Author Topic: [IC] GMK Blue Mod Set (Final Render & Pricing Received) Going Live April 3rd!  (Read 1952339 times)
Re: [IC] GMK Green Mod Set (Initial Mockup Received)
« Reply #300 on: Tue, 20 January 2015, 23:16:21 »
If we could do a white on lime ( is that AE? same as Ivan's green spacebars?) I'd probably order 6+ sets
Yep that's the one. I've got space bars ready and waiting too.
Regardless I'll always try to be down for one set. Also this color would work perfect with my commodore which I believe is the intention in the vintage set.
However who needs vintage when you can have lime green!!!
If this doesn't happen in a few months I'm running it :thumb:
You bring up a good point about my opinion that I didn't think about until now.
I will buy one of these no matter what, but I would buy 2 or 3 lime sets.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #301 on: Tue, 20 January 2015, 23:22:56 »
Yeah I'd definitely buy two lime sets, I want to do a lime bottom row on a 60% and use a full set on my Filco.
Offline bueller
  • MX baller
« Reply #302 on: Tue, 20 January 2015, 23:26:21 »
One thing I do really like about this set is the keys available, seems like a good mixture of the bare essentials with some extra keys thrown in.
Offline Wildcard
  • When caffeine isn't enough
« Reply #303 on: Tue, 20 January 2015, 23:30:20 »
I just wish EK would have offered full set of GMK lime green mods and we wouldn't be having this discussion.
Offline FrostyToast
  • Litshoard
« Reply #304 on: Tue, 20 January 2015, 23:31:23 »
I like lime more.
But maybe pale green would be more unique.
Quote from: elton5354
Offline bueller
  • MX baller
« Reply #305 on: Tue, 20 January 2015, 23:31:46 »
Tell me about it. So close, they only had to add a menu, windows, caps, tab and backspace. I've actually got all the ones they do offer but it looks **** without at least a full bottom row.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #306 on: Tue, 20 January 2015, 23:43:09 »
I'm a huge fan of the color combo in the mod pack mockup.  Not so much lime though.  I guess mainly because lime is quite
an extreme color and the other is very subtle.  I'll definitely be in for a pack.  And, hopefully Photekq's beige GB will start soon too.
Offline ideus
  • Björkö.
« Reply #307 on: Wed, 21 January 2015, 00:00:13 »
Have you ever considered the green color used in Ivan's Dolch color pack? but with black legends maybe?
« Reply #308 on: Wed, 21 January 2015, 00:05:18 »
The color in the render was off in Ivan's color pack. The color is UN6037 which is the same color as the Cyan in the CYMK and CMYW sets.
Offline renne
« Reply #309 on: Wed, 21 January 2015, 02:21:36 »
wait, where is the esc
There is a separate escape pack. He didn't send the mockups for it
great! cause I do want a matching-colored esc. but it'll be better if I can only buy the matching-colored one, not a ton of esc(s).
There's only 3, so it will only be a few dollars ^-^
oh, 3 is fine. thank you! I'll purchase 1 or 2 set(s) depending on the final price.
Offline billnye
  • ability man
« Reply #310 on: Wed, 21 January 2015, 08:31:02 »
Probably not. I don't think that will match Classic Beige well.
The main intention of this set is to match Classic Beige. I will post the other green mockups when I get them. I agree with you guys that white on lime looks quite nice, but this group buy won't be that. I will keep it in mind for a later group buy.
From the initial mockup, the 1800 caps (r1 del/end/pg dn) and all alt gr caps are being dropped. Also, the control caps will have the "control" legend instead of "ctrl".
Keep in mind that caps in real life look different than the mockups.
Offline tjweir
« Reply #311 on: Wed, 21 January 2015, 08:34:24 »
Awesome, if it was the colour from the Dolch GB I've have the pass on this.
The teal looks great with Dolch, but not with Biege.
Offline Data
« Reply #312 on: Wed, 21 January 2015, 08:35:05 »
Your Mel Gibson avatar is creeping me out dude.  :P
Offline ideus
  • Björkö.
« Reply #313 on: Wed, 21 January 2015, 08:37:08 »
I agree with your opinion on colors, regarding the caps that you are going to drop I'd prefer to have them, but again, I'd prefer to get the GB reaching its MoQ over everything else, so I am in all the way, I think Ivan's GB will still be a far more larger modifiers set with language alternatives and all, and while I hope both do well, I think this one has more possibilities because of price, just be sure to choose the color that best matches available beiges - there are over a dozen variants -, and if possible black Cherry sets.
Offline billnye
  • ability man
« Reply #314 on: Wed, 21 January 2015, 08:39:06 »
How can someone this handsome creep you out?
If price is too high, the next thing to get axed is B profile. IMO, cherry sets are meant to be used with A profile. Most group buys before this have had B, but I would like to see more people creating A profile sets.
Also, HHKB kit will always be staying. Don't worry about that support being cut.
« Last Edit: Wed, 21 January 2015, 08:41:30 by billnye »
Offline ideus
  • Björkö.
« Reply #315 on: Wed, 21 January 2015, 08:39:59 »
Your Mel Gibson avatar is creeping me out dude.  :p
Offline geniekid
« Reply #316 on: Wed, 21 January 2015, 10:51:33 »
I think black on lime (AE) would look quite good!  I also think you should consider white on N7 for a future GB.
It warms my heart to see such stalwart support for HHKB. ;D
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #317 on: Wed, 21 January 2015, 10:57:53 »
3B? Nope. My least favorite color they offer.
It's the darker of the greens here.
« Last Edit: Wed, 21 January 2015, 10:59:50 by IvanIvanovich »
Offline ideus
  • Björkö.
« Reply #318 on: Wed, 21 January 2015, 15:48:39 »
Well, its contrast with black legends does not look that bad. And thank you for sharing this cool picture, what keyboard is this?
Offline geniekid
« Reply #319 on: Wed, 21 January 2015, 16:14:44 »
G80-9009
Offline ideus
  • Björkö.
« Reply #320 on: Wed, 21 January 2015, 16:18:22 »
Thank you very much for the reference.
« Reply #321 on: Wed, 21 January 2015, 21:15:21 »
Are these the same as the dark green keys on a WEY board?  I kind of prefer the lighter, pale ones.   :-X
Offline Elocutive
« Reply #322 on: Wed, 21 January 2015, 21:24:26 »
Agreed. The lighter green is much more pleasing IMO. just my .02
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline billnye
  • ability man
« Reply #323 on: Wed, 21 January 2015, 21:25:01 »
To be honest, I'm not a big fan of 3b either.
Waiting on mockups in all green colors to make the final calls.
Offline renne
« Reply #324 on: Wed, 21 January 2015, 22:15:40 »
I'm interested in both the lighter green and the darker green in that picture.
Offline jonathanyu
« Reply #325 on: Wed, 21 January 2015, 22:44:33 »
I believe they are the same green.
« Reply #326 on: Wed, 21 January 2015, 23:33:29 »
I'll just post these side by sides again for people to see the colors.  I still think 3B goes the best with the greatest number of sets and N7 comes second.
OG Cherry Cream from beige and cream ABS:
OG Cherry BoW ABS:
OG Dolch ABS:
OG TA Green Dyesub on light grey:
OG TA Blue Dyesub on light grey:
Offline bueller
  • MX baller
« Reply #327 on: Wed, 21 January 2015, 23:37:35 »
While I'd agree that it's definitely a good match for Classic Beige I just don't like the shades of N7 and 3B, they remind me of wallpaper.
Offline korrelate
  • iubeo stultum esse libenter
« Reply #328 on: Wed, 21 January 2015, 23:52:38 »
Absolutely Yes Please!
Could we please, please, please have some blank 1.25u R4 Winkeys?
Maybe a couple of 1u R4s as well?
Some of us just can't stand logos (particularly windows logos - of any variety - they just don't belong on my custom keyboard).
Cheers,
K
« Last Edit: Wed, 21 January 2015, 23:54:46 by korrelate »
Topre REALFORCE
Offline billnye
  • ability man
[IC] GMK Green Mod Set (Revised Mockup Received)
« Reply #329 on: Thu, 22 January 2015, 06:21:22 »
I received the revised mockup. As of now, the cost of the set is roughly $70. Let me know if that price is ok for you guys, or if I need to work to further cut down the price :)
Also, important to note, I am still getting mockups done for other colors, I just need to finalize the caps and legends first ^-^
« Last Edit: Thu, 22 January 2015, 09:29:12 by billnye »
Offline billnye
  • ability man
« Reply #330 on: Thu, 22 January 2015, 06:22:59 »
Cheers,
K
Hey Korrelate!
I'm not planning on adding any blank right now. Unfortunately you're in the minority with that opinion, and I'm trying to keep prices as low as possible.
Offline ideus
  • Björkö.
« Reply #331 on: Thu, 22 January 2015, 07:08:31 »
I received the revised mockup. As of now, the cost of the set is 54.39€ (roughly $63 USD). Let me know if that price is ok for you guys, or if I need to work to further cut down the price :)
The price is acceptable, there is a good balance of basic keys and some other ones, I just wonder if some may need a 1.25u Fn Key though. And the color...well just not sure about it, so the other options you mentioned may be needed to get a final go from the interested parties.
Offline billnye
  • ability man
« Reply #332 on: Thu, 22 January 2015, 07:10:55 »
Yea, I'm not a big fan of the color either.
I asked for a final change in the legends, add "Enter" text as well as the icon to the ISO enter. I figured it would make sense to make the ISO caps US ISO since all the other caps are like that :blank:
Offline ideus
  • Björkö.
« Reply #333 on: Thu, 22 January 2015, 07:16:35 »
The arrow with the legend looks classic, good move. What are the applications of the 1u windows keys in row 5 profile? I have seen row 5 only in win key less keyboards, so it does not make sense to me. (Edit) I think I got my own answer, the HHKB layout may be the culprit.
Offline billnye
  • ability man
« Reply #334 on: Thu, 22 January 2015, 07:21:33 »
I'm hoping to fix unfortunate situations such as this:
Some WKL boards don't have blockers, so if they want to use A profile, I want to make sure they're covered!
Offline billnye
  • ability man
Re: [IC] GMK Green Mod Set (Revised Mockup Received)
« Reply #335 on: Thu, 22 January 2015, 07:22:23 »
Next revision received:
Offline billnye
  • ability man
« Reply #336 on: Thu, 22 January 2015, 07:27:38 »
Quote from: GMK
In case of placing an order I will add one surprise key for every ordered set.
:eek:
Mystery keys straight from GMK! I'm pretty excited to see what that turns out to be
Offline ideus
  • Björkö.
« Reply #337 on: Thu, 22 January 2015, 07:38:18 »
Fair enough. What do users of those boards prefer: a windows key, or a blank one?
Offline tjweir
« Reply #338 on: Thu, 22 January 2015, 08:08:15 »
I can use 30 of these, works for me!
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #339 on: Thu, 22 January 2015, 09:26:19 »
What? There isn't Delete; End; Page Down R1??? :confused:
Offline radio_killah
  • Chinchillin'
« Reply #340 on: Thu, 22 January 2015, 09:37:36 »
Seems a bit expensive to me. It might suffer from the same issue that Ivan is having with his 85|15 mod pack. I think of you can get something that is around $60 with shipping to most people you have a winner. $70 before shipping is too much in my opinion for just mods :/
Offline billnye
  • ability man
« Reply #341 on: Thu, 22 January 2015, 10:32:02 »
I can work to cut down a few if a few other people feel this way. Also, keep in mind it isn't just mods, it's meant for full TKL compatibility. Just a mods set could be much cheaper, but I want to do something new.
Offline billnye
  • ability man
« Reply #342 on: Thu, 22 January 2015, 10:57:59 »
I took out 1800 support because it wasn't full and adds a lot of keys. Sorry :-[
« Reply #343 on: Thu, 22 January 2015, 11:03:13 »
FOR CLARITY
THIS IS WHAT BILL IS TAKLING ABOUT PEOPLE, NEVER, EVER, EVER TRUST A MOCKUP
PS: I THINK MY CAPSLOCK IS STUCK #SORRYNOTSORRY
« Last Edit: Thu, 22 January 2015, 12:10:30 by SpAmRaY »
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?PHPSESSID=1iioclkjvespme7clp04jp9lm2454pj0&topic=63161.0
« Reply #344 on: Thu, 22 January 2015, 11:03:15 »
Interested.
Green color usually nice to combine with other keyset.
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
« Reply #345 on: Thu, 22 January 2015, 11:06:21 »
You are not really contributing much to the discussion.
  • Chinchillin'
« Reply #346 on: Thu, 22 January 2015, 11:08:40 »
Yeah I guess just wait to see what other people say but I just want to be sure that we don't get stuck with low numbers due to a high price. Because that is what is holding up Ivan in his current GMK GB, and that is a classic beige which is very useful.
Offline billnye
  • ability man
« Reply #347 on: Thu, 22 January 2015, 11:12:03 »
I could have phrased that a little better. What I meant is that how colors look in mockups is not always true to how they will look in real life due to how the artist uses lighting in the 3D rendering program.
I don't really appreciate you coming in just to scrutinize part of something that I said.
« Reply #348 on: Thu, 22 January 2015, 11:16:51 »
You guys are way too serious for me good luck finding 250 people to buy these caps I won't be participating.
I thought it was funny that anyone would really think the mockups from GMK are very accurate, I mean look at the one they did for dolch with the color pack, it is awful.
And if I was scrutinizing I would say green looks like butt and do that many people like classic beige?
« Reply #349 on: Thu, 22 January 2015, 11:34:56 »
Sorry ray, but if you don't want your posts to be misinterpreted then you shouldn't talk with gifs. It was very unclear what you were trying to say.
