Author Topic: [IC] GMK Blue Mod Set (Final Render & Pricing Received) Going Live April 3rd!  (Read 1953243 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: [IC] GMK Spacebars and Other Mini Sets
« Reply #150 on: Sat, 03 January 2015, 09:15:10 »
Hope you can add key  below:
Winkeyless with B profile: Ctrl 1.5x; Alt 1.5x; Alt Gr 1.5 x; Windows 1x (only my opinion because I like B than A profile )
Optional with Delete; End; Page Down (E profile for 1800 layout). There is group buy about leeku 1800. So I think there are more people interested keycaps for 1800 layout ;)
I will add in 1800 compatibility. I wasn't planning on adding winkeyless B profile, but if more people are interested I will.
Sound good :thumb:
« Reply #151 on: Sat, 03 January 2015, 12:43:13 »
I was more a fan of AE mods, 3B doesn't do it for me at all.
AE is nice and I would love to see something made with it, but I think there needs to either be a TA Green replica dyesub or Alphas (with pad printed sublegends) done to really make it good.  As it is, if you really want something AE, you can pick up shift, alt, ctrl, enter, and WASD from EK in AE.  It's not the full set, but it's a good mix.  It looks nice with TA and Beige and Cream, but I'm not sure what else it would go with.
The main reason I like 3B is that I think it goes with more sets out there, so there's a better chance of it succeeding.  It's Bill's buy though, so he has the final say on all the color choices.
Offline billnye
  • ability man
Re: [IC] GMK Green Mod Set
« Reply #152 on: Sat, 03 January 2015, 12:56:18 »
OP updated to reflect where we are currently ^-^
Offline ideus
  • Björkö.
« Reply #153 on: Sat, 03 January 2015, 12:56:54 »
\| (1 key): 1.0, D profile.
Offline exitfire401
  • The Force is Re/\l
« Reply #154 on: Sat, 03 January 2015, 13:08:54 »
Offline radio_killah
  • Chinchillin'
« Reply #155 on: Sat, 03 January 2015, 13:46:06 »
Agreed. This would be appreciated.
Another addition:  both a regular and an offset 1.75 ctrl key, not necessarily stepped but just both stem types.
Offline billnye
  • ability man
« Reply #156 on: Sat, 03 January 2015, 13:49:29 »
Added both in. I'm pretty sure the offset one will have to be stepped, but I'll ask if they have a fulltouch mold.
  • Chinchillin'
« Reply #157 on: Sat, 03 January 2015, 13:58:16 »
Awesome. I don't know about others but just having the option for both the regular and offset position is useful. Having full touch or stepped doesn't matter as much. But thanks BILL!
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #158 on: Sat, 03 January 2015, 14:50:40 »
I'm happy about this. Will this set work with Ivan's Dolch? From what I saw it looks like it would but I can't really tell.
Offline exitfire401
« Reply #159 on: Sat, 03 January 2015, 15:00:54 »
Looks likely would match pretty well to me.
Offline billnye
  • ability man
« Reply #160 on: Sat, 03 January 2015, 15:02:27 »
As you can see from nubs' pic I think it will go very well! Bear in mind though, the text will likely be black. It is mainly meant to match classic beige and other sets with black text.
Offline renne
« Reply #161 on: Sat, 03 January 2015, 15:56:56 »
what about number pad and blanks?
« Reply #162 on: Sat, 03 January 2015, 16:01:57 »
Do you plan on doing an Esc set or adding different color Esc keys in?  I asked because that's an easy way to try out color combos you're interested in for future runs.
Offline billnye
  • ability man
« Reply #163 on: Sat, 03 January 2015, 16:02:52 »
I wasn't on planning on having numpad as that would add more keys to the set which is already getting quite large. Blanks may be included, but only if more people show interest in them.
Offline billnye
  • ability man
« Reply #164 on: Sat, 03 January 2015, 16:04:16 »
I might include some escapes. I am really fond of the scitex color scheme, so I might do one in that color and a few other combinations
pic from Ivan's late GMK gb
Offline renne
« Reply #165 on: Sat, 03 January 2015, 16:05:41 »
Sure. Count me in. And what about the modifier font, text or symbol or both?
Offline billnye
  • ability man
« Reply #166 on: Sat, 03 January 2015, 16:06:56 »
Text. All legends will be true to original Cherry ANSI
  • Chinchillin'
« Reply #167 on: Sat, 03 January 2015, 16:21:13 »
ooooo nice choice.
Offline Geroximo
« Reply #168 on: Sat, 03 January 2015, 18:07:22 »
interested
Offline LechnerDE
« Reply #169 on: Sat, 03 January 2015, 18:08:25 »
I am getting more and more hyped about this Mod Set  :thumb:
Do you have a rough timeline for it? When do you plan to launch a GB?
Offline ideus
  • Björkö.
« Reply #170 on: Sat, 03 January 2015, 18:22:27 »
They will match very well, even with black legends, the colors go well together.
« Reply #171 on: Sat, 03 January 2015, 18:45:34 »
The OG Dolch and GMK CC Grey I think Ivan used are very close in color, so it should look good IMO.  It goes a little better with the lighter 2B Grey, but it's still nice together.
That would be nice.  I have a few more suggestions for colors that I think could be fun (crappy mockups included):
1. CV Yellow on CC Grey - Yolch
2. UN6037 Cyan on CC or 2B Grey
3. AE Green on UN33656 Magenta or the inverse
4. Some Manly Unicorn Loving - UN5046 Purple on CV Yellow, AE Green, and UN6037 Cyan and UN6037 Cyan on UN5046 Purple
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #172 on: Sat, 03 January 2015, 18:54:35 »
Love the UN6037 Cyan on CC or 2B Grey.  Would like to see a whole set done like that.
The Purple on Yellow is also nice  :)
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline ideus
  • Björkö.
« Reply #173 on: Sat, 03 January 2015, 19:05:29 »
Rubout (1 key): 1.75 full touch C profile with red or dark brown legends.
I do not know if this can be done with GMK available molds, but it would be very cool to get it as a novelty that can be use instead of Control to replace the CapsLock key a la Symbolics.
Offline billnye
  • ability man
« Reply #174 on: Sat, 03 January 2015, 19:09:46 »
I'll see if they have the mold
« Last Edit: Sun, 04 January 2015, 10:15:48 by billnye »
Offline billnye
  • ability man
« Reply #175 on: Sat, 03 January 2015, 19:10:57 »
I will consider some of these! I have some other color sets I've had in mind. I would like to see a Yolch one though.
Offline billnye
  • ability man
« Reply #176 on: Sat, 03 January 2015, 19:13:06 »
If anyone else has suggestions let me hear them!
Offline mason
  • have fun with her, ryan
« Reply #177 on: Sat, 03 January 2015, 23:07:24 »
my wallet is also ready
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #178 on: Sun, 04 January 2015, 03:40:55 »
I'd be in for a set
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #179 on: Sun, 04 January 2015, 10:45:54 »
+1 on basically all of them.
I like the idea of green mods set... but bummed it's with black legend. Perhaps consider to make it tonal, with one shade of green on the other? I think that would look really great and would go with either classic black on beige or white on black, Dolch, etc... set.
Offline billnye
  • ability man
« Reply #180 on: Sun, 04 January 2015, 10:53:51 »
I'm going to ask for mockups for black text on all 3 colors of green. If people are not happy with those combos, I will consider this!
Offline Blackehart
« Reply #181 on: Mon, 05 January 2015, 18:09:17 »
Interested
Any chance of getting an extra left shift for us unclean fc660m users?
« Reply #182 on: Mon, 05 January 2015, 18:20:43 »
It might be nice just to cement the color idea.  A Dolchish grey legend may also have the same effect Ivan is looking for, but I'm not sure.
Offline billnye
  • ability man
« Reply #183 on: Mon, 05 January 2015, 18:21:36 »
Interested
Sure I'll add it!
« Reply #184 on: Mon, 05 January 2015, 19:16:55 »
No I mean something like N7 on AE, dark green on light green. Like this ****:
I like the colorway, but have no interest in the weed/stoner stuff.
« Reply #185 on: Mon, 05 January 2015, 19:29:06 »
Someone really needs to do something yolch so we can see how the colors come out.
« Reply #186 on: Mon, 05 January 2015, 19:36:14 »
+1
« Reply #187 on: Tue, 06 January 2015, 01:48:31 »
That or GMK Dolch Pink.
« Reply #188 on: Tue, 06 January 2015, 06:49:57 »
Offline frostylove
« Reply #189 on: Tue, 06 January 2015, 10:11:33 »
Looks nice.
Interested :thumb:
Suhr Custom Standard Carve Top
Manson DL-1 Matt Bellamy Signature
Marshall JVM410H + 1960A
Lovepedal Kanji Enternity
« Reply #190 on: Tue, 06 January 2015, 10:38:45 »
Oh, do I see right that the legend colour is black?
Offline billnye
  • ability man
« Reply #191 on: Tue, 06 January 2015, 10:43:37 »
Yes! CR, the pitch black color.
« Last Edit: Tue, 06 January 2015, 10:48:32 by billnye »
Offline FrostyToast
  • Litshoard
« Reply #192 on: Tue, 06 January 2015, 10:47:34 »
Yes! C9, the pitch black color.
Hold on, what is C9?
I only see CR and N9 in the photo.
Quote from: elton5354
Offline billnye
  • ability man
« Reply #193 on: Tue, 06 January 2015, 10:49:15 »
CR my bad. You guys know what I mean :))
N9 isn't quite as dark as CR.
Offline honoka
« Reply #195 on: Tue, 06 January 2015, 17:37:10 »
Interested in blanks!
Also, F1-F4 and F9-F12 keys would be nice for those that don't want contrasting F-rows.
« Reply #196 on: Tue, 06 January 2015, 17:48:40 »
Thanks. The white colour sample in one of the photos looked like it had the label CR, CB or CP and was partially obscured, so I asked just to be sure.
Offline ideus
  • Björkö.
« Reply #197 on: Tue, 06 January 2015, 20:11:43 »
Coolness! my wallet is almost ready.
Offline ideus
  • Björkö.
« Reply #198 on: Tue, 06 January 2015, 20:17:25 »
Interested
Sure I'll add it!
+1 on this, I also have one of those unclean things here.  :(
Offline billnye
  • ability man
« Reply #199 on: Tue, 06 January 2015, 20:21:17 »
This won't be launching for about a month.
The package with CMYW is supposed to be coming at the end of this month, and I am hoping to get all those packages out in about a week. I want to get CMYW completely done before I start another group buy.
ETA: February 6th
