Author Topic: extra diode markings, D1, D3, X1  (Read 5651 times)
Offline gcb
« on: Fri, 07 November 2014, 11:22:20 »
hi. i'm cannibalizing some older boards for a new project, and i have several of the same board all with identical revision number, etc... the only difference being some extra markings on the (pretty huge) SMD diodes.
they are  all type 100-10L. with a circled 2 underneath. but a few have "D1" and others "D3" and on another set of boards i have the exact same part except it has "X1" and yet another has "B6"
what those mean?
i could find some weird data sheets for 100-10L and it is a rectifying zener, or so i hope :)
here are somebody else's pic of what i have
Re: extra diode markings, D1, D3, X1
« Reply #1 on: Fri, 07 November 2014, 17:15:15 »
pretty sure the 100-10L device is a capacitor, not a zener diode. It's also labelled C108A and C109 on the silkscreen. I'm not seeing D1 or D3 anywhere (though D2 is a pretty huge diode on teh far right.
In general: D -> diode R -> resistor C-> capacitor X (sometimes Y) -> crystal oscillator L -> inductor J -> jack (sometimes pin or jumper)
I was able to stalk-down that guy's photobucket (this specific image is the last on page 5, you can see 2 more on p6) and find the device, an xk3y. still looking for better photos of the PCB.
on google images, I see at least three different revisions of the PCB as well as a not inconsiderable number of fakes and knockoffs. SOme of the best photos from here show a different revision than youy have linked as well as what appears to be the same PCB but with green sodlermask and different component selection. Notice how the C108 and C109 SMD are now SMD metal can capacitors (which are much taller and probably a little cheaper)
http://modcontrol.com/review/x360key/11.JPG
http://modcontrol.com/review/x360key/28.JPG
^looks hand soldered. Is this a prototype?
« Last Edit: Fri, 07 November 2014, 17:30:22 by dorkvader »
Offline gcb
« Reply #2 on: Sat, 08 November 2014, 14:52:17 »
thanks for the info dorkvader.
just clarifying, mine is not like that on the picture. believe it or not, that was the closest i've found online for the part :)
mine is exactly the same, but the markings are:
100 - 10L
D1   (2)
or
100 - 10L
D3 (2)
and the board marks them on silk screen as:
- TC1
- TC2
- CM3
the boards i'm taking components out are all the same model, but one board has all D1s and another D3s. even if they are caps, i'm still curious about the difference  now :D
Offline gcb
« Reply #3 on: Sat, 08 November 2014, 15:02:36 »
The plot thickens! and also, it is not off-topic anymore :)
i got a couple days ago a keyboard for parts from massdrop to fix i though had a defect (it turned out to be just a design flaw)
but when comparing my board with the one in the beat up keyboard they sent as a replacement, i noticed the exact same parts!!! with the exact same difference!
now i'm double curious :D
i will try to upload pics soon. damn phones now come all without microSD cards. being a paranoid never made life so difficult to take pics out of a phone as nowadays
here is my Tex Yoda mainboard, it uses 100-10L D1 (2)
And here is the replacement they sent from a beaten up keyboard for parts or something. it uses 100-10L D3 (2)
« Last Edit: Sat, 08 November 2014, 15:33:41 by gcb »
Offline gcb
Re: extra capacitor markings, D1, D3, X1
« Reply #4 on: Fri, 14 November 2014, 14:12:31 »
So, any ideas what the D1 and D3 markings mean?
the two keyboard boards are the same except for it.
look for example on the two pictures, the top right most component.
Offline 0100010
  • Not Sure
« Reply #5 on: Fri, 14 November 2014, 17:24:04 »
Offline gcb
« Reply #6 on: Sun, 16 November 2014, 11:38:02 »
thanks!
also, that pdf list it sometimes as date code and others as data code :) so much for proof reading documentation
