06:38:07 »
Emacs uses control-FBPN for cursor movement, because Richard Stallman hates you.
  • Forward, Back, Previous, Next are easy mnemonics.
  • Every Emacser makes their own bindings anyway.
  • But yes, Richard Stallman does hate you/everyone.
Offline iri
« Reply #6237 on: Sun, 14 January 2024, 08:39:14 »
For the movement? I use the default ones.
-Ray Bradbury
Offline bkrownd
« Reply #6238 on: Mon, 15 January 2024, 01:36:45 »
I'm happy to say that EMACS was banned from our machines long ago for being a resource hog.  VIM forever!
Offline Demonseed Elite
« Reply #6239 on: Mon, 15 January 2024, 17:18:12 »
Bah... Nano FTW.   ;D
Offline mohawk1367
« Reply #6240 on: Tue, 16 January 2024, 06:38:54 »
Ah, typing classes!
we used a thing called Type to Learn or something like that with weird little cartoon people. i think you're older than I am lol
Edit: nvm apparently Type to Learn is over 30 years old and its just had multiple versions
Offline mohawk1367
« Reply #6241 on: Tue, 16 January 2024, 06:40:43 »
I didn't have it in hs but in middle school it was one of my worst (though it didn't matter cuz middle school grades barely affected anything) because didn't do anything and our teacher barely cared. we all just played Minecraft together or other games
Offline TWX
« Reply #6242 on: Thu, 15 February 2024, 20:17:22 »
Bah... Nano FTW.   ;D
Now listen here, n00b...   ;D
In all seriousness I used pico/nano for 20 years before I needed to do massive amounts of regular expression parsing, typically as a result of taking network device mgmt console output and working with it.  I planned a network switch lifecycle project spending around $10,000,000 across more than 700 telecom closets where I had to gather information on total port usage, PoE usage, PoE type, etc, where the existing switching topology had been haphazardly upgraded or supplemented.
vi made it very easy to take the captures that my scripts collected, process those into CSVs, and import them into spreadsheets in a way that let me save probably $3,000,000 compared to if we had done what a consultant recommended, which would have been replacing like with like without consideration for usage, density existing port count, etc.  I could never have done that regular expression work in pico/nano.
Admittedly I've never used EMACS, but every time I heard about this-or-that feature added to it, it reminded me of 4DOS and the integration of a bunch of crap into something that didn't need it.  I'd heard people say of EMACS, "It's a great operating system, but a ****ty editor."
TWX
C:\>echo y|format C: /q
Offline mohawk1367
« Reply #6243 on: Fri, 16 February 2024, 06:43:58 »
i was still typing over 120 wpm at the time though since i had been learning years earlier on my own (but i do type "improperly")
Offline TimeRelapse
« Reply #6244 on: Tue, 20 February 2024, 23:11:12 »
Kohaku is a mid board, pretty weight but that's about it to me... I also don't enjoy 65% layouts so I guess that's probably part of the cause as well
Offline sarahn27
    • Null Design Co
« Reply #6245 on: Tue, 12 March 2024, 14:37:27 »
Favorite layout is a 96%  :-X
Offline _rubik
« Reply #6246 on: Wed, 20 March 2024, 17:15:51 »
Oh god. We're talking about Emacs again. As is my sworn duty, I have to fan this flame. Emacs with Vim bindings (evil mode) is the only correct answer here :disappear:
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« Reply #6247 on: Fri, 22 March 2024, 01:31:52 »
I find the extra 26% on my boston really make a 96% layout shine :)
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline G
« Reply #6248 on: Fri, 29 March 2024, 00:20:10 »
There should be more 80%s with a numpad instead of the nav cluster and arrow keys. You would get access to all the keys on a full size with the press of NumLock.
Have to agree, never got all the hype around it. The Jaguar is a far more striking board from the same designer yet seems to garner less attention. All due respect, the Kohaku is borderline uninspired to me. From an aesthetics POV, even the simplest seamed two-piece wedge design seems more appealing. The back is cool and all, but that's about it.
Typing on a: Lynn Montage | Cherry MX Red | Top Mounted Aluminum Plate | Cherry 3000SAV dye-sub
Offline _rubik
« Reply #6249 on: Fri, 29 March 2024, 17:11:03 »
I'll agree to this only if it's a southpath numpad or split board. I'm not lugging my hand all the way across my desk just to click my mouse
