Author Topic: Help - Scorpius M10 or Cherry G80-3000  (Read 4381 times)
Offline Roller5435
« on: Sat, 25 July 2009, 11:34:03 »
New to the forum and I'm looking to purchase a Scorpius M10 or Cherry G80-3000 (G80-3000LSCRC-2) -Blue Cherries.  Any advise on which on to purchase?  :help:
Any advise or feedback on either board would be greatly appreciated.  Also, if anyone has purchased the Cherry recently  please let me know where you purchased it.
Thank You
Offline ch_123
« Reply #1 on: Sat, 25 July 2009, 11:42:43 »
Quote from: Roller5435;104316
Thank You
Both are meant to be good, there used to be some reliability problems with the Scorpious, but I don't think it's as common any more and they've probably fixed whatever it was that was causing it. Tbh, pick whichever one is the cheapest.
Offline Roller5435
« Reply #2 on: Sat, 25 July 2009, 11:43:24 »
United States
Offline huha
« Reply #3 on: Sat, 25 July 2009, 11:44:05 »
What's the price of each option?
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ch_123
« Reply #4 on: Sat, 25 July 2009, 11:45:24 »
There's also the Filcos, but they're going to be a good deal more expensive than either the Scorpious or the G80.
Offline Roller5435
« Reply #5 on: Sat, 25 July 2009, 11:51:18 »
It appears that the Scorpious M10 is cheaper - $59.99 with shipping (http://www.buy.com/retail/product.asp?sku=205713562&listingid=18341587&dcaid=17902)
or
http://www.totalbarcode.com/part-number/G80-3000LSCRC-2.html?src=TBGB (won't be in stock until August 27th - confirmed with Sales) :shocked:
The Scorpius is a little cheaper, but I wasn't sure about the quality of the M10 vs. the Cherry.   I also wasn't sure about which form factor/style is better :decision:
Offline huha
« Reply #6 on: Sat, 25 July 2009, 12:26:30 »
Style depends on your taste.
I don't know what the M10's keycaps feel like, but I love the feel of Cherry's keycaps. Very hard and sturdy plastic.
I don't know the price of shipping, but you'll probably be fine with the M10 if the G80's style doesn't win you over. They're both using the same switches, so there's not that much of a different.
Does the M10 employ plate-mounted switches or also PCB mounted ones like the G80? If it has plate-mounted switches, I'd prefer the M10.
-huha
Offline patrickgeekhack
« Reply #7 on: Sat, 25 July 2009, 12:34:54 »
I have never used an M10, so I cannot comment on it. However, I do own two G80-3000 and I can say they have been my favourite keyboards for a while now. If the G80-3000 was not a great keyboard, I would not have bough another one :-) One thing worth mentioning though is the scooped F and J keys. They do take some getting used to, but did not take very long for me.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline huha
« Reply #8 on: Sat, 25 July 2009, 14:20:04 »
The switches are plate-mount switches, while the PCB also allows for PCB-mounted switches (the holes are there).
-huha
Offline timw4mail
    • https://timshomepage.net
« Reply #9 on: Sat, 25 July 2009, 17:09:12 »
That's funny, when I looked at the PCB of my M10 it was a lot cleaner...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline Roller5435
« Reply #10 on: Sat, 25 July 2009, 18:17:18 »
AAAAGGGGHHHHH - I ordered an M10 earlier today and the solder pictures have made me :scared:. (just kidding)
Thanks everyone for the comments and I am excited to get the M10.  This will be my first mechanical keyboard and I don't believe it will be my last (this sickness appears widespread in this forum). :thumb:
Offline cmr
« Reply #11 on: Sat, 25 July 2009, 23:21:38 »
don't get an M10, the soldering really doesn't hold up. i just finished putting another pair of jumpers on mine to fix the comma key.
i was just in there, and if this design is not what "PCB mounted" means, then i can't imagine what is. the switches are soldered directly to the PCB. what's worse, the failure mode, as far as i can tell, is that the PCB trace conductor tears, rather than the solder simply coming away from it, so the only fix is to jumper it (or throw the whole thing away)
« Last Edit: Sat, 25 July 2009, 23:24:37 by cmr »
Offline cmr
« Reply #12 on: Sat, 25 July 2009, 23:39:06 »
ouch
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #13 on: Sun, 26 July 2009, 06:42:47 »
If the traces lift, then I'd guess the switch was not sitting neatly on the board during assembly. One can call the G80's case cheap all day long, but at least reliability is not a problem.
Offline timw4mail
« Reply #14 on: Sun, 26 July 2009, 08:26:02 »
Quote from: cmr;104414
How long have you had your M10? I looked at my PCB the other day, and the solder job was gorgeous. Very neat, consistent, and in one piece.
« Reply #15 on: Sun, 26 July 2009, 10:47:19 »
Quote from: keyb_gr;104456
True. When I was looking to buy my first G80-3000, I checked out many reviews and did not see anything against its reliability. I did see comments against their cheap cases like you said.
Offline skyian
« Reply #16 on: Sun, 26 July 2009, 11:24:52 »
I would be waiting for Scorpius M10 BackLight Edition.
I saw that on Computex 2009 in Taipei, Taiwan.
It's just like a better version of Steel 7G and even with a Backlight function.
With the function key, one could change the back light just like DECK does.
If the quality is okay, and made with cherry blue or brown switch, I would consider of getting one in Taiwan.  ^_^
Plus, I have Cherry G80-3000 with black, white, brown, blue, and red switches. They are all different keyboards. Maybe you could try before you get one, if possible.
« Last Edit: Sun, 26 July 2009, 12:06:52 by skyian »
My Own Keyboards:
RF 103 SILENT 30g, RF RGB, RF103black, RF103white, RF87UB, RF87WB, RF101, HHKB PRO2, Cherry with white, blue, brown, black, RED swithces...etc
WAITING FOR THE Ultimate Bluetooth converter for any keyboard.  Also the Beautiful GMK CAMPING Keycap.
Offline timw4mail
« Reply #17 on: Sun, 26 July 2009, 11:53:47 »
Quote from: skyian;104490
With the function key, one could change the back light just like DECK do.
Plus, I am Cherry G80-3000 with black, white, brown, blue, and red switches. They are all different keyboards. Maybe you could try before you get one, if possible.
What are the red switches? An phased out switch?
Offline skyian
« Reply #18 on: Sun, 26 July 2009, 12:05:34 »
Quote from: timw4mail;104493
Just on the contrary, Cherry keyboards with "All Red Switches" were just available in Japan, 2008, then in China and Taiwan. I bought my black cherry with red switches in Feb, 2009.
The touch of cherry red switches is quite unique to other 4 switches. I guess probably some of you guys in USA tried that, too. ^_^
My Own Keyboards:
Offline cmr
« Reply #19 on: Sun, 26 July 2009, 12:11:24 »
Quote from: timw4mail;104464
7½ months
Offline huha
« Reply #20 on: Sun, 26 July 2009, 12:20:48 »
Quote from: skyian;104496
Could you please, please, please dissemble one and make photos?
I'm especially interested in the keystem. It would be really nice if you could make photos with a referece grid in them, e.g. graphing paper. Like so:
I do have a suspicion concering reds, but I need pictures for further analysis.
-huha
« Last Edit: Sun, 26 July 2009, 12:57:45 by huha »
Offline timw4mail
« Reply #21 on: Sun, 26 July 2009, 12:48:19 »
Quote from: cmr;104497
7½ months
Perhaps the quality has vastly improved in the 3 or so months between the time you acquired your to the time I acquired mine.
Offline timw4mail
« Reply #22 on: Sun, 26 July 2009, 13:16:38 »
Quote from: ripster;104525
Hope so... that last Amazon review was scary.  That was a 10 month old keyboard.
The one with the hot glue all over?
Offline cmr
« Reply #23 on: Sun, 26 July 2009, 13:39:55 »
i don't mind the hot glue. just the crappy soldering. if they have fixed it i think they should change the model name.
Offline timw4mail
« Reply #24 on: Sun, 26 July 2009, 15:40:49 »
Quote from: ripster;104559
This was the latest amazon review.
We'll see how it goes, but I don't think I'll have too many issues.
Offline cmr
« Reply #25 on: Sun, 26 July 2009, 22:05:30 »
i've had to jumper both keys i've had fail so far. i think the trace itself is tearing.
Offline lal
« Reply #26 on: Mon, 27 July 2009, 07:17:13 »
Quote from: huha;104499
Could you please, please, please dissemble [a red Cherry MX switch] and make photos?
Huha, don't know what you're after in particular, but AFAIK red MX are really only blacks (i.e. linear) with the lighter springs from the blues (or brown? not sure).  And the stem is red instead of black, obviously.
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline huha
« Reply #27 on: Mon, 27 July 2009, 07:59:25 »
Quote from: lal;104640
I'm not entirely sure. Take the loathed spacebar switch of MX browns boards, for example--you'd think it's a grey coloured brown keystem with a harder spring, but it's not. The plastic portion providing tactility is actually shaped differently.
Could be the same with reds for all I know, so that's why I'd be interested in detailed pics.
-huha
Offline lal
« Reply #28 on: Tue, 28 July 2009, 03:41:44 »
Quote from: huha;104643
Okay, I didn't find a detailed dissection of the red MX with pictures.  Someone gotta step up to that task.  For discussions including comments by the wise Sandy55, stating it's identical to black MX with spring from brown MX, see here and here.
Offline itlnstln
« Reply #29 on: Tue, 28 July 2009, 08:14:40 »
I wonder why there aren't any keyboards available here with red switches.  I would think they might show up in a gaming 'board since they are linear like the blacks, and I would have thought that Filco would have an English 'board with reds available, too.
Offline itlnstln
« Reply #30 on: Tue, 28 July 2009, 10:53:24 »
I guess Deck's extensive market research showed that gamers prefer stiffer switches.  I, for one, don't/didn't really care much, but for pure typing, though, the lighter the better.
Offline huha
« Reply #31 on: Tue, 28 July 2009, 11:38:12 »
Quote from: lal;104941
I already asked Sandy55, but he didn't have reds.
-huha
Offline timw4mail
« Reply #32 on: Tue, 28 July 2009, 12:54:41 »
Quote from: ripster;105038
I'm still trying to figure out why Deck went with Cherry clears.
I wish their forum users would offer more insightful comments than this:
My guess is that they are the closest in force to the Cherry Blacks in their other boards, they are tactile, and they aren't very noisy.
Offline cmr
« Reply #33 on: Tue, 28 July 2009, 16:51:33 »
i finally get the M10 back to work and on day 1 i've lost the numpad 0.
great.
okay, i'll take it back home and resolder it again.
