Author Topic: would the kul es87 be a good first mech keyboard?  (Read 2434 times)
Offline ashcraft
« on: Mon, 01 December 2014, 16:08:46 »
Title. I want to purxhase y first mech keyboard. My price limit is 130 so if you want to give advice or offer other choices it would be appreciated.
Offline Heliosphere
Re: would the kul es87 be a good first mech keyboard?
« Reply #1 on: Mon, 01 December 2014, 16:34:18 »
I've heard it's a nice, solid keyboard. If you want something that's a good bang-for-the-buck, I recommend a CM Quickfire Rapid. Have you researched what MX switch you might want?
Offline Flyersfan1
  • Hi!
« Reply #2 on: Mon, 01 December 2014, 16:37:26 »
Yes, the Keyed Up Labs ES-87 is one of the best stock keyboards you can buy in my opinion.  You will not be disappointed!
Quote from: Photekq
« Reply #3 on: Mon, 01 December 2014, 17:05:18 »
Yep. Best one you can get, save Kustoms.
Offline ashcraft
« Reply #4 on: Mon, 01 December 2014, 18:34:13 »
It seems the kul is actually out of stock, so I might go for the quick fire rapid since it also has media keys. Is there anything else that would be a great option?
« Reply #5 on: Mon, 01 December 2014, 18:39:17 »
Filco MJ2, if you can find one cheaper than amazon
you can probably get one for like $100 in the classifieds
Offline Fragil1ty
  • Abre los ojos.
« Reply #6 on: Mon, 01 December 2014, 18:41:32 »
Probably the best TKL board on the market, there is a few things that you make not like though.
- The Cherry Stabalizers, I don't like them, maybe you will.
- The keycaps are ABS and are not very nice to use, the font is amazing on the keycaps, but the keycaps themselves are not and they shine very easily.
Other than that, absolutely stellar keyboard and definitely worth the price point.
你搞砸了
Offline ashcraft
« Reply #7 on: Tue, 02 December 2014, 14:31:42 »
So I will be purchasing the quickfire rapid. Who else owns this keyboard and how do you feel about it?
« Reply #8 on: Tue, 02 December 2014, 15:18:17 »
I wish the PCB was nicer, I wish that I had modded the blacks earlier.
Offline Heliosphere
« Reply #9 on: Tue, 02 December 2014, 15:21:26 »
I used to own one with red switches. It was a good daily driver. I just wasn't using it as much anymore and moved onto other much more expensive keyboards.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10 on: Tue, 02 December 2014, 15:31:35 »
It's a fine starter keyboard, the only problem with it is the PCB.
