Author Topic: Topre PBT Spacebar (SECOND RUN!)  (Read 310439 times)
Re: Topre PBT Spacebar (SECOND RUN!)
« Reply #900 on: Fri, 15 July 2016, 21:47:22 »
Maybe someone else can answer that for you; however, based on the pictures you referred, the difference you mentioned is not clear, you'd better post a side by side comparison instead, under the same light and other optics conditions, then, the difference should be clear.
I have only red ESC so can't make any real comparison, but I remember that people on this forum (maybe in the thread from the first spacebar massdrop) commented about different colors of these two. Caps Lock from elitekeyboards is little brigther than the original topre red, IIRC.
If this red PBT spacebar is color calibrated using aforementioned Caps Lock, that could be a problem, because it won't color fit anywhere else.
It would be great if someone could make direct comparison.
I think all buttons other than the space bars are made by Topre, so any color differences would be very minimal, if any.
As for the bars, matt3o spent a lot of time color calibrating them. Not sure if they're 100% matched, but they're pretty darn close.
In any case, these are your only PBT space bar options, so you have no other options.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #901 on: Sat, 16 July 2016, 05:42:12 »
white and black are color matched with a 98-99% color accuracy (matched to hhkb colors). Red and blue are in the 95-96% range (matched to special edition kit). Orange and green should be 99% (matched to original topre sets).
« Reply #902 on: Sat, 16 July 2016, 05:53:54 »
And yellow is forgotten :(
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #903 on: Sat, 16 July 2016, 05:55:40 »
pink almost made it
« Reply #904 on: Sat, 16 July 2016, 06:03:32 »
pink almost made it
That would probably have sold better than yellow :))
Maybe R3 could introduce pink and yellow .......
Offline the_marsbar
« Reply #905 on: Wed, 20 July 2016, 08:25:04 »
So it looks like more than 1600 spacebars so far. How many was ordered in the first round?
« Reply #906 on: Wed, 20 July 2016, 08:58:24 »
That's 1600 orders. Each order is at least two space bars.
Offline the_marsbar
« Reply #907 on: Wed, 20 July 2016, 11:05:33 »
Ah yes, of course. Anyway, It'd be interesting to know the numbers IMO.
Offline Shikarikato
« Reply #908 on: Thu, 21 July 2016, 16:53:32 »
if theres another run id be glad to buy a pink spacebar
white and red will have to do for now
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #909 on: Sat, 23 July 2016, 04:57:58 »
Maybe during late 2017/2018, it shall appear again  ;D .
Offline Shikarikato
« Reply #910 on: Sat, 23 July 2016, 16:21:43 »
all we have to do is start persuading every person on this planet to buy topre boards without pbt spacebars
then there will be a market and we can hit MOQ instantly
Offline zslane
« Reply #911 on: Sat, 23 July 2016, 18:01:36 »
If anyone puts one of these on a Hi-Pro board I'd love to hear how well it works out. I may get a pair for mine if they ever make them matched to "104UK biege".
Offline jessica
  • Formerly CuteDreamsOfYou & Brazzers
  • HHKB is the only good layout
« Reply #912 on: Sat, 23 July 2016, 18:16:35 »
Just joined the drop, super excited to get my hands on a few more of these :)
Good work as usual, Matt
GMK Plum /// GMK Necro
I am going to re-run these sets soon
Offline dario
  • obsessive–compulsive hardware slut
« Reply #913 on: Sat, 23 July 2016, 20:23:05 »
I'm not so sure about that. You see, it seems that there are two kinds of Topre red colors. One is of brighter shade, and the other is somewhat darker.
First would be:
- Limited Edition Control and Esc Kit
And in the second, darker red group, we found:
- complete Topre red keyset
- standalone Topre red ESC key
- standalone Topre red arrows keys
I only have a red Topre ESC key so I can't actually make any live comparison, but this is the information I got before on this forum, and judging from some of the images on the internet, it seems to be the truth. Red PBT spacebar rev1 really looks brighter and orange-like.
That's not the point.
I'm sure they will be pretty good, but it's just my OCD waiting its chance to go wild. :D
I'm sure they are, but what I'm trying to tell you is - you've calibrated your spacebars using a wrong color sample, at least in the case of red.
« Last Edit: Sat, 23 July 2016, 22:25:04 by dario »
Offline xondat
  • i'm not a star
« Reply #914 on: Sat, 23 July 2016, 20:37:58 »
pink almost made it
What is the MOQ per color?
« Reply #915 on: Sat, 23 July 2016, 23:43:32 »
First would be:
But why is it wrong if they're matched to a certain red hue made by Topre? They just don't match the red Esc you have, which is a different shade from what Matt3o calibrated. As you said, the space bar seems brighter, which makes sense considering he tried to calibrate it to the brighter Limited Edition HHKB set.
It's kind of the point considering the set that Matt3o calibrated against was the set you don't have, which may be the reason why it doesn't match.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #916 on: Sun, 24 July 2016, 00:11:58 »
First would be:
Well said, rombro.
dario, you've dubbed one "true red" (from Realforce) and the other "miscolored red" (from PFU/HHKB). Those are your opinions. Sorry these are not matched to your personal preference but saying Matt3o's work is 'wrong' is just plain rude.
Offline atlas3686
  • HHKB Elite
« Reply #917 on: Mon, 25 July 2016, 09:22:39 »
Have I missed round 2? Would have definitely taken a pink or 2 as well :)
Offline xondat
  • i'm not a star
« Reply #918 on: Mon, 25 July 2016, 09:37:25 »
It's on Massdrop now.
« Reply #919 on: Mon, 25 July 2016, 09:46:57 »
False.
Offline xondat
  • i'm not a star
« Reply #920 on: Mon, 25 July 2016, 09:56:26 »
False.
Oh. You missed it, atlas.
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #921 on: Mon, 25 July 2016, 10:09:24 »
i'll be waiting for the goods to come!
ordered 20 caps for my friends in Indonesia huehehe
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline Geckt
« Reply #922 on: Mon, 25 July 2016, 10:26:52 »
Not sure if I liked all the colors, but, hey it's either this or nowhere on the market will I ever find these BN again.
Offline atlas3686
  • HHKB Elite
« Reply #923 on: Mon, 25 July 2016, 10:53:23 »
False.
no worries, I got all the colours from the first round, would have liked green though. Hopefully we get a round 3 with pink making the cut.
Offline Pestik
« Reply #924 on: Tue, 26 July 2016, 02:36:30 »
So glad I didn't miss this! Can finally replace the crappy ABS space on my Realforce. Also if this GB is ever resurrected for an R3 a few years from now, a purple colorway may prove popular :) I know I'd be all over that.
Offline nickysan92
« Reply #925 on: Tue, 26 July 2016, 03:21:57 »
Aww snap I missed the drop due to a payment error from my bank and I was unable to resolve it before the cut-off time.
Any idea if this will ever drop again or if there's any existing vendor that have these in stock?
« Reply #926 on: Tue, 26 July 2016, 07:41:38 »
There was a huge spike of orders at some point during the drop, so I wouldn't be surprised if it was a vendor.
Offline Elrick
  • Hype Master
« Reply #927 on: Tue, 26 July 2016, 21:54:02 »
Not really, just ordered 4 of everything towards the end  8) .
Just like the first GB, always buy FOUR of everything like your life depends upon it.
Offline swimmingbird
  • keyset hoarder
« Reply #928 on: Sun, 31 July 2016, 03:11:24 »
Elrick speaks the truth
Offline RobotMalcolmX
  • hackerman
« Reply #929 on: Thu, 04 August 2016, 10:20:53 »
In regards to dropping again, I have a feeling it'll be some time before this comes back up on Massdrop. Luckily, a lot of people probably bought more than they need and you could probably pick one up from them.
Offline joric
« Reply #930 on: Sat, 06 August 2016, 04:21:14 »
Damn! I missed the second run!
Another thing though.
All black stock ABS HHKB's spacebars (not PBT ones, those are perfect) apparently have tiny discolored spots, like after dried droplets of water:
Two upper ones are ABS stock spacebars, the bottom is the new PBT spacebar (it's absolutely perfect, it's just grease).
Could anyone confirm all stock ABS spacebars have this defect (discolored spots)?
I bought two black HHKBs with an year-long interval, and they both have these nasty and pretty much visible spots. Looks like all black HHKBs are
affected.
Can anyone confirm?
Offline kawasaki161
« Reply #931 on: Sat, 06 August 2016, 05:29:36 »
Jup, mine also had it, but it's not miscolored, just mistextured, you can polish them out.
Offline suprsmo
  • Sydney, Australia
« Reply #932 on: Wed, 31 August 2016, 01:50:23 »
Bugger..too slow.
Got my RF and my FC660C.     :/
Poker
QFR
« Reply #933 on: Wed, 31 August 2016, 05:33:53 »
Bugger..too slow.
Some vendors might have bought some.
Keep your eyes peeled just after they are delivered.
Offline the_marsbar
« Reply #934 on: Sun, 09 October 2016, 10:04:56 »
So there's already some feedback that the spacebars are not as nice as the ones from the first run, even though the second run spacebars were supposed to be better, e.g., as it says on the Massdrop page for the drop, "this new iteration of the popular Topre space bar now features a refined texture much closer to the original".
Is there anything to do about this? If they're really as bad as the comments suggest, is this really tolerated?
There was a lot of manufacturing issues, but the updates on the Massdrop page said that the issues were resolved. I could live with the long wait (I haven't received shipping notice yet), but if the quality is also really low, then I'm really unhappy. Especially since I am most likely going to have to pay a high import tax on these spacebars (I ordered six).
« Last Edit: Sun, 09 October 2016, 10:07:05 by the_marsbar »
Offline Geckt
« Reply #935 on: Sun, 09 October 2016, 11:01:28 »
Now that they're in transit, I don't know if I'll ever use them with the RF RGBs incoming, must have a feel of those RF OG MX sliders.
Offline oscillik
    • music podcasts
« Reply #936 on: Sun, 09 October 2016, 15:53:24 »
As the person who donated their ABS spacebar for the original mold, and who owns quite a few of the original run - there's nothing wrong with the texture on the first run. Don't know what Massdrop are smoking.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
« Reply #937 on: Sun, 09 October 2016, 16:18:38 »
I'm gonna take a wild guess and say they changed manufacturing so they were cheaper to produce under the guise of making them 'better'.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #938 on: Sun, 09 October 2016, 16:19:39 »
That is what it sounded like as they said they had mold issues and such which was odd cause the molds made from the first run were great.
Offline Elrick
  • Hype Master
« Reply #939 on: Sun, 09 October 2016, 18:31:44 »
Business 101, it's ALWAYS better when the company makes profit on what it produces, especially when it costs far less to make  8) .
Looking forward to see if this batch matches the previous one in quality, otherwise it's FULL on refund time from MD.  All for them making money on this BUT won't tolerate shoddy manufacturing under any circumstance.
Offline Mr.Lunchbox
« Reply #940 on: Sun, 09 October 2016, 20:33:25 »
I received mine yesterday and while I don't have any samples from the first run I will say that the quiality of this second run is not great.
I ordered 2 spacebars and one was fine while the second had some minor abnormalities, looked like either the mold was not good or that particular injection wasn't right. Like it didn't fill the mold all the way in 1 or 2 spots.
I do have some that I ordered from AliExpress and I think the quality of those is better than this second run. Not by leaps and bounds mind you but better nonetheless.
For the time it took I'm not particularly happy with the results.
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #941 on: Sun, 09 October 2016, 20:40:19 »
Photos? would love to see a comparison of the aliexpress + md r2 ones.
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
« Reply #942 on: Sun, 09 October 2016, 21:44:20 »
So I got mine out to see if all the bad things being said are true and yeah these do seem to be sub par compared to the round 1 caps.
The texture feels quite a bit rougher to me and my dark gray (black) spacebar looks melted around the edges, I've never seen a cap that looked like that before. It's hard to photograph since it's basically just really shiny.
These do seem to be slightly different in profile compared to my other pbt topre spacebar I have from before when putting them side by side on my desk.
    • WTB/WTTF Thread
« Reply #943 on: Sun, 09 October 2016, 21:51:39 »
Well that sucks to hear. I may just ask for a refund than if they are noticeably worse than round 1.
« Reply #944 on: Sun, 09 October 2016, 22:22:11 »
What people have been reporting is really a shame.
This was one of the only things that I've ordered from MD in a long time and it might be the last. Tons of delays (even if they sent out emails about them) and then ****ty end product and ****ty postage (in some case I've seen posted)... game over.
Offline Elrick
  • Hype Master
« Reply #945 on: Mon, 10 October 2016, 00:02:07 »
Know how you feel, haven't gotten mine yet but if they arrive in a crappy condition, far less quality than the first round then I'm sending them back.
Think this will be the LAST Topre Space bar Group Buy, because MassDrop will be losing money on this.  Losing Group Buys are all avoided with in the future, and this looks like one of those "Loser" Categories.
Offline Belfong
« Reply #946 on: Mon, 10 October 2016, 03:43:59 »
Hopefully this is not the case and (the bad quality) is just an exception. I am hoping to be able to get myself into the third round. I really do need a PBT orange space bar or a pink ones to match the Realforce key sets that I have. Come on, Mass Drop, don't disappoint.
Offline Lansky
  • Realest motherthocker
« Reply #947 on: Mon, 10 October 2016, 04:32:55 »
Damn, it sucks to hear about these quality issues.  :(
Unfortunately my order has already been shipped out and will be here within a few days, so too late to cancel it. Guess I'll just have to go with it for now and see what they look like. But it sucks having to wait almost three months for them to arrive, only to find out that they're worse than the previous run, while paying a premium for them. Oh well...
Offline the_marsbar
« Reply #948 on: Mon, 10 October 2016, 06:58:46 »
Is it even possible to get a refund, if the quality of the product is that poor? Is it possible to write Massdrop now, and say that I don't want the spacebars because of the reports about poor quality?
Offline oscillik
    • music podcasts
« Reply #949 on: Mon, 10 October 2016, 08:10:03 »
I very much doubt it. You'll likely have to just wait to judge for yourself, and then return for refund. Unless your order hasn't already passed the point of cancellation before dispatch, in which case then I would assume you can cancel.
