Author Topic: Poker II issues after firmware upgrade  (Read 1673 times)
Offline asdjr
« on: Fri, 12 December 2014, 13:23:29 »
Received a KBC Poker II with clears from a Massdrop purchase and I have experienced a few issues on OSX, even after the firmware upgrade posted elsewhere on this forum.
Mainly, if I hold down the function key for an extended period of time (for example, to use the arrow keys), sometimes the function feature will "stick", as in even after I deactivate the function key, I cannot return to typing normally unless I unplug the keyboard.  I have experienced a few other instances where keys get "stuck" in their alternate functions like this and behave oddly unless I unplug the keyboard.
Did I get unlucky and receive a defective keyboard?  Has anyone else experienced occurrences like this after firmware upgrades?  Thanks.
Offline trizkut
Re: Poker II issues after firmware upgrade
« Reply #1 on: Fri, 12 December 2014, 13:27:01 »
When your function key is 'stuck,' do you have access to the entire function layer, or just the arrow keys?  Sounds like you might accidentally be pressing fn+space.
Offline asdjr
« Reply #2 on: Fri, 12 December 2014, 13:29:02 »
Hilariously enough, I continued searching after I posted this and yes, it appears that what was happening.  I should be careful in the future not to do that.
Thanks for your reply!
Offline jterp7
    • good typing
« Reply #3 on: Thu, 18 December 2014, 09:26:09 »
after update, only the fn seems to work after wake from sleep on osx. Its strange because before nothing worked.
