Author Topic: Boobiecaps - ☁ (.)(.) ☁ (18+ topic) Cannot be unseen  (Read 45543 times)
Offline Mandolin
  • Crystal Connoisseur
Re: B(.)(.)biecaps - soft at touch
« Reply #50 on: Fri, 26 December 2014, 19:44:54 »
All for today.
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline Buckling
  • Poker 2 Clears / Leopold 21Key Blues
Re: B(.)(.)biecaps - soft at touch (just 2 nipples pending)
« Reply #51 on: Fri, 26 December 2014, 20:01:29 »
I just don't get it. Why would you want one of these on your keyboard? It will just make you look like a tit.
Offline Mandolin
« Reply #52 on: Fri, 26 December 2014, 20:16:06 »
Innovation: Proof of concept for flexible foamy and skin like keycaps+ideal subject. You'd need to read the original IC thread. The subject is merely utilitary.
Plus, a nipple hasn't hurt anybody. You were probably all over them as a baby  :-X
#NEVERFORGET
« Last Edit: Fri, 26 December 2014, 20:36:48 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
« Reply #53 on: Fri, 26 December 2014, 20:17:08 »
The utter one is pretty great :))
« Reply #54 on: Fri, 26 December 2014, 23:07:01 »
I preordered because I really want to see soft keycaps be made and tested, it's a new material so testing and funding are required.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #55 on: Fri, 26 December 2014, 23:14:58 »
All for today.
I like how the symmetrical one is turning out =D
GON NerD TKL DTA Edition
Offline bowji
  • Came for the Keycaps, stayed for the community.
« Reply #56 on: Sat, 27 December 2014, 00:37:13 »
Gotta love the creativity involved here lol
Who would have thought typing on a "cloud of boobs" would take a literal meaning  :p
               FREE GIRLDC!!     코리안 스레드
Offline Mandolin
« Reply #57 on: Sun, 28 December 2014, 17:11:09 »
Symmetrical prototype textured (added pearled pattern). Rest are pending surface detailing and texturing. The bases are also to be evened out and sanded.
For reference , full Boob has a 1.75 cm diameter and the nipple 3 mm.
« Last Edit: Sun, 28 December 2014, 23:19:27 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #58 on: Sun, 28 December 2014, 22:21:17 »
i like it!
Offline Mandolin
Re: Boobiecaps project - soft at touch ☁ (.)(.) ☁
« Reply #59 on: Mon, 29 December 2014, 15:56:36 »
gravity boob progress
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Mandolin
« Reply #60 on: Tue, 30 December 2014, 14:28:42 »
Update.
« Last Edit: Sat, 03 January 2015, 21:04:44 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Re: Boobiecaps project - ☁ (.)(.) ☁
« Reply #61 on: Tue, 30 December 2014, 17:31:48 »
I'm really liking how the udder turned out!
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #62 on: Wed, 31 December 2014, 00:07:19 »
Update.
I ... am ... speechless.
Offline Mandolin
Gotta grab 'em all
« Reply #63 on: Wed, 31 December 2014, 20:51:01 »
New years eve special SALE
Ended January 1st 2015 23:59 GMT-3
« Last Edit: Thu, 01 January 2015, 21:01:49 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline ImBZppl
Re: Boobiecaps - ☁ (.)(.) ☁
« Reply #64 on: Sat, 03 January 2015, 14:28:33 »
Will the final product be be that wrinkly? :(
Offline Mandolin
« Reply #65 on: Sat, 03 January 2015, 20:47:00 »
Just trust me with this, wait until you see the final images properly photographed or the hold the final product
At plain sight it's not intrusive at all. The silicone keycap will be slightly translucent so, you'd see it if you look it with magnification or another aid. The different colors of the epoxy putties highlights the contrast, and that wouldn't happen with a more or less plain color.
The photos are taken under a hard light, with a good macro lens, and when resizing the image down it gets additionally sharpened.
In a small scale such as this, it's advisable to compensate a bit the texture, because if it were realistically scaled down, a important portion would get lost in perception without using a magnifier.
« Last Edit: Sun, 04 January 2015, 08:33:01 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Mandolin
« Reply #66 on: Tue, 06 January 2015, 22:58:32 »
Boring update:
I've been cleaning little dents in the sculpts with magnification, as I the prototypes were sculpted without loupes, defining edges, beveling some corners, rounding others, and making the bases as thick walled as I can. Testing fitting issues, etc.
Regarding reinforcing the base of the silicone keycaps: I bought several type of fiberglass composites, which haven't had the adhesion to the silicone I was aiming to. However, I do have some solutions on the way as I've been talking to different providers from past week, that are lengthy to explain. It involves getting the fillers to stick only to the base part, to keep the sculpt wobbly, and the stem integrity. Remember silicone only sticks to itself.
The basic alternatives were to buy fillers pretreated with an special adhesive (tried that with bad results), treating them myself (I'm in the middle of getting the adhesive), or lastly, as I came across with a self priming silicone (gonna try that this week), so it'd adhere to substrates of certain type without extra effort and could be tinted in the same coloring than the body.
I wanna sort out the problem of having one solid silicone keycap and go as further as I can with it.
« Last Edit: Wed, 07 January 2015, 00:14:10 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Mandolin
« Reply #67 on: Wed, 07 January 2015, 14:11:09 »
Boring update 2:
So, It's set. I couldn't find any commercially available option for silicones that resist wear in a day to day basis for the stem, and I'd be making it myself.
My own formula of silicone composite material for the base of the keycap will have a matrix structure set by a low viscosity polyvinyl siloxane, abrasive and tear strength proportioned by a mix of nanometric amorphous and micrometric inorganic fillers, a coupling agent and maybe a metallic oxide to disperse light evenly.
I'll be assuming the costs involved, that have surpassed what I managed to gather with the preorders, but that would mean the best possible, long lasting, flexible keycaps ever made. For the boobiecaps and future projects.
« Last Edit: Wed, 07 January 2015, 14:50:20 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Nuum
« Reply #68 on: Wed, 07 January 2015, 14:40:54 »
These updates aren't boring to me, I love to see how you approach making these keycaps. Keep it up!
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #69 on: Thu, 08 January 2015, 22:54:05 »
wait, so this isn't happeneing?
Offline Mandolin
« Reply #70 on: Thu, 08 January 2015, 23:28:57 »
Who said it isn't?  :eek:
It's super happening, and in a best shape than before, but my initial timing estimates are compromised. They could still be shipping from late january onwards, and regular orders will open only after I test everything thoroughly.
After doing some tests, I wasn't confident on the abrasive and tear strength of the best and hardest silicone I bought, so I decided to make my own reinforced syloxane composite, that'll be more like a regular plastic in hardness.
Then I tested fillers that didn't work, had to see why they failed and correct that.
Afterwards, I had to order more materials and talk to local chemical providers in order to check what's feasible (that took me most of this week). And before going further, I've got to revise my safety equipment.
The polyurethane foam are easier to do. The rigid keycaps are easy piece. Full addition cure silicone pieces are the complication, but what will look the best, and have the highest durability in time.
« Last Edit: Thu, 08 January 2015, 23:49:09 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #71 on: Thu, 08 January 2015, 23:42:43 »
After doing some tests, I wasn't confident on the abrasive and tear strength of the best and hardest silicone I could find commercially available, so I decided to make my own reinforced composite silicone rubber, that'll be more like a regular plastic in hardness.
I tested some fillers that didn't work the way I thought this week, had to see why they failed and correct that.
I had to order more materials and was talking with local chemical providers this whole week and part of the past one, to see what's feasible. They should arrive next week, but before even working with them, I've got to revise the safety equipment I have and buy some respirator filters and other things in those lines.
If anybody wants to preorder, PM me, as I'm in deep red numbers because of all the expenditures, and some extra orders would come handy.
i misread the, "boring update 2" somehow and thought it didn't work out so you were just eating the cost or something. now that i read it again i'm not sure how i got that perception.
Offline Mandolin
« Reply #72 on: Tue, 13 January 2015, 00:00:23 »
Boobiecaps are provoking  :-[
Drops jaws  :eek:
and causes giggles :)
« Last Edit: Tue, 13 January 2015, 02:49:08 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Re: Boobiecaps - ☁ (.)(.) ☁ The original FAP button
« Reply #73 on: Tue, 13 January 2015, 00:18:47 »
Yeah that post was rough, I'm excited to see the first caps.
Offline Mandolin
« Reply #74 on: Tue, 13 January 2015, 00:50:22 »
I don't mind causing a strong emotional reaction
and overall the support has been positive.
I'm working on it to have them as soon as possible  ;)
« Last Edit: Tue, 13 January 2015, 07:35:46 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline ImBZppl
Re: Boobiecaps - ☁ (.)(.) ☁ (18+ topic)
« Reply #75 on: Tue, 13 January 2015, 20:57:12 »
If it turns out like one of them oppai stress balls that would be awesome.   ;D
Not sure how they do it though.
Offline Mandolin
« Reply #76 on: Tue, 13 January 2015, 21:02:24 »
Those are a stretch fabric (polyamide or polyproilene) over a gel or foam, like some mousepad cushions. Some are just poluyrethane foam stress balls or even silicone.
I believe they'd be similar :)
Working on
- Custom keycaps
- Boobiecaps
- Others
Re: Boobiecaps - ☁ (.)(.) ☁ (18+ topic) Cannot be unseen
« Reply #77 on: Wed, 14 January 2015, 22:50:03 »
Loving the consistent updates!
Also, udder looks amazeballs so far.
Offline Mandolin
« Reply #78 on: Thu, 15 January 2015, 20:31:00 »
- Did a prototype mold with silicone putty to test Polyurethane foam adhesion to polyurethane resin. They adhere strongly, however I kept testing the PU foam I'm not convinced of the final result as the foam collapses partially compressing it and the definition of detail is not optimal (maybe it's something related to improper mixing, and waiting time before demolding and not inherent to the PU foam itself).
- final silicone materials arrived. I'll begin doing the silicone keycaps next week. Gotta prepare the molds and receive some appropriate respirator filters yet.
- Most likely I'll do all the preorders in silicone, and not PU foam, until I find one that I like (self skinning maybe).
« Last Edit: Fri, 16 January 2015, 19:45:52 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
