Author Topic: Newegg] mouse of keyboard under $40?  (Read 2076 times)
Offline Lain1911
  • God of the Wired
« on: Fri, 12 December 2014, 20:26:19 »
Looks like mouse and keyboard with black switches for under $40.
This legit?
http://www.newegg.com/Product/Product.aspx?Item=9SIA4U71H31614
Offline nomaded
Re: Newegg] mouse of keyboard under $40?
« Reply #1 on: Fri, 12 December 2014, 20:34:24 »
http://www.newegg.com/Product/Product.aspx?Item=9SIA4B41EC3800
This is just the keyboard, also claims to be Cherry MX blacks, for $30 after shipping.
Dvorak
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2 on: Fri, 12 December 2014, 20:39:29 »
The small-sized function keys smell suspicious.  You generally can't do that with conventional MX switches-- the cap won't clear when depressed, without a very nonstandard cap design.
Overton130, Box Pale Blues.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #3 on: Fri, 12 December 2014, 20:42:09 »
Its almost worth buying it just to desolder it for the switches. Haha.
Offline FoxWolf1
  • 154
« Reply #4 on: Fri, 12 December 2014, 23:54:21 »
Beware, many 3rd party vendors on Newegg in particular select "black Cherry MX" for switch type on the "specifications" tab when selling non-mechanical keyboards on Newegg. May be a default option of some kind, a translation issue, or a technical issue compounded by lack of English language skills on the part of the sellers.
I suspect that's probably the case here.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sat, 13 December 2014, 11:17:32 »
AJazz do have some MX models... but these are not them. As FoxWolf1 says, lots of those 'from Asia' 3rd party sellers mark incorrectly have wrong description and etc, use care and common sense when buying anything from those. I still wish newegg wouldn't have allowed those on, it generally dragging down the site experience, quality of goods and more.
Offline orihalcon
« Reply #6 on: Sat, 13 December 2014, 12:29:40 »
Reviews on Newegg say that they aren't actually MX black.  Also comes with a CD of malware as a bonus according to multiple reviews! Might want to sit this one out.
