Author Topic: Need help finding 7x spacebar  (Read 2284 times)
Offline Jixr
« on: Sun, 09 November 2014, 19:29:40 »
Hi everyone, I'm looking to try to find a 7x spacebar and a pcb mount stabilizer for it  ( or really just the wire )
I would really want a cherry/cherry profile spacebar, with the pointy corners to match the rest of my set.
Would really like a beige/white one if possible.
Anyone know where to find this kinda stuff?
Offline Flyersfan1
  • Hi!
Re: Need help finding 7x spacebar
« Reply #1 on: Sun, 09 November 2014, 19:32:53 »
SP has a large inventory of 7x space bars, with high quality images of the colors. I'd say that's probably your best bet. Stabilizers might be a little more tricky.
Quote from: Photekq
Offline frosty
  • jukebox hero
« Reply #2 on: Sun, 09 November 2014, 19:34:10 »
Many vendors have bought stabilizers from Ivan's recent GB, maybe you could wait. Or buy then from GON.
Offline HPE1000
  • Keycap Paparazzo
« Reply #3 on: Sun, 09 November 2014, 20:10:40 »
Ok I have the spacebar wire covered.
I will send imsto a message on here and see if his cherry 7x spacebars are ready to go and available to people who didn't purchase the BSP keycap set. If that is the case i will get one for you and buy a hammer keycap for myself to offset shipping costs.
Sound good?
Offline DzyDzyDino
« Reply #4 on: Mon, 10 November 2014, 10:52:33 »
Hey, where were you able to find a 7x stabilizer? I'm really desperately searching for stabs, especially ones with straight wires instead of with the bump in the middle, mainly for 7x, but also for 6.25... just pretty much any cherry stab. pcb or plate.
I know Costar ones can be found at wasd and mechanical keybd, but those clip into all my keys. I think maybe without the bump in the wire they wouldnt? I'm not sure though. If that's the case then I just need wires.
Offline 0100010
  • Not Sure
Offline DzyDzyDino
« Reply #6 on: Mon, 10 November 2014, 11:37:23 »
http://www.gonskeyboardworks.com/stabilizers/90-wire-for-spacebar-stabilizers.html
I was afraid that was what you'd reply with. lol.
Yeah, I'm aware of that. And I have my shopping cart sitting full of the items I need....
It's just...
That shipping to the us is killer.
Ah well. if i can't find anything by the end of the week i'll just have to bite the bullet.
Thanks though!
