Author Topic: Realforce cables @ PEXON  (Read 93779 times)
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
« on: Tue, 09 December 2014, 15:57:34 »
We are making them! Post in here if you want one, just looking at gaining some #hype before we make an order for the crimps and connectors in the next few weeks.
Would peeps be interested in me putting them online and get all the prep work done for them and have a preorder? I can make the cable up ready to go and them just pop the ends on when they arrive?! I can do both direct and detachable mods too  :thumb:
« Last Edit: Thu, 26 February 2015, 15:33:38 by pexon »
Offline awts
Re: Realforce cables @ PEXON
« Reply #1 on: Fri, 12 December 2014, 09:59:53 »
Just sort of destroyed the cable of my RealForce today... I created this account specially to get into this pre-order! (P.S. I emailed you too!)
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #2 on: Fri, 12 December 2014, 11:42:28 »
Haha, hows about that for timing! We will get a preorder page up on the site this weekend dude :)
Offline awts
« Reply #3 on: Fri, 12 December 2014, 13:31:24 »
Will definitely check back your site to do the pre-order!  :))
Offline awts
« Reply #4 on: Sun, 14 December 2014, 04:16:01 »
Still waiting diligently for the pre-order to be up!  ;D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #5 on: Sun, 14 December 2014, 06:57:15 »
I should have something up by the end of play today, considering I'm having the first Sunday off in a llooooonng time :))
Offline awts
« Reply #6 on: Sun, 14 December 2014, 11:14:02 »
No problem! I'll check back tomorrow morning when I get to work...  :p :thumb:
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #7 on: Sun, 14 December 2014, 11:24:17 »
Offline awts
Re: Realforce cables @ PEXON- Preorder open
« Reply #8 on: Sun, 14 December 2014, 12:47:15 »
Just completed my order for 2 cables! Can't wait! :p
Just to add, I realised there's a ferrite bead attached to the cable with the crimp. Is it fine if I take it off and attach to your cable when I replace them?
I'm not sure if the ferrite bead works the same way with rubber or para cord insulation...  :confused:
:D
« Last Edit: Sun, 14 December 2014, 12:54:23 by awts »
Offline awts
« Reply #9 on: Tue, 30 December 2014, 05:20:52 »
I have ordered 2 more custom black mini usb cables...  :)) :p
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #10 on: Tue, 30 December 2014, 05:49:11 »
Oh yes!
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #11 on: Tue, 30 December 2014, 08:52:47 »
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #12 on: Thu, 26 February 2015, 15:34:25 »
Realforce cables are now available :D
More pics as well as Filco style detachable kits coming in soon!
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #13 on: Thu, 16 April 2015, 15:57:54 »
Got my Realforce cable today, it is gorgeous! Pexon should know more about the fabric, since it was a surprise cable I won at the DT awards :)
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #14 on: Sun, 19 April 2015, 16:25:54 »
Super sexy genuine Carbon Fibre and Teflon sleeving. These options will be added soon
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #15 on: Thu, 23 July 2015, 03:00:18 »
Got the cable, many thanks, works like a charm! And that bonus, have to make some picture too...
« Reply #16 on: Fri, 04 September 2015, 20:56:43 »
Hey PEXON! Your cables are SOO CLEAN and well made at the Realforce end. I love it! Thank You!  :cool: Youre still the best!
Offline raymogi
« Reply #17 on: Fri, 04 September 2015, 21:05:17 »
Hot damn! I need to get one of these.
Is there an option to do this on the website? Cause I only see the Realforce mod kit, not the whole cable.
Please feed my addiction.
« Reply #18 on: Fri, 04 September 2015, 21:07:41 »
Yeah, its amazing quality!
http://pexonpcs.co.uk/products/realforce-cables?variant=1041962663
Offline raymogi
« Reply #19 on: Fri, 04 September 2015, 21:10:19 »
Thanks dustin! I didn't see that link at all.
Oh, nice Instagram btw. Thanks for the accept :D
Offline Belfong
« Reply #20 on: Fri, 04 September 2015, 21:10:24 »
I want one of these! It goes well with my RealForce Orange caps! Is there a yellow one to match the yellow caps?
Is it much hassle to replace the cable? I'm nervous opening up the case. Any videos?
« Reply #21 on: Fri, 04 September 2015, 21:14:50 »
Ray thanks man! :)
I haven't swapped it yet but I did one on my 88ub before and it was very easy. If I remember correct it was 1 screw and the clip plug in. Also the case is even easier to open. Just be careful with the plastic clips I think.
« Last Edit: Fri, 04 September 2015, 22:17:29 by dustinhxc »
Offline raymogi
« Reply #22 on: Fri, 04 September 2015, 21:16:45 »
AFAIK Realforce case is only held by clips? Should be easy. I'm scared to open stuff up too but I will do this to get rid of that ugly stock cable.
Offline Belfong
« Reply #23 on: Fri, 04 September 2015, 22:32:15 »
If that is the case, where can I buy that orange cable?!!!
Offline raymogi
« Reply #24 on: Fri, 04 September 2015, 22:34:33 »
You can customize everything there.
I just ordered a dark grey coiled one to get that SSK look on my white 55g :D
« Reply #25 on: Sat, 05 September 2015, 07:17:35 »
Hell yeah! Enjoy guys! SOOO excited!  ;D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #26 on: Sat, 05 September 2015, 10:24:44 »
Glad it got there safe brother man! Sorry for the delayed response, I actually got a few days away... first time off in 3 years  :o
« Reply #27 on: Sat, 05 September 2015, 22:19:41 »
Nice man, hope you had a good break! :D Yeah, I love this cable! It was a tad long at the Realforce end for a 23UB but it worked still. It looks nice.  :thumb: Plus a tad bit of black sticking out makes it look like a normal mini usb with the black end, hah  :cool:
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #28 on: Sun, 06 September 2015, 10:12:23 »
Awesome man! Looks good. Should be room inside to snake the cable around a little bit? Perhaps a cable tie inside the case to keep it tidy?
« Reply #29 on: Sun, 06 September 2015, 10:46:22 »
Yeah there's a bit of room on the side. When I closed the case I was able to push the white cable inside. :)
