Author Topic: Some help about poker 2!  (Read 1864 times)
Offline dodzylla
« on: Sat, 29 November 2014, 12:29:35 »
Hello guys!
Can somebody help me ?
I want a keyboard like this (mxbrown and backlight):
http://www.amazon.co.uk/KBT-Poker-Mechanical-Keyboard-backlight/dp/B00GERIV72/ref=pd_sim_sbs_computers_4?ie=UTF8&refRID=1R6RJ6NRXKD66RNN5DE9
everything is perfect, backlight, very compact, i want something like this but with numpad, i love when no space between keys, this is the best compact i ever seen, just i want numpad:S
Thanks
DOD!
Offline Rotaku
  • Too Based
Re: Some help about poker 2!
« Reply #1 on: Sat, 29 November 2014, 12:34:42 »
Well you can either buy a separate numpad and get a poker 2, or you can also get the cm storm quickfire tk. There may be other options, but i cant think of any off the top of my head.
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline dodzylla
« Reply #2 on: Sat, 29 November 2014, 12:37:48 »
thanks your answer!
There is what i want:
COMPACT!!
ISO layout
Mx brown
backlight
but this one is wonderful!
Offline Sagii
  • Time to bust some nails
« Reply #3 on: Sat, 29 November 2014, 13:31:27 »
thanks your answer!
COMPACT!!
ISO layout
Mx brown
backlight
Ehr.. If you want something compact, I guess the closest you'll get to something WITH a numpad already accessible somehow, would be a keycool 84 or Noppoo Choc Mini. If you want something with a DEDICATED numpad, the most compact option would be what rotaku mentioned; the Quickfire TK. However, none of the options I've just mentioned are backlit.
Sounds like your best bet would be a Poker 2 with a separate numpad, mate!
I do vaguely recall some other backlit boards with the layout just like the Quickfire TK's , but can't remember the name at the top of my head. I'll see if I find the it, but someone else probably knows already :))
EDIT: forgot to mention that you could program a numpad on the Pn layer on a poker 2. That way you'd have a numpad the same way you do with KC and Noppoo
« Last Edit: Sat, 29 November 2014, 15:12:44 by Sagii »
Offline Rotaku
  • Too Based
« Reply #4 on: Sat, 29 November 2014, 14:38:32 »
thanks your answer!
COMPACT!!
ISO layout
Mx brown
backlight
I thought the quickfire tk was backlit? At least that's what amazon says
Offline Sagii
« Reply #5 on: Sat, 29 November 2014, 15:11:38 »
thanks your answer!
COMPACT!!
ISO layout
Mx brown
backlight
Oh crap.. my bad!
