Author Topic: Ctrl or Control Legends?  (Read 11256 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
« on: Fri, 05 December 2014, 00:45:21 »
Just wondering, what do you guys prefer to have, Control or Ctrl on your keycaps?
The reason why I'm asking is because I've noticed that lately almost all keycaps being produced are using "Control", but what about "Ctrl", is there still any desire for it?
Some argue that "Ctrl" and "Alt" match up nicely when you look at it, but others have counter-argued that when we actually say it out loud, we say "Control, Alt", not "Control, Alternative"
So... with all that said, what does everyone prefer?
This is really trivial, but so is a lot of things in this hobby, so I thought I'd ask anyway  :p
Offline mozaiq
Re: Ctrl or Control Legends?
« Reply #1 on: Fri, 05 December 2014, 01:27:35 »
Well for me it's just that I don't like long names/printings on caps in general. So if I had the chance , I would go for CTRL. Maybe this is a matter of habit, since here in Germany, almost all native keyboards use "STRG" as a caption for the control key. So in that way I'm much more used to the abbreviation in this case. But I wouldn't rule out a keyset just because it uses Control instead of CTRL.
Offline Oobly
« Reply #2 on: Fri, 05 December 2014, 03:36:47 »
Depends on the profile and font used.
I like "Control" on GMK / Cherry sets, but most DCS profile sets I prefer "Ctrl", depending on the theme / colour scheme. For SA profile I like "CTRL", also "RETURN" on the Enter key :)
"Alternative" is a bit long to fit and I do feel that "Control" and "Alt" are okay together.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Coreda
« Reply #3 on: Fri, 05 December 2014, 04:32:47 »
'Ker-Tarl' all the way. Gotta be consistent. 'Ker-Tarl Alt Dell' just rolls off the tongue.
Macs as usual have the superior modifier - Kimm'd.
« Reply #4 on: Fri, 05 December 2014, 06:57:25 »
Control = ANSI
ctrl = I SO
Offline yasuo
  • spanengan puyeng newbie
« Reply #5 on: Fri, 05 December 2014, 06:59:05 »
i like control than ctrl and eraser than backspace :))
Logitech MK220 Colemak DH
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6 on: Fri, 05 December 2014, 08:17:25 »
Control looks nice on all the GMK sets like Dolch and OG cherry, but not on anything else
« Reply #7 on: Fri, 05 December 2014, 09:17:32 »
It should say "Control".
"Ctrl" is an abbreviation for when the key is smaller than 1.5 wide and "Control" does not fit.
Similarly, the right Alt key in some layouts should say "Alt Graph" if that fits, not just "Alt Gr".
« Last Edit: Fri, 05 December 2014, 09:20:53 by Findecanor »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8 on: Fri, 05 December 2014, 10:04:21 »
TIL
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #9 on: Fri, 05 December 2014, 10:09:12 »
Control = ANSI
ctrl = I SO
That's not true - I have a winkey cherry ISO set, control's say control.
I don't think that's true either, for the same reason as above. I have cherry sets with 1.25x that say control.
See - G80-3000HQMGB
« Last Edit: Fri, 05 December 2014, 10:11:22 by margo baggins »
I got boards.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Fri, 05 December 2014, 11:13:51 »
Control is pretty much the standard on Cherry stuff... I can only think of a few that used Ctrl or CTRL besides later 1800/11900 with 1x mods. As for personal preference, I don't really care much.
Offline ideus
  • Björkö.
« Reply #11 on: Fri, 05 December 2014, 11:52:32 »
I'd prefer * as an icon for control.  :)
Offline 0100010
  • Not Sure
« Reply #12 on: Fri, 05 December 2014, 15:23:26 »
Ctrl and Alt is what I am used to, but nothing wrong with Control and Alt, or Control and Alt Gr.
Offline HydraDyne
« Reply #13 on: Fri, 05 December 2014, 16:33:32 »
I rather Ctrl, I personally like how the letters work together in such a way.
« Reply #14 on: Sun, 07 December 2014, 01:30:31 »
Doesn't really bother me either way. I guess Control if there is room, Ctrl otherwise.  NEVER CTRL.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #15 on: Sun, 07 December 2014, 01:31:51 »
ISTR the Atari ST used "Alternate" on their Alt keys
Overton130, Box Pale Blues.
Offline jacobolus
« Reply #16 on: Sun, 07 December 2014, 01:52:23 »
IBM’s keyboard layouts and legends were okay on beam spring keyboards (pretty symbols and full words), but the little hat keys (1u wide pressable area with steps on both sides or top/bottom of the keys) on the PC XT were stupid, and forced them to use abbreviated legends,[1] which were also stupid. For that matter, all of IBM’s subsequent keyboard layout ideas were also pretty stupid IMO, right up through the 101-key layout we all have to live with today.
Because all the hardware in the IBM/Wintel computing world was made to be clones, valuing compatibility over thoughtful design or any kind of innovation, we still have to live with many of IBM’s crappy choices from the 80s today.
Anyway, to answer your question, the correct legends are “Command”, “Option”, “Control”.
[1] No room on here for full words:
Offline jacobolus
« Reply #17 on: Sun, 07 December 2014, 01:56:48 »
Should be “Alternate” and “Alternate Graph”. Though to be honest the word “graph” was a poor choice, since that’s a technical term in linguistics no one who isn’t a linguist ever uses in any context.
Offline jonathanyu
« Reply #18 on: Sun, 07 December 2014, 12:35:02 »
I like CTRL rather than Control because it give a more consistent feel since Alternative, Alternative Graph, Delete are also written in short form.
« Reply #19 on: Sun, 07 December 2014, 13:55:10 »
Thanks. I knew there was a keyboard that did it, but I couldn't quite remember which.
The Atari ST keyboard (and the rest of the computer also, btw) was quite horrible, and worth forgetting ...
Offline jacobolus
« Reply #20 on: Sun, 07 December 2014, 15:35:19 »
NeXT keyboards also used “Alternate”.
Offline SpicyLobotomy
« Reply #21 on: Mon, 08 December 2014, 20:44:21 »
I'd rather have CTRL, or just a symbol. Minimalism is beautiful on a keyboard IMO.
"Squidward, I used your clarinet to unclog my toilet"
"They don't think it be like it is, but it do?"
Offline PocoLoco
« Reply #22 on: Sat, 13 December 2014, 10:14:08 »
I personally prefer ctrl over control i think it all depends on the space available and personal preferance
Offline user 18
« Reply #23 on: Sat, 13 December 2014, 20:09:23 »
If I'm picking, I prefer to see CTRL over anything else. If it's on a set someone else designed, it wouldn't be enough to stop me from getting the set either way.
Avatar by ashdenej
Offline gravenshard
  • vagabondage
« Reply #24 on: Sat, 13 December 2014, 23:40:42 »
CTRL > Control
« Reply #25 on: Sun, 14 December 2014, 19:29:48 »
I've just realised Nuclear Data Green has CTRL legends.  Scrub my earlier comment about CTRL :p
Offline Artonkn
« Reply #26 on: Mon, 22 December 2014, 12:15:36 »
CTRL imo, Control feels too squeezed
Offline Dongulator
« Reply #27 on: Sun, 28 December 2014, 20:47:47 »
Both work for me.. everything I have does have Ctrl though. Maybe I should change that.
Offline Karura
  • SKidata life.
« Reply #28 on: Wed, 20 May 2015, 02:27:53 »
Reviving this thread from the dead, since it's been a long time.
Lately we've had a lot of GMK group buys, with the majority opting for Control over Ctrl or other alternatives, so I was curious:
Do you still prefer Control on your 1.25 keys or do I sense some need for the Ctrl legend?
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
« Reply #29 on: Wed, 20 May 2015, 02:51:08 »
I always figured that "Alt Gr" stood for "Alternate Graphic" or "Alternate Graphics" -- as in the extended character set by extending ASCII from 7 to 8 bits.
Offline baldgye
  • Will Smith Disciple
« Reply #30 on: Wed, 20 May 2015, 04:32:47 »
Ctrl Atl is life
« Reply #31 on: Wed, 20 May 2015, 06:19:35 »
« Reply #32 on: Wed, 20 May 2015, 09:55:23 »
Ctrl for consistency with Alt, Control if it's replacing Caps Lock.  It's not a big thing to me though, unlike some others that can kill a set for me.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #33 on: Wed, 20 May 2015, 09:59:27 »
This. May be that I've just become accustomed to seeing each this way but it just feels better.
« Last Edit: Wed, 20 May 2015, 16:36:11 by hwood34 »
Offline againer
« Reply #34 on: Wed, 20 May 2015, 15:59:49 »
Since I can never find matching keycaps for a swiss layout. I am used to blank keycaps. I started to like blank keycaps. You should try blanks too, they are even more minimalistic :p
Offline Karura
  • SKidata life.
« Reply #35 on: Thu, 21 May 2015, 02:00:05 »
Does anyone have photos of an OG Cherry keyboard that has the "Ctrl" legends? I know that there are boards like OG Olivetti that had "CTRL" on it, but was wondering if "Ctrl" was ever a thing. Almost all OG boards I've seen, including TA, OG dyesub, all had Control on it.
Even OG dyesub german ISO ones have "Control" on it.
Just curious to see if anyone has anything :)
Offline nightdriver
  • life is like t. rex
« Reply #36 on: Thu, 21 May 2015, 18:50:33 »
i like the all caps CTRL on the triumph adler set!
Offline nightdriver
« Reply #37 on: Thu, 21 May 2015, 18:51:17 »
oh, i also like the "escape" keycaps that have the whole word on them.
Offline Megaweapon
« Reply #38 on: Thu, 21 May 2015, 19:13:09 »
Control = ANSI
ctrl = I SO
I love Ctrl but hate ISO.  What's wrong with me??
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline KnivesM
« Reply #39 on: Thu, 21 May 2015, 19:42:10 »
I prefer Control over CTRL/Ctrl but it's not really a big issue.
Others
« Reply #40 on: Thu, 21 May 2015, 22:52:05 »
I think CTRL in all-caps should be used only if all other textual legends are all-caps. It is an abbreviation, not an initialism.
When I was in typing class back in 8th grade, I was taught that "Alt Gr" stood for "Alt Grande" ... and that I should think of it as the "Big Alternate" where as the left Alt key was the "Small Alternate" key. When looking back I think that it was only meant as a mnemonic, but I had interpreted it as gospel. I was under this false belief for a number of years ... :mad:
BTW, we had IBM PCs with clicky Model Ms back then. And nobody complained about the noise. The school official who got us them was very proud of having got "proper" computers and not Compis.
« Last Edit: Thu, 21 May 2015, 22:58:32 by Findecanor »
« Reply #41 on: Thu, 21 May 2015, 23:15:43 »
For some unknown reason to me, Alt Gr always became Alt Greel in my head.  No clue where Greel came from or what it means, just that what it be.
Offline baldgye
« Reply #42 on: Fri, 22 May 2015, 08:08:21 »
YES
Offline SamFlynn
  • Location: From inside the hive, behind your eyes, and off the grid...into the Black.
  • Type until there is no need...
    • Firefly Online Forum
« Reply #43 on: Sat, 23 May 2015, 00:21:18 »
I always felt as if Control/Ctrl should have its own symbol like Caps:
<Press Any Key>
« Reply #44 on: Sat, 23 May 2015, 01:22:32 »
The common symbol for Control is ^.
Offline Eszett
« Reply #45 on: Sat, 23 May 2015, 02:40:12 »
Why do you mix up Alt with Alt Gr, aren't both different keys?
« Reply #46 on: Sat, 23 May 2015, 12:51:37 »
YES
umm, ok.
Offline Eszett
« Reply #47 on: Sun, 24 May 2015, 15:21:57 »
Both "CTRL" and "CONTROL" are common. As a stilistic rule, write (print) a word out whenever possible. If you can't write it out due to lack of space, shorten it. Collapsed abbreviations as "CTRL", where letters inside are left out, are rather ugly, don't you think so? Or do you want to read something like "BCKSPCE"? I would rather prefer to read something like "BACK", "BACKSP." oder even "BS". If practically necessary, as for an 1u for example, "CTRL" is tolerable, though.
« Last Edit: Sun, 24 May 2015, 15:29:02 by Eszett »
Offline Monophonic
« Reply #48 on: Tue, 02 June 2015, 02:49:49 »
I prefer to see full words. It's one thing I like about the Mac keyboards more. So I guess that falls into line with the counter argument you said.
I also like seeing a space between Caps and Lock
Offline chive_
« Reply #49 on: Tue, 02 June 2015, 17:55:51 »
It doesn't matter that much to me, I'd go with either if I wanted the keyset.
