Author Topic: Tapatalk issues  (Read 1465 times)
Offline radio_killah
  • Chinchillin'
Tapatalk issues
« on: Fri, 14 November 2014, 23:37:39 »
Anyone else having issues with tapatalk connecting to geekhack? My phones browser says it has an unsafe certificate now and won't connect the app to the site. :/ not sure what to do.
Offline lightsout714
Re: Tapatalk issues
« Reply #1 on: Fri, 14 November 2014, 23:48:54 »
Yes I can't connect either with Tapatalk. Had to use browser and I am also showing the certificate is bad but I entered anyways.
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Tapatalk issues
« Reply #2 on: Sat, 15 November 2014, 00:23:58 »
So I guess I wasn't the only one last night...
Offline iMav
  • geekhack creator/founder
Re: Tapatalk issues
« Reply #3 on: Sat, 15 November 2014, 01:29:31 »
Posting this from Tapatalk.  Had to remove and re-add the forum.
(All cert issues should be resolved now as well)
Offline Belfong
Re: Tapatalk issues
« Reply #4 on: Sat, 15 November 2014, 02:47:42 »
Yup, removing and adding back works for me. Thank you iMav, sir.
