Author Topic: Seperate tenkeypads and ALT+code characters?  (Read 1767 times)
Offline mogo
« on: Sat, 13 December 2014, 16:48:10 »
I got a Leopold mechanical tenkeypad from Massdrop recently to help out with some of my more number-intensive data entries and to also regain a capability I lost in transition to a 60% board: the ability to type ALT+numpad number codes to produce uncommon symbols and letters. Unfortunately, it doesn't work! I mean, it works just fine as a numpad for number entry, but I can't ALT+type out any specific characters with it. Can anyone clue me in as to why?
Offline Jersern
  • Australian Keyboard Modding and Repair Service
Re: Seperate tenkeypads and ALT+code characters?
« Reply #1 on: Sat, 13 December 2014, 16:59:47 »
There is a possibility your numpad is not outputting correct scan codes. As in it's scan codes are for the number row. Another possibility is you haven't engaged numlock.
Offline MGH
« Reply #2 on: Sat, 13 December 2014, 17:04:19 »
Pretty sure the leopold numpads don't actually us numberpad scancodes but rather number row scancodes, which sucks and defeats a lot of the purpose to buy one. But to make sure, just load up aquakeytest and check the scancodes
Offline esoomenona
  • Gnillort?
« Reply #3 on: Sat, 13 December 2014, 17:28:20 »
« Last Edit: Wed, 19 August 2015, 09:23:25 by esoomenona »
Offline mogo
« Reply #4 on: Sat, 13 December 2014, 18:19:57 »
Very odd. And I'm certain numlock isn't interfering, it makes no difference whether on or off. I'll go find aquakeytest later. And my numpad has a Tab key I'd probably be okay with switching, but I think you're right, AHK doesn't distinguish which input device it comes from. :(
Offline Heliosphere
« Reply #5 on: Sat, 13 December 2014, 19:16:40 »
If you read the Massdrop comment thread, they confirmed that the numpad outputs number row outputs rather than numpad outputs. I picked up a Keycool numpad instead because of this.
Offline mogo
« Reply #6 on: Sun, 14 December 2014, 01:41:14 »
Well butts.
